Installing an Altenator 99 SE-L
Old Jul 13, 2009 | 12:56 PM
kapp241's Avatar
I'm getting ready to swap but by looking in the engine bay, looks like I need to remove the radiator. Does anyone have any insight to this maintenance issue?
Old Jul 13, 2009 | 01:00 PM
goggle's Avatar
Alternator replacement
I did this and you need to do it from underneath.
Remove the plastic cover. Release belt tension and make sure belt is loose.
Remove the A/C compressor bolts, don't take the hoses off, hoses are rubber so it will swing out of the way.
Alternator can be unbolted from on top and underneath and removed.
No need to remove radiator.
Old Jul 13, 2009 | 01:23 PM
pmohr's Avatar
No more Maximas...
You post whored to make this thread?
Had you searched, you wouldnt've 'needed' to post meaningless crap in other people's threads. When I say 'meaningless crap', I mean this:
good luck
Ha! Ha!
Now, as for searching, you would've found this:
http://www.motorvate.ca/mvp.php/500
http://forums.maxima.org/4th-generat...placement.html
http://forums.maxima.org/4th-generat...nator-r-r.html
...etc.
Hell, the instructions are in the stickies:
http://forums.maxima.org/4th-generat...on-maxima.html
Might I mention the following:
Originally Posted by phenryiv1
If you ask a question and the answer can be found in the FAQ threads, your thread gets locked.
http://forums.maxima.org/4th-generat...king-rule.html
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
