Knocked .839 sec off my ET
Old Jun 1, 2003 | 09:25 PM
elchino's Avatar
Does that sound right for a 50 shot of NX? Unfortunately I only went from 15.390 to 14.470 in my 02 6spd. I think a lot of it had to do with the heat.
Anyhoo, I've also dynoed at 247hp and 287tq (different day different place). Again, decent numbers?
Old Jun 2, 2003 | 05:50 AM
Jime's Avatar
Re: Knocked .839 sec off my ET
Yesterday mine went from 14.8 to 13.3 with a 35 shot. However mine's auto and I spray from start to finish.
Spray should help you with the heat because it cools it down.
Last weekend I ran a 15.4 N/A and a 15.1 on a 35 shot with street tires so traction is a BIG issue.
Old Jun 2, 2003 | 07:42 AM
DCmax's Avatar
I think traction is everything. Yesterday I was running 14.4 @ 102 with 2.4X 60 fts. I don't know what the problem was, my usual 60 fts are 2.2X. There did happen to be 40 mph wind gusts but still. I didn't feel like I was spinning at the beginning it just felt like I wasn't going anywhere. I need to get slicks.
Maybe it's the track. I usually don't go to this one but it's supposedly better. I did however drop a second off my times from pretty much the same time last year. This is after adding 85 Shot NOS, spraying at the very end of 1st, then 2nd and 3rd.
Old Jun 2, 2003 | 01:36 PM
CBass69187's Avatar
n2o
Get some real sticky drag radials or slicks and you should hit 13's.
Old Jun 4, 2003 | 04:17 AM
Blu's Avatar
Blu
the tits
what where your trap speeds before and after. Also what other mods do you have to the max?
Old Jun 4, 2003 | 03:24 PM
BJJ's Avatar
BJJ
What were your traps, you dyno'd similar to what I did with my 85-shot and I am running 13.9@104 with crappy 2.3-2.4 60' times. I would think you would be alot faster than that, also are you spraying in 1st, if your not you should be your times will go down I promise.
Old Jun 4, 2003 | 05:57 PM
elchino's Avatar
spraying 2.336 60ft 78.6MPH trap
N.A. 2.403 60ft 72.7MPH trap
Spraying in first almost at the get go (still got some wheel hop though).
Old Jun 4, 2003 | 06:01 PM
Blu's Avatar
Blu
the tits
78 thats got to be 1/8 mile. what were ur traps on the 15.3 and 14.4 run. Also whats the elevation of ur track?
Old Jun 7, 2003 | 09:16 AM
elchino's Avatar
Ok I guess I don't know what trap speed is: a little help. If it's at the end of the quarter mile then: 15.3 @ 92MPH and 14.4 @101MPH.
The track elevation isn't too terribly high. I would think less than a thousand feet, but I couldn't find any information on it.
Old Jun 7, 2003 | 12:18 PM
KiLLeR2002se's Avatar
Eat Naaawwwzzzzz
thats what it is, the speed you crossed the line at
DC_Juggernaut
Sep 28, 2015 04:07 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
