anyone change their 95-96 airbag and steering wheel to a 97-99?
I did and now the airbag light's flashing. everything bolted up fine and went smooth. i disconnected the battery currently in hopes of the ecu resetting itself but has anyone else had this problem and how did you fix it? thanks
nick
nick
You got some ***** man.
I highly doubt resetting the cars ecu will do anything to help. But try this...
Open the driver's door. Note the rubber covered button, a button which is
pressed by the door when the door is closed. This is the Driver's Door
Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7
seconds after turning the ignition switch ON. Turn the ignition OFF.
Close the driver's door. Start the engine.
Switch (DDS).
trasmadean
Feb 1, 2017 08:20 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
