supercharger problem
Old Dec 20, 2002 | 06:01 AM
turbomax97's Avatar
I couldn't fix your brakes, so I made your horn louder
The MAF wiring is not long enough to reach the maf, it's about 8 inches or so too short to reach the maf now.. the kit came off a 95-96 car, and i'm not sure how to extend the wiring... help!
P.S. It's a v1, 2nd gen sc.
Old Dec 20, 2002 | 06:45 AM
JAY25's Avatar
Re: supercharger problem
Look at the MAF wiring see all that black stuff that is tape, cut back on the tape and it will make it longer so now you can connect the MAF
Old Dec 20, 2002 | 07:15 AM
delio's Avatar
Re: Re: supercharger problem
Ding sing sing... my man is right on.
Old Dec 20, 2002 | 07:55 AM
Tanman's Avatar
You can also splice the wire and extend it. Just make sure you use the same gauge wiring and that the connections are tight.
Old Dec 20, 2002 | 08:31 AM
turbomax97's Avatar
cool, it looks like we can cut it and it should reach, if not... splicing it is.. thanks guys
Old Dec 20, 2002 | 05:16 PM
MardiGrasMax's Avatar
If you splice use weather tech connectors and be sure its really water tight. Any corosion will scew up the MAF readings and your car will run like crap.
Old Dec 20, 2002 | 09:59 PM
Tanman's Avatar
You can also use soldering\heat-shrink wrap to make solid connections. Takes more time, but looks cleaner, and it's easier to slide a protective flexible hose over them.
Old Dec 21, 2002 | 11:24 PM
96shogunmax's Avatar
Looks oh so familiar!!!!
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
