VG33R Supercharger
VG33R Supercharger
I've recently been thinking, the VG33ER supercharger would probably be an easy way to convert a VG30E to forced induction.
The question is would it bolt on and how hard would it be to tune for....like would you need to order a custom ECU tune off JWT or would an adjustable FPR or new injectors or something work?
Just a theoretical question...at least for now.
That supercharger isn't worth your time. It's an Eaton M62, which IMO is too small for a 6-cylinder. The M90 is barely adequate for a 6-cylinder and this is a good bit smaller. So, even if you could make it work, I don't think it's worth your time. Go turbo instead There's cheap, easy ways of doing that now you know!
In theory I prefer turbos but the turbocharged 3rd gen has been done before and in addition I'm BIG on low end (though...my tires seem to disagree with me there). It's more likely that I'll get a T3/T04E and try to make somewhere between 250-400hp but I'm trying not to get ahead of myself yet.
Bottom line is, this super charger is a lot of work for very little gain. You think it will even fit under the hood?
regardless i'd do a remote mount turbo cheap and easy.
And every last one of them complains about how the M90 is basically a heat pump. Spend much time on the boards? Also, you just lumped the M62 in there which is much smaller than the already inadequate M90. Don't do that.
I think you should go for it. The M90's are around around $700 bucks new and $200 and up used. Just know that compared to a Vortech. The M90 is less efficient. And the instant boost will give you traction issues...
If your serious look into Whipple and Lysholm
I was looking into buying a Grand Prix Gtp before I got my Turbo Max so I too have been spending alot of time on 3800performance, grandprix.net, clubgp.com
http://superchargersonline.com/content.asp?ID=76
http://www.sportcompactcarweb.com/te...iew/index.html
http://www.kennebell.net/techinfo/fo...RvsLYSHOLM.pdf
Everyone is forgetting that he wanted this to be "easy" as per his original post. I'm assuming he also probably doesn't want to spend a ton of money. Any of these suggestions thus far are going to require plenty of custom work and originality (read: not easy), and will likely cost him a pretty penny.
Someone mentioned a remote mounted turbo which was my previous plan for my car if I ever went with forced induction after all from what I've heard the exhaust temperatures are low enough towards the back of the exhaust piping that I wouldn't ever need to worry about letting my car run to cool the turbo after driving it hard, not to mention again I haven't heard of a 3rd gen packing a remote mounted turbo. Some things that does have me thinking I don't want to go this route though is the fact that intake piping takes up space under the car that I don't know that I have and of course Maxima's are front wheel drive so if I want to get good grip on acceleration I want to be really nose heavy.
The M62s are useless on the VG33ER for anything over stock boost. I know a few people who complain about them all the time. The M90 is well suited for the 4cyl Cobalt/Saturn Redline. To top it off, inheritly, i dont believe the VG has tons of top end to loose, so a M90 may even be a little on the small side.
But for those ney sayers..the instant torque of the M90 and the supercharger whine..oh my god..its amazing. Try a Stillen Stg3 SC on a titan for off the line torque..with 24's and 315's you can break them loose the instant you hit the throttle.
Take it from ZZ Performance..Even though the Cobalt came standard with the Eaton M62, and you can upgrade to the M90, they recommend turbo, just because of the ease and limitless boost in theory.
stock on the 3800 the m90 provides around 9lbs of boost...
guys run VERY low 11s with them
and dyno well over 400HP with them
it would be fine and they are cheap as sheat.
should the op do it? no just turbo charge it. but the facts about the m90s saying they would be bad to use is just whack. and yes i used to hangout on alot of the 3800 websites but silly ol me got banned for educating newbz.
omg a ported blower. a whole hour with a dremel it's a 'free' mod...
Ed Morad who is VERY well known in the 3800 circles ran a 11.458 @ 120.83 (1.674 60') NA in a 1997 Pontiac Grand Prix GTP with a gen 3 m90 which was 'ported'
sorry mid 11s. either way it proves the m90 is fine. porting it is very easy and i bet Ed would have still broke the 11s as a ported blower isn't going to drop you from 12s to 11.4s.
tod allen hit 12.1 with a m90 in a bonni as well.
i'm just pointing out that they work just fine. as when i saw the m90 being bashed on i thought i should 'stick up' for it.
I'v been in a bonnieville which runs low 12s with an m90. it's bad *** i love to hear it whine.
oh i still don't think the op should use either of them. i think he should turbocharge it, as it'll probably end up being cheaper and easier imo.
This is what the Op would have to do to adapt the roots type blower to our car.
This is where the cost will become an issue.. I have seen these kits used for $2500. They are hard to find.
a company makes a sc for the 5th gen that works the same way fwiw as the one you posted.
I'd use a double pulley or fabricate something like this. I do have spare time, spare metal and lathe/mill access (as I've stated before). So $2500 I wouldn't have to spend.
I'm not a huge fan of superchargers either, just as I said looking for something different to do. I'm having second thoughts about remote mounting a turbo though since that's a lot of extra intake piping.
Who made that kit? That's really well done I'd like to get my hands on one for my VQ35DE mounted in my i35.
KabirUTA13
19
10-17-2015 02:15 AM
