99 max se no start problem
Old Jul 5, 2019 | 01:04 PM
nissan99's Avatar
Well here goes kind of trying to figure it out .. at first I had no power to the dash no lights nothing so know I check all fuse good so since the positive cable is original I wiggle it and guess what got power and cranks strong but car still won’t start ... so when I put the key in and listen for the pump to turn on I hear nothing ? Check the pump fuse it’s good .. so I’m kind leaning toward a fuel pump gone out I mean it’s the original pump .. the immobile light does flash when put the key in it is not solid on the dash ... the car runs like a rape ape when running .. well I think it immobilize NATS security red light is solid trying to crank it ..ok also when I try to hook up my scanner to read codes it tells me link error.. will NATS cause it not to read the computer ?
Old Jul 5, 2019 | 03:09 PM
DennisMik's Avatar
There is probably nothing wrong with your fuel pump. If the red security light is on solid when you are trying to start the engine, you are immobilized. When the car is immobilized, NATS turns off the fuel.
Old Jul 5, 2019 | 03:52 PM
nissan99's Avatar
Ok that’s what I’m figuring and only have one original key and I try to read the any codes and it comes back link error will NATS cause that not to read the computer
Old Jul 5, 2019 | 06:15 PM
nissan99's Avatar
Would anybody know why I can’t read if codes ? It tell me there is a link error ? Does NATS shut the computer off to read codes too ?
Old Jul 5, 2019 | 07:44 PM
nissan99's Avatar
Ok guys I fix my problem .. before I wiggled the positive cable I was in the fuse box pulling fuse so what happen was I went over then and I put the signal starter fuse in the wrong spot and cause no start just crank and could not connect to Ecu ..so when I put the fuse in start signal the car started right up. So how hard is it to replace the positive battery cable ?
WTF?
23
Nov 29, 2021 03:31 PM
maxima4826
Jul 5, 2016 04:10 AM
xmastanax
18
Nov 6, 2012 11:38 PM
grey99max
1/4 and 1/8 Mile Racing
Sep 9, 2006 06:06 PM
Roo
22
Oct 7, 2004 09:44 AM
