Dyno'd today (pics)
Old Feb 26, 2006 | 06:55 PM
ewuzh's Avatar
Dyno'd today (pics)
Took the car to the dyno today and met up with ptatohed and the_wizard too. Dyno days take forever!! I got there at 9am and didn't get to dyno until almost 3pm. But, anyway here's the graph. Frankly, I'm surprised with the numbers (thought it would be lower).
VIDEO!
http://www.youtube.com/?v=rKvkUMh4QNU
264 whp / 249 wtq
powertrain/drivetrain mods:
V2 blower with 3.48" pulley
V1 plate (Stillen)
Blitz SS
Walbro 255 HP, stock injectors, stock kit Vortech FMU
BKR6E-11 1-step colder gapped to .040
Warpspeed Y (2.5inch)
HKS Sport exhaust (60mm)
Clutchnet stage 2 organic clutch
Raxles
Not all that impressive compared to the 300+ hp guys, but it's a work in progress. How's the A/F look? A bit lean?
Old Feb 26, 2006 | 07:01 PM
Tatanko's Avatar
Bacon Lover
Not too bad. Congratulations. Wish I could offer more insight...
Old Feb 26, 2006 | 07:03 PM
Kevlo911's Avatar
Kevlo for President
AF is VERY lean IMO. You need to be closer to 12.1
Old Feb 26, 2006 | 07:12 PM
steven88's Avatar
Need A Light?
wow nice #s eric....definitely has potential....haha remember we were talkin about u hittin only 235....haha congrats!
Old Feb 26, 2006 | 07:32 PM
ewuzh's Avatar
Thanks haha yeah I remember that. I was thinking about a VQ35 swap and keeping it N/A, but if I'm at 260hp now, then I'm not so sure I want to "downgrade" to ~215whp.
Old Feb 26, 2006 | 07:57 PM
Larrio's Avatar
The Definitive AE Master
you should check your MAF voltage to see if your maxing out. You might want to upgrade to larger injectors also if you want more power
what psi are you boosting at?
btw, your car looked good at the performance meet
Old Feb 26, 2006 | 08:01 PM
ewuzh's Avatar
Thanks Larry, your car looked excellent as well with the new wheels. I need to fix some oil leaks first but the next stage would be:
370cc or 480cc injectors with afpr
Z32 MAF
3" charge pipe with CAI
b-pipe and cat
I'm at 8psi right now and don't plan on downsizing the pulley any time in the near future.
Old Feb 26, 2006 | 08:04 PM
Larrio's Avatar
headers may help put down more power without downsizing the pulley are changing much of anything else
Old Feb 26, 2006 | 08:08 PM
cardana24's Avatar
Blown
since you are boosting I think you are running too lean as well. What FMU disc are you running? You may want to bump up to a higher rate. IMO you are playing with fire with those AFRs.
Old Feb 26, 2006 | 08:17 PM
ewuzh's Avatar
It's whatever the V1 Stillen kit came with originally (6:1 or 8:1). I don't think I should be increasing the fuel pressure any higher than it already is. Wouldn't larger injectors be a wiser choice?
Old Feb 26, 2006 | 08:20 PM
Donkeypunch's Avatar
Hey man, I saw you there!
You actually looked kinda pissed off. lol
Did you think you were going to make way more?
I got there at 10:00 and dyno'ed right after you.
Your A/F looks fine in my opinion.
Old Feb 26, 2006 | 08:23 PM
ewuzh's Avatar
Oh, I probably looked pissed off because I got there soo early and had to wait the entire day to dyno.
I actually thought I was going to make much less...I was only expecting around 240whp.
Old Feb 26, 2006 | 08:49 PM
VIP Maxima
damn those #'s are high
Old Feb 26, 2006 | 08:56 PM
heh, same here.
It took almost 5 hours to dyno.
Old Feb 26, 2006 | 09:18 PM
choray911's Avatar
The Crazy Azz Cracka
As it sits right now you have enough fuel upgrades to keep the monster fed. What are you usuing to tune the car, SAFC-II, E-manage........ Just richen up the system across the range and you should be fine. Just remember you don't want to be too lean, other wise you'll be doing the 3.5 swap before you thought. Try to get it between 12 to 11.5 or 11 to be really safe.
Choray
Old Feb 26, 2006 | 10:13 PM
ewuzh's Avatar
Are Apexi and Greddy the only two options as far as an electronic AFC goes?
Old Feb 26, 2006 | 10:18 PM
VIP Maxima
ewuzh, i want S/C too. what should i do?
Old Feb 26, 2006 | 10:35 PM
I30tMikeD's Avatar
Go to the next size FMU disk or raise your base fuel pressure. Bring your AFR's down around 12.
You shouldn't be running too much fuel pressure and your not maxing out the MAF. You are getting close to maxing out the inejctors though. But your fine where your at.
Curve looks nice, congrats!
Old Feb 27, 2006 | 09:37 AM
VQ30DENX_SC's Avatar
WOOOT!! Nice. Way to represent! That means I'm probably kicking *** with my 10psi pulley, lol.
Why would you need bigger injectors if you probably aren't maxing out your stock injectors or your maf??? If you don't plan on going down in pulley sizes you are wasting your money with the maf/injectors.
Old Feb 27, 2006 | 09:43 AM
ewuzh's Avatar
Yeah I think you're right on that. I beleive Jim's running stock injectors and he put down ~315whp on a 10 psi pulley
Old Feb 27, 2006 | 11:24 AM
I30tMikeD's Avatar
it's not that your injectors are not close to being maxed out, they are. It's that your using an FMU which increases fuel pressure which in turn makes your injectors flow more. 315whp is beyond what stock 240cc injectors are good for at a reasonable fuel pressure.
Old Feb 27, 2006 | 12:32 PM
JClaw's Avatar
Or you could do the 3.5 swap and keep the supercharger
Old Feb 27, 2006 | 06:47 PM
Congrats Eric. Nice numbers. It was great to catch up with you again. When's Stillen day this year? FTR, I am on stock injectors.
Old Feb 27, 2006 | 08:13 PM
slimer's Avatar
A couple of Blaxxx's? Lawls.
Eric thats about par. I'm at 7.6 psi and seeing 268whp.
Old Feb 28, 2006 | 04:12 PM
MyownNismo's Avatar
Future Camaro SS owner
Nice numbers. Thought I would here more of the SC. But that's because of the tires/drums.
Old Feb 28, 2006 | 06:12 PM
ewuzh's Avatar
Should be sometime in June like last year. That will definately be fun. Hopefully I'll have some more upgrades done by then. Gotta catch up to you
Old Feb 28, 2006 | 06:58 PM
notnser's Avatar
Before you go richening or leaning out your mixture how did they sample the AF ratio? Was the sensor a properly calibrated sensor placed in close proximity to the head? Does the shop use a different sensor for cars with leaded/race fuel vs unleaded fuel?
If not then ignore those radings. On forced induction cars these things need to be followed closely. If the sample was taken from the tailpipe it is probably off. Any exhaust leak and bad sensor can have a large effect on the reading.
I once proved this to someone who had the same issue. Thought he was lean based on a tailpipe sniffer. We then took the Zeitronix wideband and placed it just after motor in the exhaust stream. Turns out their wideband was over 1 full point off.... it was showing lean when in reality it was nearly perfect.
Old Feb 28, 2006 | 08:25 PM
choray911's Avatar
There are a few more options out there but those are the most popular around here.
Choray
Old Feb 28, 2006 | 09:29 PM
ewuzh's Avatar
A/F was sampled from the tailpipe. Isn't this where dyno shops take the readings from when tuning?
Old Feb 28, 2006 | 09:45 PM
I30tMikeD's Avatar
Tail pipe is OK if you have no cat and your sure there is no exhaust leaks
Old Mar 1, 2006 | 07:48 AM
notnser's Avatar
I agree totally, as long as the shop has a sensor that is worth a crap. 95% of all shops that I have experience with, that use a tailpipe sensor, I would nto trust them to tune from that reading.
Again just because they have a sensor and tell you something does not mean they are correct. I would ask them the questions I posed above and if they tell you it doesn't matter, I would not trust them for tuning or AF readings...
Probably sound like a skeptic but that has ben my experience with PLENTY of shops.
howardis
Dec 11, 2019 06:10 PM
Forge277
Jun 13, 2016 09:26 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
