RMT turbo idea diagram
Old Jan 15, 2008 | 12:30 PM
  #201
streetzlegend's Avatar
Originally Posted by densetsu
so if one was to put two turbos in the rear, would one need two scavenge pumps or would a single one suffice?
First you will need to have true dual exhaust setup and equal length, then you will need ofcourse the two turbos, each one having its own oil feed line, then yes u will need to have two pumps. im pretty sure a single pump will not be able to pull the larger volume
Old Jan 15, 2008 | 04:22 PM
  #202
densetsu's Avatar
is true dual the only way? what happens if you use a single pipe back to the turbos and split it into 2 separate ones right before feeding into the turbine? will that compromise exhaust velocity or cause imbalance of flow to the turbos?
Old Jan 15, 2008 | 07:23 PM
  #203
t6378tp's Avatar
Turbo 3.5
that just seems like as waste of money just to say I have 2 turbo's
remember they will be feeding back to 1 tb but if you just have too have 2 turbo's it can be done
Old Jan 16, 2008 | 01:01 PM
  #204
juani's Avatar
Rockin' VK56!!
Finally lol. Nice set up. I likey.
Come on down to SoCal and let's race!!
when are you gonna come down??
I need to check it out for future reference
litch
123
Jan 4, 2024 07:01 PM
user 11122324
42
Jul 18, 2022 03:35 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Justin Kroll
Oct 1, 2015 07:03 PM
