Gloria Turbo Manifolds install in maxima
Old Apr 16, 2007 | 10:01 AM
CustomaX's Avatar
this is the gloria turbo manifolds
i try to install it in my friend maxima and it's same the original without any problem
this is the pictures
http://www.geocities.com/hksparco/Image009.jpg
http://www.geocities.com/hksparco/Image008.jpg
http://www.geocities.com/hksparco/Image005.jpg
Old Apr 16, 2007 | 10:06 AM
SonicDust187's Avatar
Pics of it installed would be great. I believe this is the front manifold, if so is the rear one the same as stock vq30de or different, also which turbos can bolt up to it?
Old Apr 16, 2007 | 10:10 AM
eckounltd287's Avatar
Likes them corn fed
education system not working so well.
Old Apr 16, 2007 | 02:35 PM
Nealoc187's Avatar
SLOW
I really think english is not his primary language...
Old Apr 16, 2007 | 02:51 PM
CustomaX's Avatar
we didn't try only the standar one , as u see it's better than the y-pipe
for info ( no body try it here in my country they Y-pipe )
about the turbo work it's very good as i see it in my friend car
if u have any info or picture about y pipe and how can i install it just post it and thnx for posting all of u
Old Apr 16, 2007 | 03:25 PM
nismology's Avatar
Links are dead...
Old Apr 16, 2007 | 03:56 PM
Kevlo911's Avatar
Kevlo for President
Originally Posted by nismology
Links are dead...
Work for me
Old Apr 16, 2007 | 03:57 PM
Kevlo911's Avatar
Kevlo for President
Whats the biggest turbo that can fit on that? T28?
Old Apr 16, 2007 | 04:00 PM
nismology's Avatar
Originally Posted by Kevlo911
Work for me
Sonova......
They're working now...
Old Apr 16, 2007 | 04:05 PM
Tatanko's Avatar
Bacon Lover
So you're saying you have indeed fitted these onto your friend's Maxima? Have you bolted up a turbo yet and tried running things turbocharged?
If so, you, my friend, may have just disproved a lot of negative theory. I'm in for pictures installed on the car
Old Apr 16, 2007 | 04:09 PM
Kevlo911's Avatar
Kevlo for President
It will be a TIGHT fit with the radiator fans and any decent size turbo IMO.
I would add a pipe to where the turbo would go and move it so the turbo can sit where the batt is right now.
Old Apr 16, 2007 | 04:13 PM
Tatanko's Avatar
Bacon Lover
I agree. Wouldn't too hard to do, either. A couple of flanges and a small amount of piping welded up.
Old Apr 16, 2007 | 04:17 PM
Kevlo911's Avatar
Kevlo for President
Yupp.
Maybe I should...
Old Apr 16, 2007 | 04:32 PM
Tatanko's Avatar
Bacon Lover
Yupp.
Maybe I should...
You best believe it's on my mind now, as well. How to get a hold of the manifolds, though?
Also, am I correct in assuming that crossover pipe bolts up the same rear manifold that our NA cars have? If that's the case, installation of this manifold and crossover shouldn't be that difficult, since it's the rear manifold that's difficult to access.
Old Apr 16, 2007 | 04:50 PM
Jeff92se's Avatar
I'm needing a caw
Can someone save and rehost? This is interesting
Old Apr 16, 2007 | 04:56 PM
CustomaX's Avatar
the link is edited
but i don't think there is a problem , because if u want to install a T28 u Can But A Plate and reach it upon the tranmission and it will be more easy to install it
Old Apr 16, 2007 | 05:02 PM
CustomaX's Avatar
tatanko it run normaly and i will bring for u picture the turbo is installed in his car
Old Apr 16, 2007 | 05:15 PM
Tatanko's Avatar
Bacon Lover
Thank you, I appreciate it.
Just curious, where are you from?
Old Apr 16, 2007 | 05:47 PM
dead2fall's Avatar
the links are
they dont work for me and i wanna see!!! i wanna see!!!
Old Apr 16, 2007 | 07:06 PM
gtr_rider's Avatar
192.168.1.1
they are working perfectly.. let me rehost
Old Apr 16, 2007 | 07:09 PM
gtr_rider's Avatar
192.168.1.1
Old Apr 16, 2007 | 07:13 PM
Tatanko's Avatar
Bacon Lover
They go out intermittently, probably due to low bandwidth allowances.
Old Apr 16, 2007 | 07:57 PM
maxine'sMan's Avatar
very interesting.. I would also like to see this on the car. I wonder how long till someone else tries it.
Old Apr 16, 2007 | 08:07 PM
Tatanko's Avatar
Bacon Lover
As soon as we can locate some manifolds and suitable parts to go with them, I'd say.
Old Apr 16, 2007 | 08:46 PM
liqidvenom's Avatar
brotherhood of tq
i love seeing new things being tried out...
Old Apr 17, 2007 | 06:39 AM
Whitemax's Avatar
Disco Biscuit
I must say, when this guy first IM'd me, I was like "who the f*ck is this idiot??" He's from Kuwait for those wondering so his English isnt the best. Ive wondered int he past if a manifold setup like this could work, but had no idea that the DET mani's were set up this way. If he isn't full of sh*t, this would mean that 2 of the biggest performance improvements for the maxima community would have come from our Middle eastern neighbors.
Old Apr 17, 2007 | 06:44 AM
Kevlo911's Avatar
Kevlo for President
How common are the manifolds? I doubt they are cheap from nissan.
Old Apr 17, 2007 | 08:53 AM
Whitemax's Avatar
Disco Biscuit
Id say as common as a DET engine. BUT, what I think would be more of a viable solution would be to find someone to build a set based on the same idea, or if possible, a set up pipes coming off our stock manis in the same way.....
Old Apr 17, 2007 | 09:41 AM
Kevlo911's Avatar
Kevlo for President
http://www.importperformanceparts.ne...an-nissan.html
Those?
Old Apr 17, 2007 | 09:45 AM
Jeff92se's Avatar
I'm needing a caw
From what I see, you need both manifolds. As it looks like the x-over tube runs over the tranny into the 4th flange section. Someone confirm where your starter is. If it's on top of the tranny, there might be clearance problems? Auto vs manual? You can tell where the turbo will be. One of you guys should take a look and see how much room you have inbetween the front head and radiator fans. You can always get rid of one fan for room.
Old Apr 17, 2007 | 10:05 AM
MDeezy's Avatar
this is starting to look a little promising...
Old Apr 17, 2007 | 10:45 AM
BK Turbo Max
According to this thread/post...it's already been done...
http://forums.maxima.org/showpost.ph...4&postcount=23
Can't wait for the pics.
Old Apr 17, 2007 | 11:06 AM
I wonder if there is any way to use them with a larger turbo?
Originally Posted by importperformanceparts.net
Will fit Garret Turbo T25, T25BB, T28 and T28RS.
Will NOT fit Garret Turbo T3 and T4
Old Apr 17, 2007 | 12:16 PM
Kevlo911's Avatar
Kevlo for President
The best thing you can do is buy an adapter for T25/28 to T3/T4
Old Apr 17, 2007 | 05:33 PM
CustomaX's Avatar
i will post the picture after 12 hours when i come back from the work
( now i return from uae ) and it's night now
tatanko i am from kuwait and my name is ali
Old Apr 17, 2007 | 06:44 PM
Tatanko's Avatar
Bacon Lover
Good to hear from you. We're all patiently waiting
Old Apr 17, 2007 | 08:00 PM
+1.. this has the potential to drastically change my upcoming project.
Old Apr 17, 2007 | 08:35 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
so wait a minunite the glorias have a t28 turbo instead of the early 300zx t3/t4 atent the t3/t4's bigger and put out much air and why would they only put one on a det engine why didnt they just slap a dett in there
Old Apr 17, 2007 | 08:37 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
and if you ask me they lok like 300zx turbo manifolds except for the divorced chamber
Old Apr 17, 2007 | 09:20 PM
Tatanko's Avatar
Bacon Lover
For those curious what this looks like on a VQ, I stumbled across some pictures (too big for [img] tags, just click on them):
http://www.vq30det.com/Images/VQConv...5b1%5d.JPG.jpg
http://www.vq30det.com/Images/VQConv...5b2%5d.JPG.jpg
