Supercharge to get STi acceleration?
Old Jan 22, 2005 | 07:49 PM
Spaniard's Avatar
Hey just wondering what the community would think.
If I supercharged my very-modded 96 with sticky tires-
Q: would I be able to hang with a STi in a straight line from 30- to 100 (on the track, mind you)
Heres the thing - im currently logging 195 Tq and 186.9 HP (@wheels before MEVI) with a whip that only weighs 2850 (before I get in it)
The subaru weighs 3270.
If I went MEVI and S/C I would assume that I would be only 50 lbs heavier.
That means that my tq/wt would probably be around 230/2900= .0793
Subaru Tq = 300 at crank probably 260 at wheels, and weight = 3270
That means that the tq/wt = .0795
Kinda interesing. Thoughts?
Old Jan 22, 2005 | 08:02 PM
Terran's Avatar
Seems like AWD would own you. At a certain point it's all about the traction. Somebody in an STI beating you at the track or something?
Old Jan 22, 2005 | 08:08 PM
Spaniard's Avatar
Fair question! I was just wondering based on tq or hp/weight... My thoughts are that once you are at 30MPH the AWD isnt that big a factor in a straight line- could be wrong tho..?
Old Jan 22, 2005 | 08:14 PM
DAVE Sz's Avatar
Hooooooonda.....
At 3000rpm your torque would be maybe 10-20 hp over stock, MAYBE. You're not reaching full boost til redline so at 3k rpm you won't be seeing much of a gain. You also didn't say what pulley you want to run. If it's only the stocker than it won't work for your goals. BTW, put this in the BOOSTED forum.
Old Jan 22, 2005 | 09:02 PM
vortechpower's Avatar
You would be toast from a stop. It will feel like your towing a boat. Have you ever ridden in an sti before?? Too many unknown variables from a role
Old Jan 22, 2005 | 09:18 PM
JClaw's Avatar
STI's are listed at 13.20@104 MPH STOCK. That means a good driver is knocking on the 12-second door. Trap speed (mph) is a good indicator of how much HP a car is making (relative to weight, of course), and is generally very acurate in calculating potential (putting RWD, AWD and FWD differences asside). So, the AWD Subaru only needs 104 mph to get 13.2 timeslips, a RWD car getting such times (for example LS1 Forumas) would trap 107 and a FWD car would probably need 108-109.
Basically, check hp/weight ratios for trap speed (which probably is not affected by whether it's RWD, AWD or FWD). It is the ET that will be affected. There's a maxima running 12.9@111. All on street tires, of course. So, with slicks, you can beat an AWD launch. Neal was running 13.42 at only 102 mph. If you can get the same kind of power/weight ratio as a STI, use slicks to rid him of his AWD advantage.
Old Jan 22, 2005 | 09:41 PM
subs1000w's Avatar
you would only need maybe 275whp to wax a stock sti from a 30 punch
i pulled on an evo8 pretty hard from a 60mph roll with a 75shot (253whp) and sti's only trap 2-3mph faster so that seems about right
get a sc and 3in pulley and be done with it
Old Jan 22, 2005 | 10:03 PM
JClaw's Avatar
Meet the STI on the highway rather than from a dead stop and it will be a totally different story.
Old Jan 23, 2005 | 03:45 AM
maxima_kid's Avatar
Yea, you beat an STi's quarter mile time, youll take the STi. Set your goal to that and youll be fine.
Old Jan 23, 2005 | 06:26 AM
stephenlc's Avatar
I dont think from a stop you could pull a STI or EVO. You make maxium torque higher in the powerband. When they make max torque like at 3000 rpm or a little lower. From a roll you could take them.
Old Jan 23, 2005 | 04:41 PM
subs1000w's Avatar
how do you think mardi pulls 1.7X 60fts, who said he couldnt slip the clutch at red line on slicks that would take care of the max torque at red line issue. plus the max has a V6 so its already making alot more torque to begin with. trust me with 275whp and slicks it would be a drivers race from a stop with the max having an advantag. from a roll the max has the win no problem
Old Jan 23, 2005 | 07:21 PM
SR20DEN's Avatar
VQ Wizard
I beat one last night.
Old Jan 23, 2005 | 07:30 PM
subs1000w's Avatar
then i guess my 275whp was a good guess
Old Jan 24, 2005 | 12:48 AM
maxima_kid's Avatar
So ur sayin with a 275whp V6 fwd will definately Wax a 300fwhp awd? What if the 4-banger's on slicks too? Keep in mind that stock STi has 300lb torque @4000 where a 10psi supercharger has bout 275@5500, less than 200@4000.
A rolling starts not really a fair race thou. You dont get that at a track.
Old Jan 24, 2005 | 04:48 AM
SR20DEN's Avatar
VQ Wizard
So you're saying that the Subaru WRX STI has 100% front wheel drivetrain efficiency? If so they're onto some technology that no one else has. And what about the rear wheels?
Old Jan 24, 2005 | 07:02 AM
chris'smax's Avatar
Yea but by dumping the clutch at that rpm wouldn't the toast the axles or other parts of the drivetrain?
Old Jan 24, 2005 | 07:47 AM
Nealoc187's Avatar
SLOW
Alot of the things posted in this thread confuse me greatly...
Old Jan 24, 2005 | 08:06 AM
mtcookson's Avatar
go turbo. done.
Old Jan 24, 2005 | 08:08 AM
chris'smax's Avatar
, But then again i have never been the brightest crayon in the box
Old Jan 24, 2005 | 08:10 AM
maxboogie's Avatar
a couple of us org members went to e-town where there was a sti stock running 13.2 for the most part. C MAX ran him and beat him about 1 1/2 cars for a 13 sec run. i believe he was running 11lbs of boost and 30 shot, i dont know what that adds up to hp wise but it was one good race.
Old Jan 24, 2005 | 08:42 AM
Bags's Avatar
VG Ridah's Biatch Hoe
ok, this has way to much BS in it.
Old Jan 24, 2005 | 08:47 AM
Stephen Max's Avatar
He said slip the clutch, not dump it. Of course, now you're toasting the clutch, but you can control wheel spin while staying in the power curve.
D Mason
Jun 21, 2016 04:43 AM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
Need help
23
Oct 2, 2015 08:56 AM
MidnightMaxima_22
Sep 6, 2015 01:18 PM
