Stillen FTSB Installation Directions
Old Dec 30, 2018 | 09:18 AM
reallywildstuff's Avatar
I splurged and bought one of these from a fellow Orger.
I would like to see Stillen's installation instructions before beginning - but I could not find them on the Series of Tubes.
Please point me to them.
Thanks -
BrianA in Houston
Old Dec 30, 2018 | 10:41 AM
Turbobink's Avatar
(1) Remove front strut mounting nuts ... 6 of them;
(2) Install tower bar brackets on each strut tower;
(3) Reinstall strut mounting nuts ... 6 of them, retorquing nuts to manufacturer specs;
(4) Install tower bar into tower bar brackets;
(5) Adjust tower bar tension, using adjustment nuts, so that even/equal, yet notable force is exerted outward (i.e. toward each strut tower/strut mount).
(6) Use tower bar jamb nuts to secure tower bar adjustment nuts in place.
You’re done.
Old Dec 30, 2018 | 10:42 AM
Have the car on even ground, loosen and remove the upper strut mount nuts, install the bar, reinstall upper strut mount nuts, torque to 50ft/lbs and call it a day?
Old Jan 20, 2019 | 10:34 PM
i'm cleaning up the used Stillen piece before installation. i'm trying to loosen it's adjustment / lubricate it and WITHOUT breaking it. Is the adjustment nut reverse thread ?
the "adjusting nut" ? did not turn counter-clockwise under moderate force...i put some kroil on it and will come back to it. it was rusty - but not _that_ rusty
the allen key bolts and nuts as delivered seem a) backwards (allen keys should face forward - if only for looks right?) and also b) beat up. What Grade bolt is necessary for replacement ?
what material are the end links made out of? they have mild corrosion on them - whats the best way to clean them up? i was thinking "wire wheel"...
i only staged this photo a little
the nut in question
Old Jan 21, 2019 | 10:29 AM
the term "counter-clockwise" is relative to one's position.....ie bar side vs mounting bracket side. Assuming you turned the nut counter-clockwise relative to the mounting bracket, it should break free. I don't recall those eyelit bolts being reverse threaded. You said you gave it moderate force, it won't hurt anything giving it light to moderate force the other way to see if indeed they are reverse threaded. Have you tried both sides?
I would re-use the allen bolt, just clean it up. How it's mounted is personal preference. I agree with you, the allen head should be pointing towards the front of the car.
Wire-wheeling the brass looking mounting bracket will work, but keep in mind you'll have light scratches remaining. Perhaps start with a buffer wheel.
Old Jan 21, 2019 | 03:32 PM
There isnt an adjustment on the drivers’ side - only on the passenger’s side.
the bar has a threaded hole on the passengers side that the eyelet threads into. Im “looking” down the hole when I say “counterclockwise”.
i did briefly try it clockwise too
i will put the bar in a vise and try again
Old Jan 21, 2019 | 04:11 PM
Slamrod's Avatar
Nut should come off like any nut should, you just need more leverage it sounds like. Why adjust it though if it doesnt need it? Its not like theres a variation in the gap between strut towers with different maximas.
Old Jan 21, 2019 | 04:12 PM
Rather than trying to bust the nut free, why nut try spinnning the whole bracket/eyelet bolt counter-clockwise?
Old Jan 21, 2019 | 07:42 PM
All of them were frozen in place - better to R&R it before putting it on the car.
Once I disassembled the end pieces this was easy, The eyelet and its stop nut are regularly threaded.
Old Jan 21, 2019 | 08:00 PM
i buffed them with a wheel but it didn't do much. i didn't do a wire wheel yet...what are these made of (that they corrode like that) ? Is there a way to chemically treat them - either before or after using a wire wheel ? or no wheel at all ?
thanks for the help...
Old Jan 22, 2019 | 09:32 AM
i had a text chat with stillen, they report:
"Use acetone or brake cleaner and mild-grit sandpaper or other mild metal abrasive to clean the parts. The parts are all simple steel, not copper. They are painted with metal-bonding paint from the factory. Then, spray the sanded product with a brass or gold color of your choice, and it should look good-as-new! That is literally how it is colored from manufacturing."
i wonder what "metal bonding paint" means...it looks like they're supposed to be a color similar to milodon "gold irridated" oil pans but I don't know what's a match...
there's also rust in the channel of the piece that's going to be challenging to remove (without sandblasting it) before paint...
Old Jan 22, 2019 | 06:25 PM
CS_AR's Avatar
Many years ago I had the tower braces powder coated for the Q45. That has worked out well over the years. Also had the aluminum bar polished and sprayed with a clear.
BigJayx23
Apr 23, 2003 03:06 PM
DoGGx23
Feb 8, 2003 09:11 PM
Indecisive311
Dec 26, 2002 07:19 PM
maxperformance
Jul 11, 2002 06:20 PM
duplex
Apr 20, 2001 10:47 AM
