How many of you are running 300+whp with stock injectors?
Old Oct 18, 2003 | 03:59 PM
colaen
My first goal is to get above 300whp but I'm currently poor and would like to put off injectors and standalone engine management for a while. Who here is, or has in the past, run over 300whp on stock injectors?
Old Oct 18, 2003 | 04:02 PM
hlh0501's Avatar
everyday
Old Oct 18, 2003 | 06:23 PM
iansw's Avatar
close - 278 wheel power with stock injectors.
When I get my blower back I should be well over 300hp.....we'll see what happens.
Old Oct 18, 2003 | 06:37 PM
ereet's Avatar
270 untuned .. I'm pretty sure I'd be at the 290-300fwhp range with an S-AFC. If you can afford to get the means to put 300fwhp on a maxima, then you can afford to upgrade the injectors.
Old Oct 18, 2003 | 09:37 PM
Stephen Max's Avatar
I've got some 370 cc/min injectors I can let go for $280 plus shipping. They have been flowtested by RC Engineering.
Old Oct 19, 2003 | 10:55 PM
ToYLeT902's Avatar
JET Speed Lab
I Am....
Old Oct 20, 2003 | 09:41 AM
JAY25's Avatar
3.25 pulley, 8:1 FMU disk
321HP, 260 ft lbs of torque
Old Oct 20, 2003 | 09:57 AM
20thdriven's Avatar
323 tuned on 5th gen
v2 3.125
Old Oct 20, 2003 | 10:28 AM
[maxi-overdose]'s Avatar
not here!
261whp with a 13:1 AFR. for some reason, not enough fuel is delivered to the engine. compared to previous run, which was 273whp and 10:1 AFR, untuned and stock cat-back.
it must be something wrong with the fuel delivery.
so far, these might be the cause(s)
1.bad injector(s) / clogged injector(s)
2.bad fuel pump
3.spark plugs / gap / heatrange (stock heat range was used inprevious 10:1 run and 1-step was used in 13:1 run)
4.bad FMU (but I am seeing boosted fuel pressure?)
I dunno still trying to trouble shoot.
Old Oct 20, 2003 | 10:30 AM
JAY25's Avatar
Originally Posted by [maxi-overdose]
not here!
2.bad fuel pump
have you checked your FP with a fuel pressure gauge? you dont need a expensive gauge any mechanical will work. Just Tee it off between the fuel filter and the top fuel rail
Old Oct 20, 2003 | 10:33 AM
SR20DEN's Avatar
VQ Wizard
I got over 300whp with the stock injectors and a dry NOS kit.
Old Oct 20, 2003 | 11:00 AM
thx Jay25
my case is compliated.
I have an in-cabin electric fuel pressure gauge and I am getting over 100psi of fuel at redline. Even with that much of fuel pressure, I am still running super lean. I havent punch her hard recently, but the fuel pressure is still there. The sender is located right after the inline pump and the fuel rail. 5th gen fuel filter is located inside the fuel tank with the fuel pump.
I have also tested the in-tank fuel pump per Hayne's repair manual with the fuel pressure gauge. the result was fine and both the pump's working and injecotrs are not leaking.
I am going to try to relocate the sender to before the FMU. I know I will get a funny idle fuel p. but I will see better boosted fuel pressure.
Old Oct 20, 2003 | 03:42 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
tempting
Old Oct 20, 2003 | 05:50 PM
iansw's Avatar
That's an awesome price....
I'd jump on it but I already have a deal with someone to trade for a MEVI for a set of RC Blueprinted injectors..
Old Oct 23, 2003 | 10:31 AM
dashingMax's Avatar
I am.
3.33" pulley
IMHO Get those RC injectors, before you push 300whp
Old Oct 26, 2003 | 06:10 AM
JAY25's Avatar
once again with a PFI kit I am over 300
http://bigdogjonx.net/fullpics/dyno/Jay25turbo/run5.jpg
Finkle
Sep 27, 2015 09:53 PM
cruce91
Sep 20, 2015 10:23 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
