How did you break your BOOST in?
Old Jan 21, 2004 | 03:42 PM
MaximaRider's Avatar
Ok so as a majority of you know my blower has been on for about a week now, not even, but i've manage to put on 350+ miles of steady driving on my ACT clutch/fidanza flywheel. Replaced the plugs with 1 step colder plugs and put on a breather filter to cover up that gaping hole on the side of the engine.
-My question is can i push the car now? i have rarely taken it above 3-4k rpms and when i do that bish breaks loose and pulls like a ****(experienced it once or twice) am i good to go now, can i redline the bish? i don't wanna F anything up before i get back to school. Yes i know i can't abuse it at every light, but i bought this thing so i could haul some @ss. Should i go pick a fight tonight?
Old Jan 21, 2004 | 04:01 PM
[maxi-overdose]'s Avatar
the best way to do this is dyno her first and get a baseline of your AFR first.
other than that:
belt alignment / belt tension ok?
EGT reading ok?
got fuel pressure?
Old Jan 21, 2004 | 04:04 PM
belt alignment and tension are A-ok, EGT's seem to be reading fine... my FP gauge was reading 39 but then i discovered the T-fitting was leaking so i disconnected it for now until i find a new T-fitting(any recommendations, its an autometer unit)
-if anything im running very rich, 3.25 pulley with 8:1 disc
Old Jan 21, 2004 | 04:23 PM
stephenlc's Avatar
I would wait untill after the clutch is fully broke in and maybe try to do a dyno run.
Old Jan 21, 2004 | 06:53 PM
ToYLeT902's Avatar
JET Speed Lab
Once the blower was put into my car i was having fun already
Old Jan 21, 2004 | 08:22 PM
HNDA ETR's Avatar
Still Here... IM me for more..
you mean you're supposed to break it in first?
Old Jan 21, 2004 | 10:31 PM
turbo97SE's Avatar
I broke mine in ... I considered it broken in by the time I back it out of the driveway!
Old Jan 21, 2004 | 10:38 PM
your fuel tee is leaking? that's not good dont floor it until you got that fix or 100psi of fuel pressure is going to make a mess.
tee - I just use whatever I could find in an auto store and it was just an ordinary brass tee. did you use thread sealant on the threads?
once you got that fixed, downshift and floor your car from 5th to 4th and see if your EGT drops a little. If it does, that means you are running rich. But the best way to find out is spend 50 bucks on a baseline dyno.
Old Jan 22, 2004 | 10:28 AM
I disconnected the T so its not leaking anymore, i guess i'll try the shops up by school for a different T. What EGT's do you guys usually see? I never really see it go above 1200 F and thats when im really on it. Otherwise its always around 800-1000.
Old Jan 22, 2004 | 10:31 AM
Stephen Max's Avatar
Where's your egt probe located?
Mine is just below the front bank O2 sensor, a couple of inches below the header junction. I see about 1450-1475F at the end of a quarter mile WOT run.
Old Jan 23, 2004 | 11:59 AM
C MAX's Avatar
start the key...peddle to the medal....when your heart stops racing...
its broken in .....
Old Jan 23, 2004 | 12:40 PM
maximase86's Avatar
I love lamp.
Or it could be considered broken in when you scare the **** out of the passengers in your car.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
D Mason
Jun 21, 2016 04:43 AM
Need help
23
Oct 2, 2015 08:56 AM
MichMaxFan
Sep 30, 2015 09:18 AM
