DEK build for boost
Old Sep 30, 2008 | 09:00 PM
  #81
CMax03's Avatar
Originally Posted by nismology
I was hoping you wouldn't mistake my stance for ignorance of the theory behind studs. Theory is nice, but what happens in each individual situation in the real world is better. I will make two points:
1. Factory head bolts are designed to stretch and/or twist. This stretching doesn't compromise the bolts' reliability. In fact, this characteristic is the catalyst by which it does it's job. As such, they provide one distinct and irrefutable advantage over any non-TTY fastener; absolute preload consistency. When you torque down an ARP stud, you are not measuring preload; you are simply measuring friction between the threads, which can vary based on a number of factors. When you use angle tightening on a TTY bolt, you can rest assured that the preload through the yield zone will remain consistent. Even tightening around the bore promotes a greater level of concentricity, especially on open-deck blocks.
2. Standard ARP's have not been proven to be any more reliable than OEM in a (specifically) VQ3x application, boosted or otherwise. I am careful not to throw these into the same category as L19's which due to their sheer tensile strength, might prove to be more reliable. In any case, simply using stronger fasteners to fix "head lift" is like putting lipstick on a pig, but that's another story.
If we were in to 60's and early 70's I would agree with the OEM hardware being sufficient and reliable! There's no need for me to go with OEM in a high performance application when their stretch bolts aren't even sufficient for high mileage street vehicle (unmodified). The fact is you can only bend or stretch the metal some much before it finally fatigues and fails such as in Nissans Z20,Z22,and Z24 4 cyl engines (notorious for the head of the bolts to just snap off) and every domestic and foreign rotating assembly with stretch rod and main bolts usually results in spun bearings on untouched and none modified cars
Now I'm the proud owner of a Dodge Shelby Charger that was notorius for blown head gasket cause the OEM stretch bolt could handle 17lbs boost for a sustained duration! The cure Larger stud fasteners(+1mm) and now the ability to run 30 lb boost, NO PROBLEMS!!!
I would love to be able to legally cruise together, down I-10 you in your stretch bolt machine, me in my Nissan with my theoritical studs at no less than 130 mph for about 1 hr. I guarantee we'll find you on the infamous "ROAD DEAD".
You still never stated why aviation machines are full of studded components instead of stretch bolts, nor why any racing team even the sorriest use heavy stud fasteners such as ARP, RACEWARE, or COSWORTH etc...If i was 20 yrs younger, your real world experience and knowledge would get a big a$$ laugh! As far as Standard ARP hardware Im running their Specific application rod bolts on 3 of my vehicles and shift well beyond the lame OEM stretch bolt limit with no problems, SO if you live in the REAL WORLD< I guess I'm in "THE WORLD OF ACTUALITY" > it's not only theory put performance proven!!!! The End
Old Sep 30, 2008 | 09:11 PM
  #82
tavarish's Avatar
fwd gone rwd cr00
www.clubna-t.com has gt35r's for 612 shipped, bishnu.
A guy with 1jz (2.5L) made 465whp on a light tune at around 23psi.
I vouch for this product, and so do a bunch more people. The 3.0 should spool it well before 3k, and won't run out of breath.
I would seriously look for something bigger than a gt35r, but you dont want peaky power. I'd slap a gt42 on there with built internals, and give it hell.
Old Sep 30, 2008 | 09:12 PM
  #83
nismology's Avatar
You still have no idea what point I'm trying to make so this is useless. I've been around these motors (VQ3x) for a while now so I've seen what works and what doesn't. You can keep throwing theory about every other engine manufactured even going back to the damn Model T if you want to. Doesn't bother me...
Let's leave it at that.
Old Oct 1, 2008 | 08:27 AM
  #84
kzoosho's Avatar
I went and looked Tav . They only have journal which aint bad and they are 450 shipped. I love XSPower also and think they are pretty good.
Old Oct 2, 2008 | 09:52 AM
  #85
CMax03's Avatar
You're right you haven't been able to communicate your point to me, so keep on stumbling on the truth! By the way...I'm only using ARP rob bolts on the VG30E NA....too many folks with reflashed ECU's found out the hard way the the new 7000 rpm redline was too much for the OEM rod bolts!
Old Oct 2, 2008 | 09:56 AM
  #86
nismology's Avatar
Nevermind the fact that we were talking about standard ARP head studs for a VQ3x application...
http://my350z.com/forum/forced-induc...3-0-build.html
Your turn.
Old Oct 2, 2008 | 12:27 PM
  #87
CMax03's Avatar
Nice Article! But you Know Nismology...The head lift can be due to unsecure/improperly machined sleeves, Block flex due to not boring or honing cylinders with torque plates, even a substandard head gasket(for that specific application) could have played a part to his term "HEAD LIFT" or what I call a blown head gasket....Nismology improperly installed studs can be problematic if installed with too much or too less torque. Thanks for the respond, I'm not trying to be an a$$, I'm just going by my practices and results with engines I've build and ran with no problems @ extreme levels. I find no need to stud My VG30E nor VQ35DE but, the rod bolts is where my attention is for the power levels I'm @ in both those N/A cars. Thanks Guy, I'm cool with your opinion , no disrespect....
Old Oct 2, 2008 | 12:36 PM
  #88
nismology's Avatar
Respect. I think it's safe to say that the OEM VQ35 rods are the fuses in an unmodified short block so it might be a moot point in the end.
Old Oct 3, 2008 | 12:32 PM
  #89
CMax03's Avatar
VG30DE, VG30E, have been known to make 500whp with stock internal components, I had my rods out and their stronger looking than Chevy(stock) 350 rods. So I'm going with the rod bolts themselves. Japan doesn't make to many blocks or bottom ends that to be heavily modified for higher performance yrs back B4 Honda became so mainstream, production blocks and cranks were used in Endurance Racing (Lemans).
Old Oct 3, 2008 | 12:50 PM
  #90
nismology's Avatar
VQ's are quite different from the nissan engines you're used to working on. The mode of engine failure under boost with VQ35's is usually bent rods. 500+ WHP has been done (which the OEM head bolts can handle reliably) but is not typical. The rods are definitely the weak point in the stock VQ35 shortblock. Furthermore, torque doesn't kill rod bolts; revs do.
Old Oct 3, 2008 | 01:46 PM
  #91
CMax03's Avatar
Yeah I'm aware of that...But the redline of a VG30 is 6000 and the VQ's are 6600 but can be pushed to 7200 in short durations....The VG rod is actually longer than the VQ which also helps in torque production and less angle sweep.
Old Oct 3, 2008 | 02:03 PM
  #92
nismology's Avatar
Not sure what this has to do with the rods being the weak point but k.
Generally speaking, rod/stroke ratio is more important than just rod length itself.
Old Nov 17, 2008 | 06:03 AM
  #93
secondtonone317's Avatar
nycnissans
well, I got the motor.....and been taking it apart. It only has 32K on it. I been thinking of doing some pistons, rings, and rods. Any ideas on beefing up the bottom end for boost + nitrous..........?
Old Nov 17, 2008 | 08:04 AM
  #94
DrunkieTheBear's Avatar
Turbo'd Saab
well, I was planning on buying that Importperformanceparts.net kit, which includes pistons, pins, bearings, rings, gaskets. The kit runs $1,200, but if you part everything out individually your actually not getting a bad deal. Other then those components, a new set of rod bolt/nut combo and thats about all you can do on the bottom end, besides a different set of rods, but I think they should be strong enough.
Old Nov 17, 2008 | 09:58 AM
  #95
jcy98maxse's Avatar
Turbo is too much fun!
I just skim through the thread so I may have missed something...
I've ran a GT35r/T4 on a DE and a DEK and would never have traded for anything else. It spool well and full boost was about 3.5-3.7k @ 10psi, it was a top end monster. If you want something that is even faster on spool but less top end, you may want to look into a GT30r?
When I bought my turbo from PFI, I spent about $1100 but that was a few years ago. Also if you are in the market for a GT35r, maybe look at FP (forcedperformance) variations of the 35r (specifically the 82HTA/86HTA). For basically $300-$500 more, you get faster spool than a standard 35r and it makes more power. It's been proven over and over again in the EVO community that the 82HTA is an awesome turbo!
http://store.forcedperformance.net/m..._Code=Turbo-FP
Old Jan 5, 2009 | 10:05 AM
  #96
nycnissans
^ what about the turbonetics version of the GT35r?
Old Jan 14, 2009 | 11:13 PM
  #97
Ghase's Avatar
Any update Bishu??? I will be buying my motor soon too.....
Old Jul 9, 2009 | 06:03 AM
  #98
nycnissans
here's my first startup video
Old Jul 9, 2009 | 07:56 AM
  #99
kzoosho's Avatar
See you finally are going to try to make some real power, I mean using a turbo lol.
Old Jul 9, 2009 | 08:05 AM
  #100
nycnissans
lol.......
Old Jul 9, 2009 | 08:09 AM
  #101
kzoosho's Avatar
lol.......
Trust me it will not compare to your old car. It can very well make less power and be faster. Think i made 20 less hp but i also made 356 wtq so that put me at 343whp and 356 wtq and ran a best of 12.5@113 so it was not slow at all. U will love the new power when you finally drive it man.
Old Jul 9, 2009 | 08:22 AM
  #102
nycnissans
yeh man, the supercharger does not have too much under the curve.....very peaky
Old Jul 9, 2009 | 07:42 PM
  #103
streetzlegend's Avatar
FINALLY, so now what?
Old Jul 10, 2009 | 05:06 AM
  #104
Ghase's Avatar
Where you learned that from.....lol nice setup Bishnu, but what turbo are you using???
Old Jul 10, 2009 | 05:32 AM
  #105
nycnissans
Its all your fault man, lol
How's the car?
Going with a 35r killer
Old Jul 10, 2009 | 09:09 AM
  #106
Nealoc187's Avatar
SLOW
3.0L ftw. I'm going back to turboing 3.0s myself.
Old Jul 10, 2009 | 09:26 AM
  #107
nycnissans
yeh, the 3.5 is a nice NA or spray motor......it just doesn't hold up too well for boost unless fully built/sleeved unless you plan to stay under 400whp.
Old Jul 10, 2009 | 10:38 AM
  #108
KRRZ350's Avatar
Gotta love the VQ, you can rip the entire motor apart and it will still fire up like it was in the car & running an hour ago
Old Jul 10, 2009 | 10:41 AM
  #109
nycnissans
This is true my friend.
Old Jul 12, 2009 | 05:39 AM
  #110
nycnissans
Old Jul 13, 2009 | 01:26 PM
  #111
TB.4L's Avatar
Nice bish +1
Old Jul 13, 2009 | 01:31 PM
  #112
Kevlo911's Avatar
Kevlo for President
How thick is that rad?
Old Jul 14, 2009 | 05:30 AM
  #113
nycnissans
Originally Posted by TB.4L
Nice bish +1
thanks homie
2in, should get the job done
Old Jul 17, 2009 | 02:40 AM
  #114
AceofSpds's Avatar
wat
are you going to be able to retain having a/c?
im sure its not that big of a deal for you but down here, f that.
Old Jul 17, 2009 | 05:31 AM
  #115
nycnissans
no ac, however it could have been possible to retain but I didn't want it anyways so I fabbed things up knowing I will get rid of the ac, also the pipes I bought was designed with the same thoughts of no AC.
Old Jul 18, 2009 | 12:39 PM
  #116
kzoosho's Avatar
Boo no A/C blows Bish. i have to have A/C man . i will show yo umy new feedpipe man. it keeps a/c and clears the stock rad and fan.
Old Jul 18, 2009 | 12:56 PM
  #117
nycnissans
another teaser
Old Jul 18, 2009 | 12:58 PM
  #118
nycnissans
I hear you man.....Im sure I will regret it but I guess live and learn
Old Aug 15, 2009 | 08:15 PM
  #119
k20tek's Avatar
OWES MEMBER MONEY - DO NOT BUY FROM k20tek
I like that maf housing where did you get it
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
MichMaxFan
Sep 30, 2015 09:18 AM
