Emergency
Old May 18, 2002 | 11:46 AM
melteye's Avatar
Emergency
I need to know the size and type of nut used on the ball-joint of the Lower Control Arm. Anyone with a manual, this would be greatly appreciated. Either post, email, or message melteye (aim)
Old May 18, 2002 | 11:56 AM
melteye's Avatar
Anyone with a 2002 Manual?
Old May 18, 2002 | 12:28 PM
melteye's Avatar
Got a part number on it... 0122500581.
I need something at least temp to see if this is going to work. Where would I find the size I need?
Old May 18, 2002 | 12:45 PM
97GLE's Avatar
Your dealership should know.
Sorry I can't help more. That will be the best place to get it though.
I purchased all the nuts and bolts I've needed for my suspension at the dealer. Cost is usually pocket change.
Old May 18, 2002 | 02:08 PM
studman's Avatar
I have the ESM, but all I can find is this....
24-29 (2.4-3.0, 18-21)
Key = N-m (kg-m, ft-lb)
^^^ That's listed on a breakdown of the steering wheel and steering column page ST-12 in the manual. Those only appear to be the tightening settings, etc. Nothing listed as to the part number (which you already have) or what size wrench/socket to use.
Sorry I can't be of more help.
Old May 18, 2002 | 02:18 PM
studman's Avatar
Wait a sec... may have found some more... Page ST-3
http://www.webslapper.com/balljoint.bmp
http://www.webslapper.com/steering.bmp
Maybe that will help. I didn't want to convert them to jpg/gif due to time constraints, so right-click on them and choose save as. Then open with MS Paint or some other photo editor.
Old May 18, 2002 | 04:14 PM
see5's Avatar
Not an emergency!!
Old May 18, 2002 | 04:27 PM
2k2Merlot's Avatar
Well if your car's in pieces and you need it to get around, I think it would qualify as an emergency.
Originally posted by see5
Not an emergency!!
Old May 18, 2002 | 05:54 PM
97GLE's Avatar
He's talking about the ball joint on the Lower Control Arm...
But seriously, go to the dealership. A crushed control arm is very common on many cars. Someone in service will be able to tell you.
Old May 18, 2002 | 08:15 PM
melteye's Avatar
14mm. I used one temporarily and am ordering one today.
I replaced the Lower Control Arm ($150) and put everything back together and lowered the car and the camber is still screwed up.. (Camber is when its at an angle when looking from front of car right?) so only half the tire is making contact with the road.
There is 3 more possibilities. Bent Hub/Bearing (I Doubt), Spindle, or Strut. The strut visibly looks fine, so does the Hub... I will be ordering the Hub+Bearing+Seal+Spindle just in case, have to wait for Dave to go back to work to get price and have them overnighted again. If the strut is damaged I will get coilovers.
What else could it be?
ZIPPIN
18
Jan 13, 2002 07:07 PM
ZIPPIN
Jan 6, 2002 09:56 PM
NJ_MAX2000
Nov 3, 2001 03:28 PM
shumax
Jul 10, 2001 08:33 AM
Rit
Jun 6, 2001 08:55 AM
