4th gen dek turbo setup/ questions
Old Aug 19, 2012 | 08:26 PM
  #41
maxgtr2000's Avatar
KH3 by popular demand
It won't blow if it is tuned right, a conservative tune, proper timing pulled and you should be good, for added safety get a methanol kit, it will add a few hp also, they are on ebay for about $200 shipped for a budget one.
Old Aug 20, 2012 | 08:22 AM
  #42
tsheffler's Avatar
I don't have anything to pull timing... I'm on Safc and jwt, i have an e manage blue but damn I've hacked into the harness so many times already lol
Old Aug 20, 2012 | 10:44 AM
  #43
t6378tp's Avatar
Turbo 3.5
the jwt ecu should already have altered timing. They come with 10degree standard, 16 with a 100octane map and anything more has to be requested
Btw if you have the standard tune you'll need the 14psi spring to make decent power
Old Aug 20, 2012 | 05:33 PM
  #44
tsheffler's Avatar
14 psi is kinda much for stock everything i think, i don't even have head bolts/gasket. So well see, I'll stay with 9 and see how it goes
Old Feb 12, 2013 | 01:40 PM
  #45
JDweeds's Avatar
A little late lol but I just joined the forum not long ago. How is the turbo build coming along? 13-14 psi peak is fine on a stock DE-K with a proper tune.... it wont hold 14#s the entire rev range anyway so it shouldnt be much of a strain as long as the internals are in decent condition to begin with. I ran 13.5#s off a JWT/SAFC2 tuned setup for upwards of 50 all out 1/4 mile passes and 15-18k street miles with zero issues before I tore into the engine at all. Afterwards with ported heads and Fel Pro MLS gaskets, JWT Cams and SSIM but the same stock longblock, I run 15psi and will probably go up to 16-17 this summer once my sheetmetal upper is fabbed and on my new trans and axles, but now will be tuned on a Greddy EMU. Just my two cents.
Cotozic
Jun 28, 2017 08:01 PM
Finkle
Sep 27, 2015 09:53 PM
max_speed97
Aug 26, 2015 07:46 PM
MikesChevelle
Aug 10, 2015 10:53 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
