knocking
Old Feb 3, 2009 | 06:33 PM
brasso's Avatar
knocking
I havn't started my car in a couple of months and the battary died so I boosted it tonight and there is a knocking sound on the same side as the supercharger. I let the car warm for ten mins up and it gets quieter but didn't go away. I cant tell if it's the blower or the engine. any ideas what this could be?
My cel is not on
Old Feb 3, 2009 | 07:06 PM
mastercater7's Avatar
VQ35 FTW
Did you go through boost before the motor was warmed up?
Old Feb 3, 2009 | 07:18 PM
brasso's Avatar
No I didn't. I didn't even go into boost when it warmed up. i just put my foot on the gas and brought the rpms up to 3000
Old Feb 3, 2009 | 07:32 PM
VQ35 FTW
You said you boosted it. Now I am confused
Old Feb 3, 2009 | 07:35 PM
brasso's Avatar
I had to jump start it with a booster box to start it cause the battary was dead
Old Feb 3, 2009 | 08:59 PM
98MaXeDouT's Avatar
What kind of knock are we talking here? Make sure all the plate/blower bolts are tight, my v1 kit made a rattle when one of the bolts were loose. Can also be the timing chain/tensioner from sitting and not oiled.
Old Feb 3, 2009 | 09:14 PM
brasso's Avatar
Its hard to explain what it sounds like. Its a knocking/ticking sound like every second or two,if that make sense. If it is the timing chain tensioner will it go away or does it need to be replaced?
Old Feb 3, 2009 | 09:17 PM
brasso's Avatar
It has old gas and I should change the oil so maybe that is why.
Old Feb 3, 2009 | 11:28 PM
matty's Avatar
Miles on the blower ??
Miles on the engine ??
Ever change the timing chain tensioner ??
Is this is a lower end motor knock or a knock you can hear from the top ??
-matt
Old Feb 4, 2009 | 02:37 AM
VQ35 FTW
It is most likely your timing chain tensioner that went out and the sound you are hearing is the chain slapping the timing cover. Put your hand on the cover when it makes the noise and its cold, if you feel it, then you know thats the problem.
Zack
Old Feb 4, 2009 | 06:03 AM
accordingtou's Avatar
VQ30 DE T
Is this a 3.0?
Does it idle rough?
Remove the belt to isolate the noise then report back.
Old Feb 4, 2009 | 08:48 AM
brasso's Avatar
-matt
Blower = 35,000 to 40,000 KM estamate
engine = 180,000 KM
No i haven't
I can hear it from the top
Old Feb 4, 2009 | 08:50 AM
brasso's Avatar
Zack
Ill try this tonight after work
Old Feb 4, 2009 | 08:53 AM
brasso's Avatar
Originally Posted by accordingtou
Is this a 3.0?
Does it idle rough?
Yes it is a 3.0
No the idle was fine
I work this weekend but I will try.
Old Feb 4, 2009 | 06:02 PM
brasso's Avatar
So i started the car up after work and the sound was gone. so i don't know what it was. I will start it more often and see if the sound comes back (hopefully not). Thanks for the help!!
Old Feb 4, 2009 | 06:48 PM
VQ35 FTW
It is possible your timing chan tensioner was having some issues. However, when mine quit working the car only made the noise when it had sat over night, after driving it or letting idle for 15 minutes, the noise would be gone for the rest of the day. I hope for your sake it is not the tensioner, It is a total PITA
Old Feb 4, 2009 | 07:53 PM
brasso's Avatar
I hope its not the tensioner to. I dont drive the car in the winter, but it's been pretty nice out and the snow is almost all gone, so I might drive it to work one day.But for now i will just start it every week and see what happens and hope for the best.
Thanks again for your help
DC_Juggernaut
Sep 28, 2015 04:07 PM
ac max 92
Sep 17, 2015 07:35 AM
ballerchris510
Sep 11, 2015 05:29 PM
