Ebay wheel bearing press
So I just bought one of the 23 piece bearing pressers off ebay. I was able to pull the knuckle and pres out the old bearing and install a new bearing+hub in about an hour. The local machinest would charge me $70 per knuckle so this really paid for itself. Just letting you 4th gen guys know if you already didn't know about it. Here is a link:
https://www.ebay.com/itm/23-pcs-FWD-...9PwN:rk:1:pf:0
If y'all YouTube 04 max wheel bearing replace I saw someone own a bearing with Hammers and blocks of wood only. I used this method and it took a few hours but only because my cheap *** didn't think of using a body washer right away as a flange to help get the bearing in. 1/2 in drive electrici impact wrench how me straight it ito once so I didn't gotta back n it out when it started looking offset. Outter race was about 3 inches diameter. Use normal sockets as cups or punches..
Penetrating oil and patience. Slowly slowly pried it up bit by bit and clean and Brush the area before and during to keep grit away. I have 200k miles with original sensors .
I feel I have more control with the screw press vs the hydraulic. I do not have ABS, so that there was a bit of a time saver. With this tool you can press the bearing, press the hub, and even the seals. The only thing is the hub removal must be done with other methods, but my hub just sorta fell out lol.
Kenji Shinomori
May 27, 2019 01:58 PM
220k+ A32
25
Oct 3, 2015 09:09 PM
maxinout93
Jun 28, 2012 06:15 PM
