Can you weld brass to steel?
Old Dec 24, 2002 | 03:12 AM
RBa's Avatar
RBa
I need to weld a brass fitting onto my S/C intake pipe so I can hook up the vaccum hoses for my VI.
Just wanted to know if it was possible to mis brass with steel.
Any chemistry majors wanna offer advice?
Old Dec 24, 2002 | 06:36 AM
MardiGrasMax's Avatar
Re: Can you weld brass to steel?
I have VI and SC, no fitting welding was needed? Can you elaborate?
Old Dec 24, 2002 | 09:25 AM
BlackCat's Avatar
RIP '98 Maxima SE
Brass fitting? Are you hooking up a boost gauge?
Old Dec 24, 2002 | 12:08 PM
RBa's Avatar
RBa
Re: Re: Can you weld brass to steel?
I'm adding a NOS dry kit.
JK
How do you have your VI hooked up?.. Jeff didn't hook mine up when he did my S/C install. I don't have the extra time to go back and he's always busy.
This is the next best and easiest way.
Old Dec 24, 2002 | 01:24 PM
Re: Re: Re: Can you weld brass to steel?
JK
This has been discussed before, search around and see what you can find. If you cant figure it out in a few weeks PM me.
Old Dec 24, 2002 | 01:33 PM
PCGuRu2K's Avatar
JK
I was talking with Jeff today about your VI. He said you can wire it the way I did and it wouldn't be a problem.. I'm gonna do my bov welding on Thurs @ 9am.. Maybe I'll tell him to drill a hole and weld that fitting on since he'll have my pipes off.
Old Dec 27, 2002 | 02:10 PM
RBa's Avatar
RBa
Re: Re: Re: Re: Can you weld brass to steel?
You can use that hole for your breather.. Won't require welding..
Old Dec 27, 2002 | 05:46 PM
PCGuRu2K's Avatar
Re: Re: Re: Re: Re: Can you weld brass to steel?
Jeff ghetto rigged this weld for the vi.. You can peep it next time I see you =)
Old Dec 27, 2002 | 08:54 PM
Engloid's Avatar
NO
You cannot weld brass to steel. You can braze it with the proper silver though. There are nitrous fittings that will allow you to put a nozzle in without welding.
You also need to (if you havn't already) consider that a dry system will put an additional strain on your fuel system. This can cause you to run lean and have MAJOR engine problems including blowing it.
A wet kit is safer. You can buy a couple extra parts and convert a dry kit to a wet kit. I did it and it worked well. I ran 12psi and 125hp nitrous this way. Most likely your fuel system won't support 125hp nitrous, but if it's a wet kit you will be able to do it.
Old Dec 28, 2002 | 01:17 AM
RBa's Avatar
RBa
Re: NO
I was kidding about the Nitrous.. I know the deal with the dry and wet kits...
Thanks for the info though.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
uttadms31
Sep 30, 2015 05:24 AM
dcam0326
Sep 18, 2015 04:52 PM
DBear
Sep 14, 2015 08:33 PM
ag90fox
Sep 9, 2015 12:22 PM
