Missing vacuum line and SES light
Old Dec 21, 2019 | 09:18 AM
1999i30t's Avatar
I found this missing vacuum line or open line. Where does it go?? I’ve googled diagrams and can’t decider. Also, I have a p0138 bank 1 o2 sensor 2. With a mild miss at idle.
do I replace the sensor, or is it coil related or possible vacuum leak?
the photos uploaded upside down, but you can see the vacuum line that is open is clipped to the air box from the valve cover (my guess PCV)
Old Dec 21, 2019 | 09:22 AM
1999i30t's Avatar
It’s an Infiniti i30t by the way. 1999
Old Dec 21, 2019 | 12:14 PM
JvG's Avatar
JvG
That looks like the vent hose from the transmission. If so, it s meant to mount that way.
I haveven a 5 speed, so mine looks different.
Old Dec 21, 2019 | 12:20 PM
JvG's Avatar
JvG
You have an oxygen sensor issue.
Do a search on you tube, like I just did.
1999 Maxima P-0138 code.
Old Dec 22, 2019 | 08:26 AM
Jason Chrest's Avatar
With all the tracking I’ve done on mine - I can say definitively that is the transmission vent tube as JVG mentioned. It’s supposed to be exactly where it is without any connections
Old Dec 26, 2019 | 12:56 PM
1999i30t's Avatar
Thanks everyone!! It looked like it was meant to be that way! But I wanted to confirm!!
now I have a bank 1 sensor 2 O2 sensor code
Old Dec 26, 2019 | 01:13 PM
JvG's Avatar
JvG
you might want to look for the oxygen sensor fuse in the fuse panel under the dashboard. Clean off any oxidation, or replace the fuse. I've had false positive oxy sensor codes. I replaced the indicated oxygen sensors on both sides, but till had codes. Until I cleaned the fuse.
should you still have the code after dealing with the fuse, you probably really do have a bad oxy senser.
Your fuel mileage and performance should increase once both upstream sensors have been replaced. It's worth the expense.
Old Jan 2, 2020 | 07:27 PM
1999i30t's Avatar
its throwing bank 1 and 2 sensor 2 now lol. Think I’m gonna park it and order new o2 sensors and clean throttle body and new spark plugs. Go from there
Old Jan 5, 2020 | 01:47 PM
JvG's Avatar
JvG
Good call.
Old Jan 5, 2020 | 02:04 PM
Be sure to NGK spark plugs. Either the OEM plats or copper will suffice.
Old Sep 4, 2020 | 05:14 PM
1999i30t's Avatar
I can’t get the egr tube off. There is another tube in the way!!!
Old Sep 5, 2020 | 09:52 AM
JvG's Avatar
JvG
post a photo of what you are talking about.
are you removing the upper intake manifold now?
What is your reason for this task.
A32fanatic
Jul 16, 2019 10:39 PM
NSMO240
Jun 22, 2014 07:15 PM
Brl24
Apr 30, 2013 11:39 AM
MaXtUneD
Nov 29, 2005 02:13 PM
Ramius83
Nov 7, 2003 09:59 PM
