Streetzlegend goes to the darkside (3.5!)
Old Feb 21, 2009 | 04:39 PM
streetzlegend's Avatar
So yea, It has been done. Last night I completed my 3.5 swap, it started with my original 3.0de having bad rings possibly due to the large amount of smoke out the valve covers. bought a dek, it was broken (as i posted on n/a forum), and finally said, F it and looked for a 3.5, found one right away for $700, 25k miles (verified on carfax), 2004 Maxima engine.
Here is vid clip of the initial start up http://www.youtube.com/watch?v=_bfNPec3RAE .
Basically, im using the 3.0 equipment, with the dek oil pans, left the engine stock, as far as internals and head gasket, using stephen max's cam adapter/spacers, along with an adapter to use my 3.0 TB (and yes i will upgrade later). right now i have the stock 04 injectors on there, maybe tomorrow or monday i will be putting in 440's.
Also, I still have my turbo setup hooked up
I upgrade my turbo to an HX35 (bought brand new), so as soon as i put in the injectors, ohhhh boyyy! Auto+Turbo+3.5 =
im coming after the nitrous boys jime and grey99! lol
First impressions. drove it around. feels really smooth, not hesitations or misfires, runs awesome. I have only gone WOT in 1st gear (I havent lowerd the 3.0's boost yet lol so i dont wanna hurt a fresh motor already), in 1st gear, i rolled into WOT, and right at about 4k that thing wakes the hell up spinning all over the place, the most i saw was like 1 or 2 psi, which was basically almost n/a power going to the ground. also, from a stop, i stepped on it hard, spun like crazy (on the 3.0 it would just chirp from a stop). torque is so nice. Here are some pictures and im uploading a 2nd video right now with engine running smooth.
Old Feb 21, 2009 | 04:40 PM
Video and Pics
here the pics, the dude with the jesus sandles is 95blkmax, thanx for your help buddy!
Here's the video clip of it running smooth, http://www.youtube.com/watch?v=UKE9wKhqXys
Old Feb 21, 2009 | 04:47 PM
grey99max's Avatar
LandShark has Cosworth
You gotta love those 3.5s don't ya? Way more torque than you would expect....
Oh, "im coming after the nitrous boys jime and grey99! lol" Yeah, bring it !! It's gonna be a great season!
Old Feb 21, 2009 | 04:55 PM
mightyMax95's Avatar
nicely done! you had me wonderin' but i was pretty sure i knew what you were up to.
Old Feb 21, 2009 | 05:50 PM
t6378tp's Avatar
Turbo 3.5
congrats on the swap, yeah tq is great.
Old Feb 21, 2009 | 06:24 PM
ghostmax301's Avatar
hey, ill add to the F/I 3.5 comment comity.lol
congrats streetz!! cant wait to see the numbers...hopefully ill lose the juice and see some boost soon
Old Feb 21, 2009 | 06:27 PM
maxgtr2000's Avatar
KH3 by popular demand
Congrats dude. Boost+3.5 and spray has gotz to be crazy. Let me know if you need info on clamping the maf and running off the emanage map sensor when you max it out.
Old Feb 21, 2009 | 06:30 PM
running of a map sensor is an alternative to running with a z32 maf or easier/better/only works with EMU??
Old Feb 21, 2009 | 06:37 PM
gtr_rider's Avatar
192.168.1.1
word bird
Old Feb 21, 2009 | 06:59 PM
thnx guys, Actually i wanted to do things right with this motor instead of doing new things (for me)like clamping the maf etc..., im going to get a z32 maf to make things simpler.
Old Feb 21, 2009 | 08:11 PM
Hey I wanted to ask you. How did you deal with the idle? In my case, the issue im having is that in order for rpms to be in the 700s or something acceptable, i have to have idle (in neutral and park) above 1k, now theres no problem with that, car drives and everything, the thing i dont like is that, shifting from park to drive or reverse it bangs into gear to hard (like neutral dropping), since the rpm out of gear it soo high. Now if I lower the rpm out of gear when i put it in gear it drops to like 500 which is too low, specially when i turn on the a/c. How did you go about this? im not using an IACV by the way, are you?
Old Feb 21, 2009 | 09:02 PM
PharoNDmist's Avatar
Congrats on the swap. Must be alot of fun with that power.
Old Feb 22, 2009 | 07:10 AM
grey99max's Avatar
Maybe someone else can help you with the idle - I don't use the IACV, even though it's connected to keep the ECU happy. My idle is set for 1,000 because of the cams and with the Edge 2800-stall TC, it's still quite drivable. Best guess is to hook up an IACV and see if you can make it idle.
but it's fun, isn't it ???
Old Feb 22, 2009 | 08:03 AM
Well I havent started having fun yet lol, I still gotta figure out a minor tps issue, its making the auto lock up the TC way to early like at 30mph before it even goes into 4th. Did hooking up the iacv make any change on the idle eventhough u dont really have it hooked up to the car?
Old Feb 22, 2009 | 01:34 PM
accordingtou's Avatar
VQ30 DE T
Sweet
Old Feb 22, 2009 | 03:27 PM
Kevlo911's Avatar
Kevlo for President
Hook up the IACV, it's not hard...
Nice looking flex plate
Old Feb 22, 2009 | 03:36 PM
Update, i just installed the 440 injectores, I had wired the front three wrong lol, car still ran though but i fixed it anyways. Ran the car at 5psi or so, and man it pulls nice, no tune yet, a/f was in the high 10's, im still on the plugs that came with the motor (they look alright, no major abuse, just the usual normal wear), tomorrow I might go ahead and get 1step colder plugs, and tune it a bit. As for the idle, its not too bad now, I gotta keep driving it, eventually it will fix itself (I remember with the 3.0 i had same issue with 00vi, and it fixed itself, i guess ecu has to go through its learning process etc.., i cleared the learning crap through my obd scanner, so we'll see)
Old Feb 22, 2009 | 04:03 PM
ahhhhhh yes... Cant wait for some vids
Old Feb 22, 2009 | 04:25 PM
SleepyMax1's Avatar
so your running 3.5 with boost on a auto tranny?? Any mods to the transmission?
Old Feb 22, 2009 | 04:27 PM
the tranny has same mods as the fastest maxima in the country, in other words, its a stock auto, with a cooler and synthetic atf, oh an drop restitor mod.
Old Feb 22, 2009 | 04:50 PM
SleepyMax1's Avatar
so no suprastick ??? very nice... keep a log on how long the tranny last. It would be nice to see it last longer than 6months. Congrats
Old Feb 22, 2009 | 05:39 PM
yea i got the suprastick too,
The auto is going to last more than 6months, you do know iv been abusing and putting more than 300whp and torque through the auto for a few years with no issues right? The auto will last as long as you want it too if you know how to treat it.
Old Feb 22, 2009 | 06:53 PM
matty's Avatar
Nice work man!!!!
45 psi of fuel pressure ??
Old Feb 22, 2009 | 07:05 PM
Originally Posted by matty
Nice work man!!!!
thanx, and yea 45psi why the "?"
Old Feb 22, 2009 | 07:32 PM
Macof2003's Avatar
good job bro, putting florida back on the map
ajcool2's Avatar
Congrats Streetz. Cant wait to get mine done.
Old Feb 22, 2009 | 08:25 PM
essential1's Avatar
My axles cry for mercy...
I knew you would switch over sooner or later. Good job.
But you still hold the title for the messiest engine bay in SoFla.
How long did it take you guys to swap the engine over from start to finish?
Old Feb 22, 2009 | 09:51 PM
Well the whole process was about 1month or more, thats counting getting the dek, finding that it was broken, then finding another engine (3.5), but actual like work, id say 4 to 5 days. One day i took off all the electrical, hoses, radiator, fan, etc.., then 2nd day came back for the bigger things, axle, alternator, compressor, etc.. another day to take out engine, i spent whole day on this one, i was alone but eventually got it out, then eddy came over, helpd me prep the 3.5, put oil pans, then put in the motor, next day, filled it with liquids, make injector connectore, tighten torque converter, etc... id say about a full week total.
Old Feb 22, 2009 | 09:55 PM
TJ_Max's Avatar
Paradox Systems Vendor
Good stuff. No rod bolts at the very least? You can change those with the engine in the car pretty easily. .
Old Feb 22, 2009 | 10:00 PM
TJ_Max's Avatar
My only guess is because the 3.5 fuel pressure is supposed to be at about 51psi at idle.
Old Feb 22, 2009 | 10:12 PM
95BLKMAX's Avatar
Don't need them. Power doesnt kill the rod bolts, revs do. And since he's keeping the stock redline there's no point in upgrading those. Stock work just fine up to 7100, so stock redline is no issue.
Not necessary really. Plenty of people run their swaps at lower than that. Personally I've always ran my engine (NA and boost) anywhere from 55-66psi for any number of reason at the time. Mainly to get the most indirect timing advance out of the piggyback
Old Feb 22, 2009 | 10:37 PM
VQphantom's Avatar
That is gonna be nasty. Congrats
Old Feb 23, 2009 | 11:02 AM
Thanx, another update lol, just put in new spark plugs, 1step colder, also found that the 440cc o rings seem to be leaking, you can see the base where injector meets lower IM wet around. I wonder what o rings would be best.
Also, i got rid of the VIAS, i cut the inside plate off, made the inside surface of the plate completly flat with a grinder, and plugged the hole with a screw and taflon, then grinded off the excess sticking inside.
Old Feb 23, 2009 | 12:11 PM
Aaron92SE's Avatar
NWP Engineering.com
Congrats! I'm surprised you made such quick progress with this swap! I'm glad it's running smoothly already.
Old Feb 23, 2009 | 07:36 PM
NiZMo1o1's Avatar
Big ups to SW !
Old Feb 24, 2009 | 01:14 PM
New pictures! just painted the cover a lil bit, so pretty!!
and for those that havent seen my new turbo,
Old Feb 24, 2009 | 01:18 PM
kzoosho's Avatar
awwe purty lol
Old Feb 24, 2009 | 03:13 PM
MaximaSpd85's Avatar
umm....u do realize slicks go on the fronts of these cars right??
Old Feb 24, 2009 | 03:15 PM
Aaron92SE's Avatar
NWP Engineering.com
I was thinking the same thing. Those are some pretty bald tires!
But nice setup Streetz!
Old Feb 24, 2009 | 03:16 PM
lol thanx, well I had to change those tires to the back, thats what 15psi of boost on the 3.0 did to the tires lol, im currently looking for a new set of tires ofcourse
