Wrapped car out to 9k+RPM
Old Apr 18, 2005 | 03:39 PM
iansw's Avatar
Last summer, I did a stupid downshift from high in 3rd Gear to 2nd gear on accident!! (Meant to shift to 4th, missed)
That was quite a while ago and the car still feels fine. Everything I've read tells me that the engine should have popped right then and there, leaving me by the side of the road.
Anyone else done something dumb like this and lived to tell about it?
Is there anything I should be looking at mechanically just to make sure there isn't some unknown damage? (besides compression test, which is fine)
Thanks!
Old Apr 18, 2005 | 03:53 PM
JClaw's Avatar
Yeah check for compression. Highest mine's seen on accident is 6800-6900, which doesn't hurt the engine at all.
Old Apr 18, 2005 | 04:18 PM
I30tMikeD's Avatar
I did that. Shifted at 7k from 3rd to 2nd. My motor was not as lucky.
Old Apr 18, 2005 | 04:19 PM
Jeff92se's Avatar
I'm needing a caw
Little late to worry Ian. If it hasn't broke by now..............
Old Apr 18, 2005 | 04:48 PM
mtrai760's Avatar
'Trynna' is not a word
Ha ha, yeah, if its still fine now, your probably good. Did you record the highest RPM on your SAFC? Tachometer would be horribly inaccurate at that level. I accidently ran my old integra up that high, and never had a problem. Heard a lot of stories though. M3's are especially susceptible to this, and there ECU records it all, making warranty claims useless.
Old Apr 18, 2005 | 05:49 PM
Kevlo911's Avatar
Kevlo for President
That happened
Those peices are suppose to be on the Cam
Old Apr 18, 2005 | 06:03 PM
Stephen Max's Avatar
The horror! The horrror!
Old Apr 18, 2005 | 07:37 PM
Nealoc187's Avatar
SLOW
I did it 3 times in my 96. Twice when I first got it, and once like two years ago. No ill effects whatsoever. Ran faster and faster until the day I started de-modding it. If your car didn't pop right away, it didn't do any damage. Also was in BriGuyMax's 97 when he did it. No damage.
Old Apr 19, 2005 | 05:04 AM
Blu's Avatar
Blu
the tits
I did that boosted running the 3.33 pulley. Yea it recorded 9800 rpms on the DEFI link and I bent a couple exhaust valves. Had 5 compression in one cylider and 55 in another. You are lucky.....
Old Apr 19, 2005 | 08:29 AM
vortechpower's Avatar
nope, never did that but I know someone that did and had to get a new motor...
Old Apr 19, 2005 | 08:41 AM
mtcookson's Avatar
something similar happened to my in my 3rd gen. i was passing someone and shifted from 3rd to 4th pretty hard. the clutch slipped real bad and i saw the tach run up to 7,000+ rpm, which was recorded by the s-afc. happened to me another time and i saw the tach read 8,000+ rpm but the s-afc said only high 7,000 rpm. was still pretty scary but luckily nothing happened.
Old Apr 19, 2005 | 09:42 AM
iansw's Avatar
Yeah - I was sure I was good now - mostly just wanted to hear some stories and make absolutely sure there isn't anything else besides compression to check.
Old Apr 19, 2005 | 10:04 AM
Blu's Avatar
Blu
the tits
well after it happened to me the car idled terrible, cammed realy hard etc. So you would more than likely know if anything was wrong, but I would do a compression check just to be 100% sure there arent any hurt cyliders.
Old Apr 20, 2005 | 07:19 AM
Zack342's Avatar
Happened to me in my 99. shifted from 3rd at about 95mph into 2nd and tach shot to 7500rpm....that was about a year ago
Old Apr 22, 2005 | 10:17 AM
chaos356's Avatar
A friend did that to anothers bmw dinan 3 series. Messed the head up.
Old Apr 22, 2005 | 10:25 AM
Jeff92se's Avatar
I'm needing a caw
This one time at band camp................
Old Apr 22, 2005 | 10:54 AM
C MAX's Avatar
yeh same thing happend to me. im auto but my gear shift lock wasnt working and i accidentally knocked it in 2nd. all i know is im revving out over 7000rpm then bent a valve.
Old Apr 22, 2005 | 11:45 AM
mtrai760's Avatar
We all know what happend to you at band camp jeffy...
Old Apr 23, 2005 | 10:36 AM
Kevlo911's Avatar
Kevlo for President
We don't haev a lock like some cars do. We can throw it in 1 doing 100 and blow the tranny yot bits and peices. Some cars you put it in one and it will do nothing.
Old Apr 26, 2005 | 02:20 PM
Mximus's Avatar
yeah, i did about the same in my car too. I was going about 50 or 55 in second and shifted into first instead of third when i first got my car. the tach read about 8000 when i did that. It scared the **** outta me but i poped the hood just to listen and it didnt even seem to faze it. Shes a pretty rugged engine.
Old Apr 28, 2005 | 02:26 PM
95turbo gxe's Avatar
nope never happend to me Im the master shifter.
But their was once that I rev up a little high and the safc recorded 6400rpms
Old Apr 28, 2005 | 03:09 PM
Stillen Maxima's Avatar
Pay to Play
Well my friend has a 2004 6 speed coming in the beltway she was in 5th gear and missed 6th to 2nd I was like OHHHH SHHH***** and her Max is still perfect
Old Apr 28, 2005 | 05:37 PM
THT's Avatar
THT
Throbbing member
How, pray tell, do you shift to second when you meant to hit sixth?
~THT
Old Apr 30, 2005 | 05:19 PM
98SEBlackMax's Avatar
Maxima.org Insomniac
Ive never been able to shift it back into 1st gear once the car was moving, it seems to have a lock out on my car.
I did the 3 to 2 once by accident when I first started driving stick, shot to about 7000 on the tach and no ill effects came about. To avoid the 3 to 2 when I want to goto 4th I throw the shift down and towards the front passenger's seat. The car can't go into reverse when going forward (well not without that awful grinding) and it saves you from going into 2nd. Ever since I adopted this method Ive never screwed up the 3 ~ 4 shift.
Old Apr 30, 2005 | 05:37 PM
Kevlo911's Avatar
Kevlo for President
I am talking about hte Autotragic...
MikesChevelle
Nov 23, 2024 11:17 AM
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
Balkins
Aug 12, 2015 06:39 AM
altome15
Aug 10, 2015 07:05 PM
