Engine covers
Old Aug 14, 2018 | 11:45 AM
Engine covers
so I snapped the head off the bolt that holds the undercover to the car.
this was back in 14' I did this.
I guess I could drill it out and put a plastic push pin in? What are my options?
Old Aug 14, 2018 | 12:26 PM
Drill that sucker out. Start with a small bit and work your way up, but stop short of full size so that the threads won't get damaged. Once you drill it and get through 85% to 90% of the diameter, it will disintegrate and fall out. Or it will be so weak that you could hit it with heat or some WD-40 and it will no longer be stuck and will un-thread itself.
Old Aug 14, 2018 | 02:28 PM
Thanks what your explaining is exactly what I tried to do around the other side.
But it never came out as planned. I wound up shearing off the threads flush and now left with just an 8mm hole. 8mm I think is what it is.
I primed the the steel so it wont rust after replacin the W/P.
Could I just get away with a push pin? I think the pins with the phillips head drive located within the wheel wells will snap in.
Old Aug 14, 2018 | 03:08 PM
95naSTA's Avatar
You could always use rivet nuts.
Old Aug 14, 2018 | 05:46 PM
Sure, one of those push pins would probably do the job. Or you can drill it out completely, and re-thread to the next size up using a cheap tap and die set from Harbor Freight.
Old Aug 14, 2018 | 08:45 PM
I use zip ties ,if done right it looks good.
Old Aug 15, 2018 | 09:53 AM
Heres the other side. I sheared off the threaded nut welded on with a dremel.
Yesterday I put a plastic push pin in the hole. Done deal.
Violator
Mar 4, 2017 09:24 AM
maximaxi
Sep 25, 2016 06:22 AM
LongoTE
Garage and Workshop
Mar 15, 2013 04:33 PM
lskiat
Jan 10, 2013 07:59 PM
JaKillz2
17
Apr 15, 2006 08:34 AM
