What's possible to fix camber and toe?
Old Oct 27, 2020 | 06:41 AM
marktab's Avatar
I continue to invest regular maintenance in my Maxima: and today want to ask what is possible to fix camber and toe.
  • Over time: I have run over curbs and hit curbs. There have been no major accidents.
  • Recent work: Changing steering rack, tie rod arms, front suspension parts
  • Comment from one mechanic: back end looks like it's riding low, maybe fixed with new struts (though the struts are working -- changed a long time ago, and front end was about 2 years ago)
I'm adding my alignment results from October 20. Perhaps the numbers are not concerning, but I'm open to ideas -- thanks
Alignment results from October 20
Old Oct 27, 2020 | 07:33 AM
RA030726's Avatar
I'm nutty for Nissans
Let's pretend all of your control arms, bushings, bearings, springs, and struts are perfect.
The front has a tiny amount of play at the 2 bolts joining the knuckle to the strut. You can install camber bolts to get more adjustment.
The rear has no adjustment. You would have to bend the beam or replace it.
Old Oct 27, 2020 | 09:06 AM
Turbobink's Avatar
There is no camber adjustment possible in the 4th Gen ... just other worn parts that result in off-spec. camber.
Old Oct 27, 2020 | 11:37 AM
RA030726's Avatar
Seriously? Yes you can adjust it with different bolts.
https://www.rockauto.com/en/catalog/...bolt+kit,13512
Also you can get caster bushings and even camber plates to adjust even further.
Old Oct 27, 2020 | 01:23 PM
Turbobink's Avatar
^^^ that’s right out of the FSM.
Old Oct 27, 2020 | 08:45 PM
marktab's Avatar
Thanks @Turbobink and @JSutter : I agree that factory does not allow adjustment. I have the factory manual (I paid for mine back in the day, but I think people can find it all online for free).
I checked out a video about changing this bolt to see what's involved. I think my path will be work with my regular mechanic to see if he will do it. It looks like I would need four of them, two for each side. I've been a Rock Auto customer, but I'm leaning toward still having the mechanic do it. My alignment package is life, so I can just go back for that to be done again.
Now on the back side -- I agree about little can be done there. But I'm thinking about having those old (certainly over 15 years old) struts evaluated, and maybe that would help it all work better.
Old Oct 27, 2020 | 08:59 PM
RA030726's Avatar
Yes, I know the holy grail of info. I have read mine cover to cover. But it won't talk about aftermarket parts or fixes.
Old Oct 27, 2020 | 09:05 PM
RA030726's Avatar
At each wheel, replacing one bolt will do +/- 1.75 degrees, two will do +/- 2.5 degrees.
boondoxmax
19
Oct 20, 2008 04:49 PM
95bluse
Jul 24, 2006 01:36 PM
samsonite
Jan 31, 2005 11:56 AM
mymaxlvsattn
Apr 11, 2004 02:38 PM
Flutie7NFL
Apr 18, 2002 03:11 PM
