Replaced my 4th Gen Maxima Speakers
Old Jul 3, 2012 | 10:13 PM
EvoTillIDie's Avatar
Changed my front speakers seeing how only one was working....It was a easy install, & the speakers sound great, so I'll let this pics speak for themselves.
Old Jul 11, 2012 | 10:25 AM
djfrestyl's Avatar
Suspension Yoda
Cool, but I'd have recommended MDF mounting rings over reusing the plastic crap that's in there.
Old Jul 11, 2012 | 10:35 AM
Thanks but uh...how come? & I also want to know how do you tell the difference between the positive & negative wire in the door? I couldn't tell the difference & when I play from certain sources the left speaker sounds louder than the right
Old Jul 11, 2012 | 11:04 AM
djfrestyl's Avatar
Suspension Yoda
3 reasons.
1. Sound quality. Resonance. Plastic reflects sound waves and resonates/vibrates. So does your metal door frame. MDF is a dead material, pretty much absorbs sound waves, or at the very least, vibrates much less, speakers sound better.
2. Easier to mount speakers to MDF than spend the time to hack up your speaker and fish around for a mounting point in the soft plastic.
3. Your OEM speakers wouldn't be butchered, and you can return to stock, or sell those speakers any time you want.
I have the positive/negative wire colors memorized. But when I don't, I use a multimeter to determine which OEM wires are positive/negative.
These are the reasons I was telling you to have me do the work. Yea, you got it done, but you're missing the finesse and the other 40% of the knowledge to make it a really quality install, no offense.
Old Jul 11, 2012 | 11:09 AM
mrfliboi's Avatar
are those speakers factory bose speakers? because I heard bose speakers are more difficult as far as the amp..
Old Jul 11, 2012 | 11:17 AM
These are non bose, I wish they were bose, I probably wouldn't have changed them.
Old Jul 11, 2012 | 11:18 AM
djfrestyl's Avatar
Suspension Yoda
They are more complicated in terms of installation considerations.
Old Jul 11, 2012 | 11:24 AM
3 reasons.
1) Thanks, I might just go back & change the brackets seeing how I have to double check the speaker wires anyway.
3) The OEM speakers were completely blown with the coning & all out
Old Jul 11, 2012 | 11:26 AM
mrfliboi's Avatar
oh.. because I have bose speakers, but also have alpine type r speakers and a 1000watt vpower alpine amp that I was considering putting them in.
Old Jul 11, 2012 | 11:27 AM
djfrestyl's Avatar
Suspension Yoda
Makes sense. You probably won't notice a difference in sound if you switched to MDF rings. You might as well save yourself the few bucks for the rings since the speakers are already installed. It's only in larger/more expensive installs that it makes a difference. Still a practice I bring to all installs though.
When you check your wiring, wrap the leads in electrical tape. Something might be grounding out against the metal door.
Old Jul 11, 2012 | 11:28 AM
djfrestyl's Avatar
Suspension Yoda
You're going to have to run all new speaker wiring.
Old Jul 11, 2012 | 11:35 AM
Sounds good & I did..that's why I figured I probably wires a positive to a negative, also what do you think about heat shrink wire? I use those with other bare wires I connect together.
Old Jul 11, 2012 | 11:43 AM
djfrestyl's Avatar
Suspension Yoda
I almost never use heat shrink - I crimp everything.
Old Jul 11, 2012 | 11:46 AM
Any specific reason? Or you just rather crimp?
Old Jul 11, 2012 | 11:57 AM
djfrestyl's Avatar
Suspension Yoda
Yea just easier/faster than fussing with solder.
Old Jul 11, 2012 | 11:59 AM
Lol alright thanks
Lakersallday24
Nov 7, 2024 07:31 PM
CRizz
41
Jun 7, 2021 05:42 AM
jskirwin
Jun 8, 2016 08:49 AM
morteljc
Oct 19, 2015 10:47 AM
