2k2 shifter: too tall?
i was looking at a picture the inside of my car and it occured to me that the shifter is really tall. anyone else agree? i may consider cutting it but i dont know what this entails.
first off, SHOULD i cut it? 2nd, what steps do i take to do this? how much should i cut? how do i make sure the shift **** will screw back on?
its huge.
its huge.
Naw. Install a Short Throw Shifter instead. You'll be glad you did, especially if the 2K2 is still plagued by the elbow-into-the-arm-rest-release problem.
Originally posted by Newman96SE
but that wouldnt reduce the hight of the shifter at all, would it? a short shifter is definitely coming sooner or later but right now im just talking about how it looks.
If you cut the stock shifter, you'll probably have to install an aftermarket shift ****. Either that or you'll have to remove the shifter and take it to a machine shop to be re-threaded.
Remember, the 2k2 6 speed tranny is cable acuated. The 95-01 have linkage acuation. This is why the 95-01 have EXCELLENT feel compared to the crap feel of the 2k2. The 95-01 STS WILL NOT work with the 2k2. You're only option is to cut the shifter or wait till a STS comes out. If you cut the shifter, you will either have to get an aftermarket shift **** or glue on the stock **** because you will have to cut the threads. Shortening the throw always results in more notchiness because you are changing the leverage therefore you end up putting more stress on the syncros.
Dave
Dave
shifter
Dave
Dave
Re: 2k2 shifter: too tall?
its huge.
its huge.
Originally posted by see5
The 02 shifter works well except in the very cold temps. I would recommend Redline, had great results in the past.. I will get it done this Spring.
Thanks, I was wanting to change it out now but I remember hearing that you weren't supposed to till like 30k miles. Oh well, I'm assuming auto-zone or the sort would carry it?
Also about chopping the stick, can we do that with our reverse lockout there? I looked at it briefly when I first got it and it seems like we'd have to get a whole new unit.
TallTom
57
Oct 14, 2025 05:16 PM
AdamK
Jul 31, 2001 05:58 PM
DA-MAX
Feb 3, 2001 06:44 PM
