TPS help
Old Jul 19, 2010 | 04:20 PM
icedout's Avatar
TPS help
what would make your tps go bad then when you put a new one in go bad again in a week...
Old Jul 20, 2010 | 05:38 AM
mistur_sleepyass's Avatar
it could possibly be faulty wiring shorting it out
Old Jul 20, 2010 | 05:54 AM
cashoit's Avatar
u sure u installed correctly?
Voltages and signal come from ECU and battery.
Old Jul 20, 2010 | 06:23 AM
ajm8127's Avatar
For sure. Check the wiring. How are you determining that the TPSs are bad?
Old Jul 20, 2010 | 11:49 AM
Trini Boom's Avatar
Yeah makes no sense that a new TPS goes bad in one week. Did you just screw out the old one and screw the new one in and plug it up? If so, you installed it incorrectly and that's why you have the code for it stored.
Old Jul 20, 2010 | 06:23 PM
icedout's Avatar
brought to the car to a tuner shop.My afc wasent reading any throtle,it was just 0 and the car was running like crap.He said it was the tps changed it ran good for a week and then the same damm thing happened.Doent make much sense to me that this is happening out of no where....any help would be great because the cars goin back to him this week.Its running so bad got to tow it down to the shop now.
Old Jul 20, 2010 | 06:30 PM
jholley's Avatar
Are the sensor and switch connectors snugly fit onto the TPS? Check those brown and grey connectors and their wiring.
Old Jul 20, 2010 | 06:33 PM
DennisMik's Avatar
When you get the car back there, just play stupid and don't tell him that someone on the org told you that the ecu could be causing it or you will be paying for a new ecu.
Old Jul 20, 2010 | 06:41 PM
icedout's Avatar
hell with that i got the jimwolf ecu in there lol.
Old Jul 20, 2010 | 06:42 PM
icedout's Avatar
i still have the stock ecu also.I dont know whats goin on with the tps just happened out of no where.
Old Jul 20, 2010 | 06:56 PM
Trini Boom's Avatar
Well if you change the TPS again and it lasts only a week, try back the stock ECU and see what happens..
Old Jul 21, 2010 | 04:22 AM
ajm8127's Avatar
Word.
If that doesn't help you are going to have to check the continuity of the wires going between the TPS and the ECU. Excessive current draw is about the only thing I can think of that would kill a potentiometer (what the TPS is). If it comes down to checking wires, make sure the red and white are not shorted to ground.
Another thing to look at is the actual voltage on the pins of the TPS once you get another working one. Make sure they are in spec. The red wire should have 5 volts, the black should be ground, and the white is the signal. The FSM recommends that you monitor the voltage as you depress the pedal and make sure that the response on the sensor is linear. The voltage should increase as you press the pedal down. It's on pages EC-128 to EC-133
Old Jul 21, 2010 | 05:43 AM
cashoit's Avatar
JWT ECU ehhhh? Didnt someone jus start a thread on that mod and its merits. Coincidence?? idk man.
Either way, if its the TPS then something def is fryin it. Go back to stock and see if that helps.
Old Jul 21, 2010 | 03:53 PM
icedout's Avatar
yea i will try it out but the jwt ecu has been in the car for a while now so it wouldent make sense if it was doin it now.I think the shop screwed up the wireing maybe cars on its way down there now so we see what happens in the am.
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
nizmolee
Aug 22, 2001 12:34 PM
