245/40-18 vs. 235/45-18
I used Dannys tire size calculator and determined that the 245/40-18 was nearly identical in radius, diameter, circumf. & revs/miles as the stock 235/50-17. I went on-line with tirerack.com and the site recommended the 235/45-18 for my 2002 SE. The numbers are close for the 235/45 but not as close as the 245/40's.
Isn't the 245/40's the better fit to keep the speedo and such accurate? Will the 245/40's fit my car? tirerack.com has only 3 choices in the 235/45 size, but has 38 choices in the 245/40 size.
![](https://maxima.org/forums/images/smilies/support.gif)
What's the width of your wheels? 18X8? 18X8.5? or 18X7.5? I would go with 245/40/ZR18 if your wheels is bigger than 18X8.
ajaffee
03-15-2001 11:20 AM
