EBAY Turbo kit for 780? nearly complete? hmmm....
It wouldnt be that different between the 2. And depending how you run your pipping you may have more left. I chose to run mine across the engine bay but you could do it like Chernmax did with his and run them on the same side of the car. I do think you will have more than enough pipe.
http://forums.maxima.org/showthread.php?t=543194 here is his setup. its on a 6th gen but none the less can be done on a 5th
Is you washer fluid tank in a different spot on the 5th gen? if you look close on mine. It goes right behind the headlight.
hey guys im new here but i have 2000 3.0 and im looking into turbo's as well. what do you suggest to get. im not a road racer but i do want a v8 response out the car. i had a 750li and a porsche cayenne and now the v6 doesnt have that response. please help thanks
Look on the sticky threads, you'll be overwhelmed with information.
Search the forums. Look at what other guys are running and go from there. It all depends what your goals are.
Turbo in my 97
If I don't want to boost more than 12 psi what spring should I go with on the wastegate? Also is it true that the maxima VQ3.0 can only handle 12 psi safely?
Safely is a matter of setup and tuning. I personally would do a 5lb spring with a bc but you may be able to run an 8lb one.
The Frye
Sep 2, 2021 11:03 AM
t6378tp
Sep 29, 2018 04:27 PM
londonflu
40
Sep 25, 2015 09:11 AM
