v1 supercharger.
v1 supercharger.
Okay guys I Just got finished in stalling my v1 supercharger, now my question is, how in the world do we tighten the tensioner pulley, I cant seem to get down there with the blower in the way. I sorta got it a little tight.. Also the belt is like super close to the top of the tensioner pulley adjuster. Is it suppose to be like that or did I mess something up?
Did you get your kit used? Did it come with the modified tensioner pulley set up? If you do have that then it is not too hard. Make sure the center nut has been loosened on the tensioner pulley (just remember to tighten it back once you are done) then just tighten it up just like normal.
Hmm.. Doesn't the V1 use the stock tensioner pulley?
I adjust mine with a socket wrench and long extension bar with a swivel joint on the end. You cant get to it dead on straight. You need to come at it on an angle - hence the swivel joint.
When I had the blower of earlier this year I grinded down that area a bit, not a socket goes right onto the tensioner.
just sit in the fs thread for forced interduction i would do a compression check and put money in the struts and replace all your bushings make sure the car is up to par before you take the task of s/c ur car
Here are some recent sales. Be warned, once you see it you will want it.
http://forums.maxima.org/forced-indu...etup-sale.html
http://forums.maxima.org/forced-indu...es-1900-a.html
http://forums.maxima.org/forced-indu...onversion.html
http://forums.maxima.org/forced-indu...1-bracket.html
http://forums.maxima.org/forced-indu...cessories.html
http://forums.maxima.org/forced-indu...tuff-sale.html
http://forums.maxima.org/forced-indu...en-v2-kit.html
there is nothing better than driving a boosted maxima. You see, if you drive something that your grandma would comfortably get into without hassle, it adds to the element of surprise
Midnight_Speed
Nov 23, 2002 08:08 PM
