Leaking lines or normal?
Old Jun 13, 2003 | 08:24 AM
eddymax's Avatar
When i turned off my nitrous bottle say at 6pm the pressure was at 900psi and the next day at 11am I looked at the pressure in the line was only at 350psi, given the bottle pressure was only 650 now but is this normal or are my lines leaking?,thanks
Old Jun 13, 2003 | 09:28 AM
Jime's Avatar
Re: Leaking lines or normal?
Eddy mine does that too, I wouldn't lose any sleep over it. If it dropped to 0 in less than an hour or so I would look for a leak.
Relax and have a cold one.
Old Jun 13, 2003 | 01:07 PM
xHypex's Avatar
For reference I looked at my bottle pressure the other day in the morning and it was 850psi. Late in the day it went up to 1050 psi, and dropped back to 800psi the next morning. PV = nRT
-hype
Old Jun 18, 2003 | 09:14 PM
SmoothMax's Avatar
OG
Mine does the same thing; rises and falls. Keep in mind, your lines aren't meant to be a storage place for high pressures, just a pathway from point a to b. Eventually it will find a way out. Is it something to be worried about...no, it's normal. Like Jime said, if it starts leakin out at a noticable rate, then you'd better investigate. Or get a purge valve.
Old Sep 7, 2003 | 04:14 PM
teejnut's Avatar
If I can hear a hissing around where the fittings are then thats NOT normal, right? What can I do if there's leaking where a fitting is?
Old Sep 7, 2003 | 10:15 PM
CalsonicSE's Avatar
Hissing from the fittings is definitely not normal. Depending on where the hissing is coming from, you can either reseal the connection with teflon paste or get a new teflon washer (for the bottle nut connection). Remember, do not use any kind of thread sealant on -AN connections.
Mar 12, 2020 12:06 AM
captchaos
Mar 15, 2016 12:18 PM
RWCreative
Sep 21, 2015 11:01 AM
followthadollar
Sep 17, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
