sc belt issues
Old Nov 7, 2004 | 12:01 AM
Max97Stick
sc belt issues
i just checked my engine bay and looked at my sc belt it looks like the belt is rubbing somewhere but can tell where
sc 3.125
can anybody help me out
Old Nov 7, 2004 | 08:48 AM
vortechpower's Avatar
how can you tell it is rubbing somewhere?
Old Nov 7, 2004 | 11:18 AM
Max97Stick
belt has lil tears on the end
Old Nov 7, 2004 | 11:42 AM
matty's Avatar
how longs the blower been in ??
V1 or V2 ??
-matt
Old Nov 7, 2004 | 12:58 PM
Max97Stick
v2 about a week or two
Old Nov 7, 2004 | 06:41 PM
little tears can usually just mean the belt is getting worn in. When or if you start noticing threads or loose parts hanging from belt then you need to inspect. What side of the belt is this wear occuring on? I might guess the motor side.... Just make sure you have the proper tention and drive it like you rented it. Good rule is to look under your hood evey time you park/ get out of your car. How many miles have you put on the belt you have on now?
Old Nov 7, 2004 | 10:12 PM
meccanoble's Avatar
Sports Button FTW
i had SC on for roughly 5k miles with a new belt and i never seen any rips on mine or signs of slowly wearing in. It was the same since the first time it was put on.
Old Nov 7, 2004 | 10:28 PM
Max97Stick
i have put about 500 miles on it or more
i always check everyday or so for leaks or anything
well since i saw the belt havin little tears on the motor side
i found 2 screws a bolt 2 bolts and a nut
Old Nov 7, 2004 | 11:24 PM
Well, I have gone a few miles with a sc so... Sometimes you can get wear on the edge of the belt and it doesnt mean something is wrong. If you are finding bolts and screws in your engine bay that is not bad unless they are not where there supposed to be. Maybe you should put them back and try some lock tight. If you have gone that many miles than your issue is prob minor. The bolts your finding might have a purpose and would prob be best if you put them back where they go.
The wearing of the belt does not always have to happen. Over a hundred thousand miles you might see this happen several times...
Old Nov 7, 2004 | 11:47 PM
Max97Stick
the bolts were probably extra or lost while installation
as of know only problem i have i see alil oil residue under blower,
blower doesnt look like it leaking but the oil feed line is wet or the elboms fittin maybe need to be changed for new ones or maybe line
also on the bottom the oil feed line is leakin alil oil maybe theyre wasnt no lockite put on while installation
Old Nov 7, 2004 | 11:56 PM
sometimes the oil return line will leak alittle if its not on really tight. Best way to fix that is by going under neath the car with flat head screw driver and try to tighten it. Clean that erea real good than you can get an idea of how much oil is coming from there. As long as there isnt any oil getting on the belt you should be ok
Mar 12, 2020 12:06 AM
markevans999
Oct 25, 2015 08:27 AM
RWCreative
Sep 21, 2015 11:01 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
BrandonCause
Sep 14, 2015 10:41 PM
