Help!! After changing ignition switch car won't start
Old Aug 19, 2021 | 05:32 PM
whitakerbrandy32's Avatar
I have a 95 Nissan Maxima and I recently replaced the ignition switch assembly and now my car will not start it will go to the on position all the lights will light up but then it won't do anything. I don't know what I'm doing wrong. The person I bought the car from had a lawn mower ignition because someone tried to steal it. But I could not get my breathalyzer hooked up to it because you could unplug it and the car was still crank apparently, so I bought a new ignition switch had installed now it won't work. I've heard it's the security system and that it needs to be reprogrammed to the new key? I was hoping that this site could give me the answer that I need because I have a two-year-old and I really need my car
Old Aug 20, 2021 | 03:53 AM
Turbobink's Avatar
Originally Posted by whitakerbrandy32
... The person I bought the car from had a lawn mower ignition because someone tried to steal it. But I could not get my breathalyzer hooked up to it because you could unplug it and the car was still crank apparently ...
Wait ... what?
Lawn mower ignition?
Breathalyzer?
Old Aug 20, 2021 | 06:58 AM
RA030726's Avatar
I'm nutty for Nissans
If the security system was triggered the lights would be flashing and the horn would be honking. To disarm, unlock the car with the key in door.
Otherwise your ignition switch or wiring is bad. Download the factory service manual at nico club forum and check the wiring.
Old Aug 20, 2021 | 12:35 PM
DBear's Avatar
It's been a while since this subject has come up, but whenever all the dash lights come on and the engine won't crank, I think "slop." Take a look at this thread: https://maxima.org/forums/4th-genera...tion-slop.html
Old Aug 21, 2021 | 10:26 AM
Bnwhitaker32's Avatar
Wait ... what?
Breathalyzer?
Yea that's what the dummy I bought car from was using and I had a DUI 10 years ago so therefore I have to have a blow and go
Old Aug 21, 2021 | 04:24 PM
Thats just it I don't have the original key 🤯
Old Aug 22, 2021 | 12:53 PM
JvG's Avatar
JvG
you don't need the original key. It's nothing special.
you just need a key which will turn the door lock and ignition.
i
Old Aug 23, 2021 | 01:10 PM
i
I tried the key that came with the new ignition switch assembly and it wouldn't turn .. idk what to do.. it'll crank by touching a wire to the starter and the battery terminal but I'm scared to do that and there again I won't be able to hook up the breathalyzer
Old Aug 23, 2021 | 09:33 PM
JvG's Avatar
JvG
Turn the steering wheel slightly in either direction while you attempt to turn the key. That will relieve the binding which keeps the key from turning
Dan21
Jan 11, 2016 12:16 PM
Ahmad_1290
Aug 12, 2008 01:08 PM
gassian
Jul 2, 2006 09:49 AM
venturous
Apr 8, 2006 09:48 PM
