Kevlo RMT Turbo build -Works !!
Old Aug 19, 2009 | 04:09 PM
  #161
Kevlo911's Avatar
Kevlo for President
Alrighty so smoke might be from w/e is left in the muffler. I will give it a few days.
Tomorrow I go to 5-6psi and tune it to 11's AFR.
Old Aug 19, 2009 | 06:38 PM
  #162
maxgtr2000's Avatar
KH3 by popular demand
Are you going to spray the feed pipe and wrap it? Have you messed with the emanage yet or are you just letting the tuner do all that?
Originally Posted by Kevlo911
Slower than before before 4k
No 3" maf timing, mad rich so cant expect to be w/o tuning.
It is prob only at 2-3 psi lol so not much till tomorrow. I will up it to like 5-6psi. Then the party will begin
Lemme find the vid cam for tomorrow night
Old Aug 19, 2009 | 07:00 PM
  #163
Kevlo911's Avatar
Kevlo for President
I am the tuner
I am gonna wrap the bpipe all the way to the turbo once i get a new muffler. For now as is. Tomorrow the gauges should be here and then I will be able to up the boost to 5-6psi and then tune. Right now it is SUPER rich, I can get another 20+ hp out of the midrange just from AFR tuning.
Old Aug 20, 2009 | 07:17 AM
  #164
mtrai760's Avatar
'Trynna' is not a word
You know what's next.... 3.5, 3.5, 3.5, say it with me... 3.5, 3.5, 3.5....
Old Aug 20, 2009 | 07:19 AM
  #165
MDeezy's Avatar
exactly!
Old Aug 20, 2009 | 07:28 AM
  #166
Kevlo911's Avatar
Kevlo for President
****, VQ30 4lyfe! lol
I have ZERO money for the car now. Plus w/e money I do get Ima spend on partying and stuff. Gainesville = WOO WOO
Old Aug 20, 2009 | 07:57 AM
  #167
95BLKMAX's Avatar
Sir just so you know to expect it. This is a BIG *** COMPRESSOR. The higher you go in boost, the higher it will get into it's more efficient part of the compressor map (more power/psi).
On my 3.5, 1st pull at 6psi (pipes still a bit warm) it did 289whp. However, once the pipes got hot, and I did more tuning, and upped the boost to 9psi, the "effer" did 372whp and that was where the MAF maxed out. Look for my old dynos (I think around May or June 08). That thing was still climbing when the 3" MAF on 4th gen sensor just maxed out. Just to give you a reference as to the difference in HP/Psi as you move higher up in the boost with thie turbo.
Also check for exhaust and boost leaks. You are bound to have some and this could be attributing to your late spool up. Not to mention the fact that you still have to wrap the exhaust. Doing that alone not only yields much more power but also drastically decreases spool up time. For me it dropped a good 500-700rpm
Old Aug 20, 2009 | 08:09 AM
  #168
Kevlo911's Avatar
Kevlo for President
Yeah I don't have enough exhaust wrap to wrap it all the way to the turbo yet. I will do that as soon as I can. Today I will up the boost to about 6psi assuming my fuel setup can handle it. I did notice the more I pushed it today the faster it got. So the pipes def need to get wrapped.
Old Aug 20, 2009 | 09:34 AM
  #169
95BLKMAX's Avatar
I suggest you start wrapping from the engine to the turbo. The key here is to have the exhaust reach the turbo as hot as it is when it comes out of the engine. Which i coruse is physcially impossible but the wrap plays the big roll here
Old Aug 20, 2009 | 10:09 AM
  #170
MDeezy's Avatar
Did you spray and wrap your pipes?
I believe Defi..has a spray that you can either spray onto the pipes or spray onto the wrap it self after it is on, to further help with temps.
I'll see if I can find that old link...
Old Aug 20, 2009 | 10:58 AM
  #171
streetzlegend's Avatar
You have too!! the right way of doing it is cleaning the pipe and spraying a good coat on it (I used bbq grill spray, dry's fast and handles heat), then you wrap the pipe, then spray with the silicone spray they offer for the wrap by DEI.
Old Aug 20, 2009 | 12:31 PM
  #172
MDeezy's Avatar
Yea DEI!! I think that will supremely help with temps and spool. Clean, spray, wrap, then spray again.
Old Aug 20, 2009 | 01:37 PM
  #173
choray911's Avatar
The Crazy Azz Cracka
Very pimp'n!
Old Aug 20, 2009 | 03:17 PM
  #174
Kevlo911's Avatar
Kevlo for President
Found oil in my charge pipe:
One of two things, could be seals are bad which means a bad rebuild
Or I did not leave the pump running long enough after the car was off(now 2 min, was 1:20)
I am getting very mad bout this turbo/oil thing
Old Aug 20, 2009 | 04:05 PM
  #175
Dont worry man, its a process. Most likely is that you didnt let the pump run long enough, so oil leaked through the seals into the charge area. clean the pipes closes to the turbo, and drive it for about a week, put the timer at like 2:30min. (hope you have a good battery).
Oiling is the most frustrating part of doing a RMT setup, just be patient. Some troubleshooting and a few beers, and you should end up with a nice setup. put it to you this way, when i had the T04B i used to run the timer at like 3mins minimum. any lower and it will smoke at start up.
Old Aug 21, 2009 | 07:28 AM
  #176
Kevlo911's Avatar
Kevlo for President
So I went to go tune today, shifted from 2-3 at WOT. 3psi of boost. and it goes BOOOOOOOOOOOOOOOOOOOOOOOOOOOSHHHHHHHHHHHHHHhh
You will never guess what happened!!!! The damn compressor housing blew off the turbo! So I hope there is no damage to the blades but I doubt it. I am gonna put on my other turbo.
What is acceptable shaft play?
Old Aug 21, 2009 | 07:41 AM
  #177
Kevlo911's Avatar
Kevlo for President
Can I use the turbine housing from the "bad" turbo? It already has the wastegate welded shut.
  #178
choray911's Avatar
REFUND!!!
Old Aug 21, 2009 | 07:58 AM
  #179
nismomaxct's Avatar
How much will you have to spend to get a new turbo? Just let me know and I will pay for it. I am so sorry for all the issues that you have. That turbo was rebuilt a few weeks before I sold you the kit so I am somewhat confused as to why this happened. The only thing I can think off is that the shop did not balance the turbo properly. Just let me know how much for the new one?
Old Aug 21, 2009 | 08:02 AM
  #180
Kevlo911's Avatar
Kevlo for President
I have another spare one right now that im bout to get put on, I will let you know later tonight thru pm's.
Old Aug 21, 2009 | 10:12 AM
  #181
Kevlo911's Avatar
Kevlo for President
Lol now one of the bolts head stripped off the turbo housing on the new turbo!
AWESOME! lol
  #182
Kevlo911's Avatar
Kevlo for President
Can I use the turbine off the old turbo?
Old Aug 21, 2009 | 02:43 PM
  #183
tibal's Avatar
damnn, not having best of luck, what condition is the turbine of the old turbo in?
Old Aug 21, 2009 | 04:37 PM
  #184
Yea you can use the turbine, shouldn't be a problem. thats crazy man, was it cuz the housing wasnt tightened enough?
Old Aug 21, 2009 | 06:00 PM
  #185
DAVE Sz's Avatar
Hooooooonda.....
Damn Mr. Patel, seems when **** rains on you, it effin pours....
Old Aug 21, 2009 | 07:26 PM
  #186
Kevlo911's Avatar
Kevlo for President
Lol man, the other turbo I have has bad seals!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! lol it smokes when it is warmed up. I am gonna buy a "new" turbo and if that doesnt do it ima take it all out.
I spent HOURS today putting it all together what a pain in the *** man. Im so tired dunno what to do since I gotta go back to gainesville tomorrow.
Old Aug 22, 2009 | 07:39 AM
  #187
Kevlo911's Avatar
Kevlo for President
Anything I can do to stop this thing from smoking? How bad will it be if I stop it from getting oil? I just wanna get back to school w/o smoking up the interstate. I don't wanna take it off cuz it will be too loud open muffler.
Old Aug 22, 2009 | 08:25 AM
  #188
kzoosho's Avatar
If you stop oiling it bro it will stop spinning period. It wouldnt take long to completely fry it either. If you can try to limit a little more oil going to it but dont stop it from getting oil.
Old Aug 22, 2009 | 12:06 PM
  #189
Kevlo911's Avatar
Kevlo for President
Since I had that extra turbine housing, I welded one of those roundish electrical box plate covers on the side and used it as a giant flange to connect to the turbo. I put my filter on the front and now I am back to NA. Now im on the hunt for an 18 back of beer and a new turbo.
I will keep you guys updated and show which turbo ima buy before I buy it
Old Aug 22, 2009 | 12:39 PM
  #190
MOHFpro90's Avatar
this.
Orlando sucks the big one for parties...
By the way, it looks like I will be in Daytona this semester. If you need any help let me know. No classes to speak of and no job yet (working on that though)... So yeah...
Good luck man, hope you can get a new turbo soon!
Old Aug 22, 2009 | 01:57 PM
  #191
Quickywd01's Avatar
How's that maf adapter working? I need one for my sc setup.
That is a 240sx maf adapter, I will let you know if it fits perfectly(they are only like 10 shipped so it will save a bunch of money compared to "maxima specific" ones)
Old Aug 22, 2009 | 05:07 PM
  #192
Kevlo911's Avatar
Kevlo for President
Doesnt bolt on to a 4th gen maf, just gotta drill new holes. No biggie, it is really nice and thick so it is worth the 10 bucks.
So I dont even wanna tell yall what happened on the way here. I lost all my oil but the engine is still running strong thank god
Old Aug 22, 2009 | 06:03 PM
  #193
Old Aug 22, 2009 | 06:25 PM
  #194
MOHFpro90's Avatar
h****:
Old Aug 22, 2009 | 07:15 PM
  #195
Kevlo911's Avatar
Kevlo for President
Engine running strong. Scary **** tho man. Oil feed line broke, leaked all the oil out on the interstate. I had to fix it at a small *** town with 2 gas stations. But I did and the car turned on fine luckily. Man I've been thru hell, makes me wanna keep NA but I am buying a NEW turbo so hopefully that will do it all. I never been thru so much with this car. I am really lucky the engine didn't seize, but it was only for less than 1 min with the oil light on. VQ30 is pretty amazing since most people say it is too late when the oil light comes on
Old Aug 22, 2009 | 08:02 PM
  #196
tibal's Avatar
thats great to hear that u made it safe! Thats scary stuff right there!
Old Aug 22, 2009 | 09:15 PM
  #197
maxgtr2000's Avatar
Full synthetic ftw!!
Old Aug 23, 2009 | 09:08 AM
  #198
MOHFpro90's Avatar
Was you goin down I10 or somethin? lol
Old Aug 23, 2009 | 10:50 AM
  #199
Kevlo911's Avatar
Kevlo for President
Yeah man lol 10 miles from my place! I was LUCKY it happened half a mile from the exit
Old Aug 23, 2009 | 11:02 AM
  #200
ibag8rfan's Avatar
damn kevin.. lol
