Customize lights inside/Out of vehicle.
Old May 9, 2015 | 03:42 PM
Pboned's Avatar
I'm thinking about a idea for a light set up for the inside ando outside. I have a 2014 pearl white Max.
1) An artic blue Halo head light set up.
2) Swap out stock lights that come on when you open the doors. Overheard and by feet for artic blue.
3) The stock orange lights that come on behind your radio,navigation and in the general dash board area.
My idea is to make an artic blue/icy light theme. Has anyone done this before and how hard would it be to do? I might have to take it to a professional because I'm not good with cars myself and I want it to look good.
Any feed back is appreciated. .
Old May 9, 2015 | 05:16 PM
ThinBlue82's Avatar
Ummmm I'd say there's a wealth of information regarding lighting on this forum. I'd suggest using the search box.
Many have halos around their headlights (myself included) which is a common and relatively easy mod but involves baking open the headlight assembly and wiring things up to work properly so I'd suggest having a shop do it. The interior door lights are super simple and can be done in a few minutes. The orange dash and radio backlighting is a different story. A few have done it but it requires removing each individual led then resoldering the new ones in place for the entire dash which seems like a pain to me.
Anyway, good luck!
Old May 10, 2015 | 10:48 AM
Daaavid's Avatar
The amber lighting for your radio, navigation, and dashboard area is a very difficult, and costly job. If you do not have any experience soldering, consider giving it to a professional. Even then, they will charge you about $1,000 for it to be done. The LEDs (PLCC-4) are the size of Lincoln's forehead on the penny.
Here is what I have done. There is an overhead light next to your sunroof/moonroof controls that lights up the center console and cupholders, and you can change out with a different color LED. The factory color is orange, but I changed it to a 3mm blue LED to contrast the orange on the radio.
There are also little lights on the under the front driver and passenger door handles illuminating the door lock and window controls. Again, factory color is orange. You can change it to any color 3mm LED.
What it looks like when it is all said and done. Really helps contrast the orange on the radio, and looks much more modern and luxurious.
There are vendors out there that sell a plug-and-play projector light for the doors shining a Nissan logo already wired into where the factory 194 incandescent bulb would go. This way, you do not have to drill a hole into your door and do any wiring.
For your headlights, you can do it yourself or have a professional do it. There are ton of write-ups on how to bake your headlight open and reseal them, including the current Maxima we have. Many have halos on their Maximas. You will have better quality lights combined with a legitimate warranty through TheRetrofitSource.
Old May 10, 2015 | 11:31 AM
Pboned's Avatar
I really appreciate all this information and your help. I didn't realize how difficult it would be to get behind the dash area.
I'll take another look at these things once I get done work.
Old May 10, 2015 | 01:00 PM
1996blackmax's Avatar
Nicely done Daaavid!
Old May 11, 2015 | 09:04 AM
Pboned's Avatar
Could anyone recommend a good shop either in NY, around Queens or possibly around Newark, Delaware?
I would like to talk to someone about some halo lights and interior lights.
Old May 11, 2015 | 01:13 PM
ThinBlue82's Avatar
An .org member named kmoney does lights in nyc
Old May 12, 2015 | 08:25 AM
slatemaxima's Avatar
How did you manage to change the ambient lighting LEDs. Always wondered about those. Any links or write-ups by any chance?
Old May 12, 2015 | 07:40 PM
MaximaDrvr's Avatar
Just remember, most states have laws against visible blue and/or red lights visible from the vehicle.
Old May 13, 2015 | 08:23 AM
Daaavid's Avatar
The overhead ambient lighting require you to remove the entire sunroof controls, and then there is a little plug that is an absolute pain in the *** to remove, but it is the easiest do. IMPORTANT: MAKE SURE YOUR CAR IS OFF AND ALL THE LIGHTS ARE OFF. I also recommend disconnecting the negative battery terminal as you may possibly cause a short elsewhere and the interior lights will no longer power on. People on the 7GM Facebook group report that it is not fuse related, so replacing a fuse will not fix it!
  1. You'll need 3mm LED, anything larger will not fit and anything smaller will not emit enough light through the opening.
  2. From the front of the panel, pull downward and it should pop off.
  3. The 3mm LED sits inside this black box.
  4. I forget how to open the black box, but if I remember there are these little three black pins on the outside that you have to press down simultaneously and then it will separate revealing the light. Disconnect the harness that attaches to the box so you can remove it and put in the LED easier.
  5. Take your new 3mm LED and cut it to same size as the factory orange 3mm led. The reason to remove the box from the housing is because the new pins on the LED may be thicker than the factory OEM, so having the box separated will be easier for you to pry apart the old connectors to seat the new LED.
  6. Put the new LED in and close the box. It is important to close the box as the box puts pressure onto the wires to ensure the wires have a solid connection and act as a pressure crimp.
  7. Put everything back together, and enjoy your new blue light.
Old May 13, 2015 | 11:04 AM
Pboned's Avatar
Nice walk through.
Old May 13, 2015 | 01:23 PM
saltohio's Avatar
Thumbs up
Thanks. Well done.
Old May 13, 2015 | 02:35 PM
Daaavid's Avatar
Dependent upon what year, model, and package you have, the door light is another story and much more complex. To see if you have a light back there, turn on your parking light or low beams and place your hand behind the handle. All Maximas will have a hole for the light, but few will have a physical light. This is important because if there is actually a light behind there, then your vehicle is wired from the factory. If not, then you will need to run it.
You can pry open the door handle by putting a flathead screw driver or using those plastic trim removal tools on the bottom of the door handle and prying outward. It's held in by clips.
To change the door handle light, you will actually need to cut the wire to remove the LED as the housing cannot be removed.
  1. Take a flathead screw driver or a plastic trim removal tool and pry from the bottom.
  2. Here you can see the LED, housing, and the two wires. The LED housing cannot be removed, so you must physically cut the wires and crimp new ones.
  3. Cut as close as you can to the existing housing and splice them.
  4. Grab your new LEDs. These LEDs came pre-wired so all you have to do is match up the negative and positive, and it should light up. Link attached below.
  5. Solder or crimp, your choice. The lights will not be moved, but because it is in the door, it is subject to vibrations and slamming. Determine what is best for you. You will also want to heatshrink.
  6. Seat the wires neatly and ensure the light comes on. You can cut the wires shorter if you want, but there is ample room to tuck the wires.
  7. Finished product.
    http://www.ebay.com/itm/like/261615939634?lpid=82&chn=ps
Old May 13, 2015 | 03:09 PM
Pboned's Avatar
Hmm.. I haven't seen any lights around the door handle area.
Old May 13, 2015 | 03:23 PM
Emoney66's Avatar
need help...
trying to find some good led DTRL / turn signals ive tried a couple sets of bulbs with the resistors but cant seem to figure out why they don't blink, ive got them to turn on with the signal but they just stay on, then if I use the running lights they blow the fuse.... I tired looking for a thread on this but cant seem to find one... any help would do..
Thank you
Old May 13, 2015 | 03:30 PM
Daaavid's Avatar
I believe the lights are only wired if you have the mood lighting package from Nissan ($500). I will see if I can find a write up on how to wire it easily if you don't have the package.
Thank you
You need 3157CK base bulbs. If it is just a regular 3157, you will blow fuses.
Old May 14, 2015 | 08:31 AM
saltohio's Avatar
Thumbs up
Thank you! I'm very interested in doing this mod.
Old May 14, 2015 | 05:14 PM
Emoney66's Avatar
Talking
[QUOTEYou need 3157CK base bulbs. If it is just a regular 3157, you will blow fuses.[/QUOTE]
Thank you
Old May 14, 2015 | 05:16 PM
Emoney66's Avatar
Thumbs up
Thank you
Old Mar 10, 2023 | 11:59 AM
Lukesdad's Avatar
Wires?
    Qty 10 LED 3mm Pre Wired 12 Volt LEDs 12V Blue USA | eBay
Where is the best place to run these wires from the interior door handles? My maxima didn't bring these lights from factory but i did manage to get a set of the wiring harness with the lights on them from the junk yard and figured it would be a nice touch. I currently installed them and have them connected to that light on the door, so unless you open the door the light on the handle doesn't come on. I want them on while the car lighting is on, if that makes any sense....
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
iflexsteel
Sep 2, 2015 08:04 AM
A32goldylocks
Sep 2, 2015 06:39 AM
