Slip and abs light is lit permenantly...
Old 09-05-2014, 05:22 PM
greaseyoda's Avatar
This is a repetitive old problem went away a while ago but it still bothers me to have that unanswered... my car stalled and I had to wait 10 min b4 it cranks on but I had an annoying 2 lights that would remain solid and went into limp mode as I drove back home. No CEL light popped up and that makes me more curious.... someboody halp plz!
greaseyoda is offline
Old 09-05-2014, 06:17 PM
Y2kMaxima's Avatar
Well I've had that issue a couple times with my old 5th gen, but it had the cel light on along with slip and abs. Could be your MAF sensor going bad. I also read somewhere a crank position sensor would also give those symptoms.
Y2kMaxima is offline
Old 09-05-2014, 06:34 PM
Ghost_54's Avatar
Have your charging system checked, as the issue usually is related to the alternator on its way out ... possibly a weakened batery ... or even a bad ground somewhere, but from my own experience it turned out to be a bad alternator only putting out 8 volts instead of upwards to 14 volts.
Ghost_54 is offline
Old 09-05-2014, 09:46 PM
george__'s Avatar
Had a TCS, SLIP & ABS light on sometimes and it turned out to be the ABS sensor
george__ is offline
Old 09-06-2014, 03:00 PM
BigLou55's Avatar
Sounds like your abs wheel sensor. Not all 5th gens have TCS so I'd start there if I were you.
BigLou55 is offline
Old 09-06-2014, 04:24 PM
Itz Shak's Avatar
No problems with the speedomoter?
Itz Shak is offline
Old 09-09-2014, 06:37 PM
greaseyoda's Avatar
Thanks tomorrow I will put my baby on stilts and check out those abs sensors. I do remember putting a gas welder on the old front lower control arms....maybe I torched it on accident?
Old 09-26-2014, 07:24 AM
Mateen995's Avatar
had the same exact problem about a month ago, check the codes if there is any
the code that popped up for me was for the bank1 camshaft sensor, but the code only popped up later
i changed the other camshaft sensor & crank sensor anyways since nissan said they are faulty due to ****ty soldering.
you can replace the the camshaft sensors yourself easily if you want, there are a bunch of youtube videos on how to do it
the crank sensor is underneath the car which is a bit hard to get to
note that this is if you have ONLY the TCS & Slip light on,
these lights shouldn't be on once the engine is cold, the lights will re-appear once it stalls again.
Mateen995 is offline
Old 06-28-2018, 05:41 PM
maxinout93's Avatar
How do you know which abs sensor is bad? There are 4 of them.
maxinout93 is offline
egali045
04-02-2015 10:20 AM
PhillyDonut
10-29-2012 02:11 PM
danielm5486
05-31-2009 06:59 PM
maxima985spd
29
07-02-2007 05:56 PM
FieldzGood
03-05-2006 07:17 PM
Quick Reply: Slip and abs light is lit permenantly...
