anyone running 225 tires (particularly fronts)?
Old Sep 29, 2003 | 08:40 AM
Roman-dude's Avatar
I am thinking of putting 225/60-15 on my stock alloy rims (which seem to be able to accomodate them). Spoke with the installer who said that while they will fit, there is a chance the fronts will rub the arch on turns. I am going to see him to test if that will actually happen, but before I do I wanted to know if anyone has a similar set up and has or does not have any issues with it.
thanks
Old Sep 29, 2003 | 08:45 AM
ivelweyz
Why would you want to do that? Do all 4 tires the same size and I would't go more than 215 on stock 15s. There are some that have 225 on the sawblades, but 225 are more for 7" rims than 6.5"...
Old Sep 29, 2003 | 09:04 AM
Roman-dude's Avatar
I am putting all 4 the same size, I referenced the fronts since the rears don't turn... from what i see at tirerack.com some of the 225/60-15 are for 6.5"...
btw, what are the sawblades?
thanks
Old Sep 29, 2003 | 09:15 AM
maxspeed96CT's Avatar
The original VQ...
depending on your rim size you can fit up to 235s without changing anything, on the stock 16' s wheels you can have 225s, and i also have a 1.5 rop.
Old Sep 29, 2003 | 09:23 AM
Roman-dude's Avatar
the wheels are 15", the rims are 6.5", original tires are "205/65-15" and the calculators say 225/60-15 have almost the same circumference
thanks
Old Sep 29, 2003 | 10:19 AM
felix's Avatar
Sittin' On Chrome
I run on 225/40/18 and they don't rub at all.
Old Sep 29, 2003 | 07:17 PM
Roman-dude's Avatar
would the fact that i'd be running 225's on 15 and not 18 make a difference?
thanks
homeyclaus
Sep 3, 2015 06:15 PM
FlaMark
Aug 21, 2015 11:06 AM
twotonezed
Aug 16, 2015 11:41 AM
mls277
Aug 11, 2015 07:18 PM
jholley
Aug 11, 2015 09:38 AM
