nitrous questions -- non max :)
Old Apr 6, 2007 | 05:27 PM
viguera's Avatar
Sorry to bring up the G, but a) I don't have the Max anymore and b) I trust the info here more than anything anybody says on some other site.
I have a 2007 G sedan. The dual intake and dual throttle bodies should make for an "interesting" challenge when dealing with nitrous. I've been talking privately to a couple of people here, but I don't know if anybody knows for sure how to go about this.
My original idea was to go direct port, which should be the "safest" way and bypasses the issue of the dual intakes altogether. But it's also the most complicated and most expensive.
One of the ideas was to treat it like a regular setup, but split the line into both intakes. So take your standard wet setup, and instead of having one nozzle going to one intake, split that and have two nozzles going to two intakes.
I can already see potential problems with this since I don't think anybody is doing it yet, but that's why I'm posting here.
Suggestions? Comments? Other ideas?
TIA
Old Apr 6, 2007 | 05:33 PM
absoundlab
you can just run a single wet system and then split it into two. you have fuel and nitrous connect them each to a tee and from there send fuel and nitrous to each nozzle in each intake. and if you are spraying a 100 shot half should go to each intake side.
Old Apr 6, 2007 | 05:37 PM
viguera's Avatar
That was one of the ideas. However I don't know if this is all theory or if anybody has actually done this.
Old Apr 6, 2007 | 05:53 PM
Max_Out's Avatar
Under the radar
hummm, tricky. Direct Injection would be your best bet. anything other wouldnt work right. Splitting the line to each intake wouldnt work right, unless you ran a multiple shot into each intake at the same time, But you would have to have tow solenoids set ups two fuel lines, etc...
Old Apr 6, 2007 | 06:17 PM
t6378tp's Avatar
Turbo 3.5
I do not know what it cost for a direct port setup but if it cost too much than I would basicly run a nitrous setup to each tb
for example 1 bottle, 1 supply nitrous line then split the nitrous line to 2 noids 1 for each tb, then run 2 fuel noids 1 for each tb. it will be almost like 2 nitrous setups
Old Apr 6, 2007 | 06:55 PM
viguera's Avatar
See... Different responses from different people.
Old Apr 6, 2007 | 07:25 PM
grey99max's Avatar
LandShark has Cosworth
Too complicated - you need one nitrous and one fuel solenoid, a Y-connector from each one to two fuel lines and two nitrous lines, one each of the lines going to a nozzle at each intake. Jet each nozzle for 1/2 of your intended shot level. When each nozzle is jetted for 35-shot, you will actually spray a 70-shot. Simple, reliable, and consistent. Sounds like fun!
"Those who spray together stay together." Heh.
And yes, I'm serious about the nitrous feeds. It will work.
Old Apr 7, 2007 | 05:43 AM
t6378tp's Avatar
Turbo 3.5
your correct about the setup but I just like the idea of running 4 niods or 2 niods that can handle a big shot that way you do not have to worry about out growing the kit. the only thing that would need to be changed in the future is the supply line and he could do that from the start
like you said do it right the 1st time, people alway said I am only going to do a 55 shot then a month later they running 75-100
Old Apr 7, 2007 | 06:14 AM
grey99max's Avatar
Sure - but think about this for a moment - if you use two pairs of solenoids, and something fails on one pair, then you will be spraying full-bore on one side and nothing on the other side. That can't be good for your engine.
A single pair of solenoids can supply more "shot" than you'll use on that engine. Heck, you can buy solenoids good for a 400-shot delivery! You'll be safer with a new pair of solenoids controlled by one relay. IMHO.
And yes, do all your trunk nitrous installations with a 6AN "race hose" from NX. It's the last one you will need to buy. The factory "soda straw" hose is about as worthless as the NX fuel tee they ship with kits.
Also use only 4AN-3AN lines to the nozzle. This way, the inside diameter on the line is larger than a 3AN-3AN nozzle line. I have an assortment I bought just to check that out.
"It's always something"
Old Apr 7, 2007 | 07:08 AM
viguera's Avatar
That's what I was thinking too... running 100 shot to 3 cylinders and 0 to the other side would "probably suck"
Looks like I need a shopping list now...
Old Apr 7, 2007 | 08:05 PM
Tatanko's Avatar
Bacon Lover
Aren't there kits specifically for dual-intake cars?
For example:
http://www.nitrousexpress.com/Pages/20616.htm
Take that concept, apply it to what you've got. You could buy similar pieces to make up your own setup if need be, or even buy generic fittings that do the same thing.
matts95max
Apr 23, 2025 10:44 AM
The Frye
Sep 2, 2021 11:03 AM
MaxLife17
Jun 27, 2019 01:37 PM
MaxLife17
Sep 8, 2015 02:36 PM
Johnny9595
Sep 3, 2015 05:18 AM
