Need Help!
Old Jan 11, 2019 | 06:32 PM
Kirk Lewis's Avatar
Need Help!
I have a 1993 Gxe that i purchased about 4 yrs ago, I'm having a problem with the (Shift Pattern Select Switch) which is located near the gear shifter inside the vehicle. The problem is that the light doesn't come on for a few seconds when i start the vehicle, when this happens, the transmission seems to be stuck in 1st gear and does not change gears once driven. Does anyone know what may be the problem/fix for this issue?
Old Jan 14, 2019 | 08:36 PM
chrome91's Avatar
which light isnt coming on? if i remember right by the shifter its just a plastic orange tab for the shifter not a light
Old Jan 14, 2019 | 09:44 PM
Kirk Lewis's Avatar
Yes, that’s the light.
Yes! That is the correct light.
Old Jan 15, 2019 | 01:50 PM
chrome91's Avatar
hmm i had a similar problem years ago where mine wouldnt start, it ended up being the shifter bushing under the car. its like $2 from Nissan and takes 5 minutes to install under a heat shield under the car, my shifter wouldnt go into park fully and it caused no cranks
so is it permanently in first gear or can you get into park and reverse?
Old Jan 27, 2019 | 10:10 AM
Tiniform's Avatar
I hate to say it, but these cars are never reliable until you do a manual swap. Of course someone will say this is not a fair statement since these cars are all well over 20 yrs but they will run for many more years with the manual swap. I am getting ready to do my 5th swap.
Old Jan 29, 2019 | 10:36 PM
nismax1994's Avatar
That's awesome, I wish I knew someone in my area who could do the swap on mine.
Old Feb 2, 2019 | 11:12 AM
chrome91's Avatar
the problem was the auto trans in GXE was made for 4 cylinder engines, doing stupid stuff like shift R-D and D-R while moving, launches, etc with them they wore out quickly. if you did alot of highway driving with them and took care of them, they could last. mine went to 430,000km only going through a shifter bushing before 1st started slipping
maxi91
Nov 3, 2013 01:30 PM
Amillyon
Feb 2, 2011 07:15 AM
92SEftw
Dec 2, 2010 07:57 AM
josmicru
Dec 8, 2009 05:47 PM
Craig Mack
Aug 24, 2002 12:08 PM
