Weird Problem After SC install
Old Apr 11, 2007 | 05:47 PM
ExoticCreations's Avatar
After installing the supercharger when i floor it at exactly 3500 RPM's the car seems to Dead miss or something. It's fine below that but as soon as i go over 3500 RPM It struggles to redline. I'm boosting to about 9 psi near redline. I have no codes, I checked the plugs and vacuum lines and there fine.
The only thing i can think of is cause i have stock diaminter cat back piping and to much back pressure. Please help has anyone else had this problem or think what it could be.
Old Apr 11, 2007 | 05:53 PM
streetzlegend's Avatar
You gotta describe a lil more dude. What are you doing about fuel management? what injectors? what fuel pressure, any tuning, do you know your air/fuel, etc... theres alot of things that can be happening
Old Apr 11, 2007 | 06:10 PM
gtr_rider's Avatar
192.168.1.1
I hope you tuned that thing..
Old Apr 11, 2007 | 06:16 PM
It has the FMU the comes with the stillen kit.Stock injectors. It's really weird after 3500 rpms the car barely moves and the boost stays on.
Old Apr 11, 2007 | 08:51 PM
Another thing i noticed is at a stop it feels like its missing.When i put a load on(A/C) it it gets worse. Tomorrow I going to change the plugs and test the coils with a ohm meter.
Old Apr 12, 2007 | 08:35 PM
I changed the plugs and tested the coils, only one tested lower than the other's, put not bad.Still have the same problem. Anyone got ideas or suggestions?
Old Apr 12, 2007 | 08:39 PM
TJ_Max's Avatar
Paradox Systems Vendor
Compression test? QNZmax has the same issue in his thread. I don't know what thats about. Check his thread "Some questions about the SC install". Check and make sure there are no hose clamps blocking the TB.
Old Apr 12, 2007 | 08:59 PM
have u checked ur air/fuel? Do you know if you MAF is maxing out?
Old Apr 12, 2007 | 09:10 PM
How could i test my MAF?
Old Apr 13, 2007 | 04:57 PM
What is the max boost on a A32 MAF?
Old Apr 14, 2007 | 09:06 AM
GodFather's Avatar
Made in Taiwan
Need a Wideband O2, better if you can log the A/F data. I'm suspecting a tuning problem.
-Peter-
Old Apr 14, 2007 | 09:43 AM
Kevlo911's Avatar
Kevlo for President
9psi and stock injectors
Old Apr 14, 2007 | 11:08 AM
MaxInProgress's Avatar
Proud of his GroceryGetter!!!!
HHMM are you hearing a crackling noise coming after 3500 rpms like somone is crunching up some newspapers? Your system is nowhere done for you to be safely boosting. YOu need a wideband ASAP, bigger injectors, z32 maf, fuel pump. HMM that what I can thinkof right now. It can be too many things without you having anything we can look at a/f wise. Tell me if you hear that crackling noise.
Old Apr 14, 2007 | 02:33 PM
GodFather's Avatar
Made in Taiwan
Can you elaborate what that cracking noise is a symptom of? I am just curious to know; the more I'd learn, the more I'd know. Thanks.
Kevlo,
9psi over stock injectors shouldn't impose any problems at all. I humbly think that it's over 10 psi's is when we'd need to look at injector options. As long as he's still in the range of being able to use FMU's successfully, stock 240cc injectors wouldn't be a problem at all. But if and when boost is more than 10 psi's, and FMU's step size isn't the tune-span anymore, that's when larger injectors should be needed.
-Peter-
Old Apr 14, 2007 | 02:35 PM
GodFather's Avatar
Made in Taiwan
Max boost for A32 MAF is legally correct under 300whp, ie. under 10psi boost should normally be okay.
-Peter-
Old Apr 14, 2007 | 04:41 PM
Curt's Avatar
I don't see any mention of whether or not he's using the T-Rex pump. Almost sounds like something about the installation wasn't done right.
Old Apr 14, 2007 | 08:25 PM
GodFather's Avatar
Made in Taiwan
I was wondering the same thing, but since his post upstairs says that he's done the "full" kit. I assumed he was referring to the the Stillen S/C kit, which implies further that he's got the T-Rex Aux pump installed. Then, unless he's got a bad FMU, I really dont' see how this could happen.
He won't get positive pressure till late 2k to early 3k rpms (maybe a little early with a 9psi pulley, but nevertheless, my theory still applies). That's window when the FMU is supposed to "kick-in". But he's able to pull it to redline like he said, so it's just a very bad A/F tune in my point of view. Hence, asking him to install Wideband for A/F.
-Peter-
Old Apr 15, 2007 | 08:24 AM
The crackling noise is a symtop of knock, which is not good. Its a very diff sound youll know it when you hear it.
Old Apr 24, 2007 | 12:47 PM
LatinMax's Avatar
You need to tune really bad.
What are you using the manage the setup? Is it just the FMU?
Lakersallday24
Nov 7, 2024 07:31 PM
Cotozic
Jun 28, 2017 08:01 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
kirkhilles
Aug 8, 2015 10:53 AM
Jcof88
Aug 3, 2015 10:43 PM
