Boost gremlins
Old Dec 3, 2002 | 10:02 AM
Jer's Avatar
Jer
Boost gremlins
Hi guys,
I've got two concerns I'm hoping someone can help me address... I'm no genious in this field – it’s just a hobby, so any input would be appreciated
My setup :
V2 supercharger, 3.33” pulley, A/F gauge (REALLY wish I had gotten an EGT which will go in ASAP), 6:1 FMU disc, NGK BKR6E copper plugs gapped at 0.039.
The two problems :
- The plugs have about 10k miles on them, and they are in as good as new condition : I should be seeing more deposits on them I think... I'm worried that I'm running lean/overheating them... or do our cars never foul plugs and am I worrying about nothing?
- Car runs unevenly on a cold start; only when around 1100-1300rpm though and only when it's colder out.. if keep around those rpms in gear the car surges - sort of like in limp-home mode. Once the engine warms, that goes away.
The plugs are what I’m worried about most. I’ve entertained a few possibilities; I realize some may be far-fetched, but I’m trying to come up with anything to make me feel better. The first thing that crossed my mind is that the mixture is leaned out most of the time anyways, except for when running boost or when at WOT. My discount A/F ratio gauge usually shows me running lean.. do I just need to give them more time before worrying? How do your plugs look under “proper” conditions at around 9-10k?
A few other things that came to mind.. colder air = greater air density, and I am always running 94 octane... both factors can cause more heat (gotta love that 10% ethanol content in Sunoco 94 – I heard it also makes a great agent in cleaning deposits). Maybe I’m not running lean after all?
I’m hitting myself for not getting an EGT gauge, but I have to settle for the A/F ratio for now.. which still tells me I’m running rich - but from what I've read that's more believeable than a lean condiition with my setup. Still.. I don't want to destroy my motor just yet... I’ll have to get the EGT if I want to start toying with the S-AFC down the road..
With regards to the cold-start problem; I’ve scoured for vacuum leaks and found a small rip which has been fixed by a replaced line.. but that only did me psychological good Maybe colder NGK plugs hate Canadian climates? Perhaps I should lend my car to someone who lives in a warmer area until things shape up around here...
Old Dec 4, 2002 | 10:36 AM
funnylittlman's Avatar
how many miles on the car?
Any tune ups forseeable? (like a 30, 60K'er?)
Old Dec 4, 2002 | 09:24 PM
Jer's Avatar
Jer
About 55k miles (I'm in kilometers ). Not sure about the maintenance book, but all my fluids are fine, and the fuel pump won't be coughing up any hairballs anytime soon
Old Dec 5, 2002 | 06:15 AM
This is just an idea, but it worked on another car of mine.
Check/change the PCV valve. I had a camry before, and the valve was getting old (via 60K miles) and I replaced it. She suprisinly smoothened up.
Just a suggestion, don't know if it will cure anything.
Old Dec 9, 2002 | 06:55 AM
Jer's Avatar
Jer
The idea came to me but I didn't look at it.. heck here's something to do next weekend!
Old Dec 9, 2002 | 12:05 PM
PCGuRu2K's Avatar
I'm getting about 11psi of vacuum at idle.. Does that sound right or do I have a leak somewhere?
Old Dec 9, 2002 | 12:10 PM
PCGuRu2K's Avatar
Old Dec 9, 2002 | 12:53 PM
RBa's Avatar
RBa
hmmmm... How do u know when there is a leak??
Old Dec 9, 2002 | 01:16 PM
PCGuRu2K I'm getting about 11psi of vacuum at idle.. Does that sound right or do I have a leak somewhere?
I read somewhere that is low. Possible leak
JER
Jer, BenBlanco was running lean, and he used some fuel injector cleaner at fillup. He says that he has not had a CEL all week so far. PM him. Great guy and willing to help you out. Sorry I can't help more.
-fnny
Old Dec 9, 2002 | 02:31 PM
SuDZ's Avatar
Isnt 18 about normal?
SuDZ
Old Dec 9, 2002 | 04:28 PM
PCGuRu2K's Avatar
SuDZ
I thought 19-21 was normal.. Hmmm. I gotta check my wires over the weekend..May sure all my t-taps are nice and snug.. Any suggestions on what I should be checking first?
Old Dec 10, 2002 | 09:17 AM
Try the T Tap for the boost gauge. BOV, and actual plumbing while your at it
Old Dec 11, 2002 | 12:18 PM
Jer's Avatar
Jer
And if all else fails, try another boost gauge!
Thanks for the injector advice... maybe I will go for an injector flush... I've got quite a few km's on the car so it can't hurt - before I installed the s/c I usually filled on Esso which has the highest lead/crap content around here I sorta figured the ethanol content in the 94 octane that I fill up on would clean them out.. feh we shall see!
Old Dec 11, 2002 | 12:22 PM
BlackCat's Avatar
RIP '98 Maxima SE
Say, Jer...what brand and style of gauges do you have?
Old Dec 12, 2002 | 06:07 AM
PCGuRu2K's Avatar
What's the most accurate Boost gauge to get out there?
Old Dec 12, 2002 | 11:41 AM
Stephen Max's Avatar
11 psi is good vacuum. Normal vacuum at idle is 18-22 inches of Hg, which converts to ~9-11 psi. Now, are you sure your vacuum gauge is calibrated in psi and not inches of Hg?
Old Dec 12, 2002 | 12:12 PM
Old Dec 12, 2002 | 12:53 PM
PCGuRu2K's Avatar
Originally posted by Stephen Max
11 psi is good vacuum. Normal vacuum at idle is 18-22 inches of water, which converts to ~9-11 psi. Now, are you sure your vacuum gauge is calibrated in psi and not inches of H20?
I'm positive.. It's the cobalt series boost gauge.. It's in PSI.. So then what I'm getting is normal?
Old Dec 12, 2002 | 01:33 PM
11 psi is quite normal, even better than what most people are getting.
Old Dec 12, 2002 | 02:57 PM
Jer's Avatar
Jer
Autometer Phantoms; I got the Boost, A/F and Trannie Temp... picking up the EGT and Fuel pressure; I doubt I can fit 5 gauges so the A/F will hafta go
Stephen : 11psi is normal? How come we usually see 20 on idle!?
PCGuru : Cobalt gauges are sweet looking! When I was ordering my S/C they had just made the initial run and then delayed the next batch for 1.5-2 months I wanted them soooo badly
Old Dec 13, 2002 | 06:22 AM
Yes, 11 psi is normal. So is 20 inches of Hg. 20 psi of vacuum is not possible.
Old Dec 13, 2002 | 10:28 AM
Jer's Avatar
Jer
Hmm, oops I am a moron.
Forgot that everything before the zero is not measured in psi but rather Hg/something-something
Yes, 11 psi is normal. So is 20 inches of H20. 20 psi of vacuum is not possible.
Old Dec 13, 2002 | 10:41 AM
You're right it is inches of Hg, not inches of H20 like I stated (I edited my posts). Basically, atmospheric pressure (14.7 psi) is able to support a column of mercury roughly 29.9 inches high. Somewhere in dim ages past, vacuum came to be measured in inches (millimeters) of Hg, even though positive pressure is measured in psi (or Pascals). The result today is boost gauges with two scales depending on if the pressure is + or -.
Old Dec 13, 2002 | 05:36 PM
PCGuRu2K's Avatar
So then I should be showing 20 HG?
Old Dec 13, 2002 | 07:43 PM
Yes, but didn't you say your gauge is in psi? If so, then 11 psi is a good vacuum at idle. 11 inches Hg is waaaay low, indicative of a vacuum leak. Do you have a link to a picture of your gauge?
Old Dec 13, 2002 | 11:18 PM
PCGuRu2K's Avatar
It's the Autometer Cobalt. Right under where it says Vacuum I see "in HG". And then for boost I see PSI.
Old Dec 16, 2002 | 05:51 AM
Okay, now we're getting somewhere. You are getting 11" Hg of vaccum at idle. That's too low, 18-22" Hg is normal. You've got a vacuum leak.
Old Dec 16, 2002 | 09:25 AM
PCGuRu2K's Avatar
Yeah I figured that.... It's too freakin cold though to go outside and check
Old Dec 17, 2002 | 10:06 PM
iansw's Avatar
When you guys say "At idle", so you mean in gear or Park/Nuetral.
I'm 15 in P, 12 in D. (Hg)
I've removed my manifold and re-sealed it with new gaskets several times (and RTV) - replaced every hose in the vacuum system, done a compressions test (which looked great), and tried 4 different gauges - all with the same results.
I gave up about 6 months ago.
Old Dec 17, 2002 | 10:23 PM
2k1i30's Avatar
PcGuRu, i just noticed in ur sig that you ran the 1/4 in 14.9?!?! and ur SCed with 297 FWHP? I was seriously considering supercharging my i30 but i was expecting to see a little bit better results... didnt kev run it in 12.8@112 or some crazy number when he was auto?
Old Dec 18, 2002 | 03:08 AM
PCGuRu2K's Avatar
When I was ran my 14.5 I was only at 245fwhp cuz I was running super rich.. I loss about 55hp that I gained from the afc.. With that gain I'm sure I'll see low 14's possibly high 13's...
Old Dec 18, 2002 | 07:06 AM
At idle means in neutral or park. If you're in drive, then you can expect slightly lower vacuum because the idle speed goes down a bit due to torque convertor drag.
litch
123
Jan 4, 2024 07:01 PM
James92SE
142
Jan 2, 2024 09:23 AM
aw11power
Oct 10, 2021 04:57 AM
MichMaxFan
Sep 30, 2015 09:18 AM
hozay99
Sep 19, 2015 10:20 PM
