NX tread sealant?
Old Sep 25, 2003 | 10:45 PM
Nismo's Avatar
NX tread sealant?
NX has this sealant fro the threads of the connectors? is it something special or can I use regular thread lock on the connectors? or do I have to get that same stuff?
Old Sep 26, 2003 | 04:16 AM
Jime's Avatar
Thread sealant and thread lockers are two different products.
Thread lockers just keep bolts, screws etc from coming loose.
Thread sealants are to prevent leakage. Permatex has a variety of each not sure about Locktite.
Get one that will withstand the pressure and product, they will usually list on the container. I would tell you what I use but I don't know the name, it was given to me and there is no label but it was designed for up to 5000 psi and doesn't set for about 4 or 5 hours so you can change your mind.
Just don't use teflon tape.
Old Oct 2, 2003 | 11:05 AM
1MAX2NV's Avatar
Best teflon sealant are the paste type. The permatex one didn't work for me. I used teflon paste that came in the jar that you can pick up at homedepot.
Old Oct 2, 2003 | 01:49 PM
Nismo's Avatar
aww, and I just bought the permatex stuff. guess Ill have to buy the paste then.
Old Oct 2, 2003 | 02:08 PM
Jime's Avatar
Permatex works fine as long as you get the thread sealant not the thread locker. Major difference between the two.
Old Oct 2, 2003 | 09:11 PM
Nismo's Avatar
lol, now i have both, permatex 14 and teflon paste. ok well Ill experiment with both
twotonezed
Aug 16, 2015 11:41 AM
j_bryan
Oct 12, 2001 08:29 AM
Hypersion
Feb 20, 2001 06:39 AM
petemoe
Jan 28, 2001 05:52 PM
