where to get vq30det
Old Sep 21, 2011 | 07:00 PM
sc10692's Avatar
I've been looking for one for a while and have had no luck, all the ones I've seen are motor only and im looking for harness&ecu aswell(its going in a 240). So where do the few of you guys running them get them?
Thanks,
Shayne
Old Sep 21, 2011 | 10:19 PM
Nealoc187's Avatar
SLOW
overnighted from japan. they decimate all. not cheap though, 10 grand, maybe more.
Old Sep 22, 2011 | 09:08 AM
sc10692's Avatar
Well then it's a good thing I re-enforced my floorboards, but seriously though anybody wanna chime in?
Old Sep 22, 2011 | 09:56 AM
Quickywd01's Avatar
He is being serious, well maybe not the last bit. lol But I've seen a stock internal VQ30 make 500hp so you don't need a vq30dett. Do a little research and you might rethink your plan, it'd be a whole lot cheaper too.
Old Sep 22, 2011 | 11:39 AM
aackshun's Avatar
There's one FS locally in Houston, TX, would you be willing to cover shipping cost? Or pick up?
Old Sep 22, 2011 | 12:28 PM
From God, if you're lucky..
Old Sep 22, 2011 | 04:43 PM
kasso's Avatar
I just saw one on ebay
Old Sep 22, 2011 | 05:02 PM
2000_MAXIMA_KING's Avatar
http://cgi.ebay.com/ebaymotors/JDM-9...item4cfa27e066
Old Sep 22, 2011 | 05:09 PM
streetzlegend's Avatar
Eeek for that much you can get a used high mile VQ30 for like 200-300 bucks, get rods and pistons, head bolts and u got a 700hp engine
Old Sep 22, 2011 | 07:42 PM
sc10692's Avatar
Do you know if its a neo or earlier and how much? and who is selling it?
Thanks,
Shayne
Old Sep 23, 2011 | 06:24 AM
aackshun's Avatar
Thanks,
Shayne
I have noo idea, but if you're really serious about it I will contact him for details.
Funny you said that....
The seller is BLKonBLK98, well known member around the 4th gen community.
http://forums.maxima.org/4th-generat...-part-out.html
Old Sep 23, 2011 | 11:45 AM
sc10692's Avatar
Thanks but that's just the motor.I wanted harness and ecu as well, seems like the money would be better spent on a fwd 3.5
Shayne
Old Sep 23, 2011 | 04:27 PM
Quickywd01's Avatar
Shhh. If everyone finds out they won't be cheap anymore. Tell him to put a LS1 in there instead, it's a 240 after all.
Old Sep 23, 2011 | 05:08 PM
QT1 5MT AE's Avatar
Gram Lights addict
out of all the possible engines that can be swapped into this platform you choose to go with the needle in a haystack? why dont you drop in an RB, JZ, LS or VQ37 or something?
Old Oct 2, 2011 | 03:04 PM
HomerMAC's Avatar
Donating i30 Owner
Shayne
.. Your stock ECU will run a DE-T. not well but it will run enough to drive the car around town. Also your stock harness and everything down to the TPS sensor is same as the 3.0DE. You will need a Emanage or AEM piggyback to go into good boost.
If it is to mount in a FWD configuration your best bet is to just use a maxima 3.0DE with the DET internal.
at the end of the day, you can get reliable 350+hp from 3.0DE and upto 500hp with good tuning. All that is really special about the DET is lower compression, better intake manifold and additional oil within the engine.
This below is a DEK with DE-T manifold/inejctors/MAF. It ran great. worked off my 96 ECU . started , ran and drove like a stock car. then I used e-manage ultimate to fine tune. But the 370cc inj. and z32 MAF was a great base tune. only leaning out a bit at top. It worked better than a DEK swap in terms of idle etc.
You can even mount the FWD 3.0DE in rear wheel configuration such as 240sx with the 5spd z32 trans or 6spd z33 trans.
Old Oct 2, 2011 | 03:16 PM
QT1 5MT AE's Avatar
Gram Lights addict
HomerMAC for president
CaTalyst.X
Dec 23, 2008 12:11 PM
CaTalyst.X
Dec 14, 2008 01:48 PM
95turbo gxe
Sep 25, 2007 06:26 PM
Emtx
Dec 29, 2005 10:47 AM
MAXXspeed18
Aug 18, 2002 09:25 AM
