Tire pressure (96 GLE)
Old Jan 24, 2004 | 09:39 PM
Chino's Avatar
The sticker that indicates the appropriate tire pressure level on the driver's side door pillar is smuged horribly. What does it say? Thx
Old Jan 24, 2004 | 09:53 PM
myke321's Avatar
Doesnt it depend on the kinda of tires you have?
Old Jan 24, 2004 | 09:58 PM
MaximaEvolution's Avatar
Regardless of what the door panel sticker says, each tire has a PSI rating right on the sidewall. They may not be the original tires, therefore you will have to look on the tire.
Old Jan 24, 2004 | 10:03 PM
Chino's Avatar
I'll have to check in the morning. I have Flankens 205 60 ZE R15s on stock honeycomb GLE rims like MaximaEvolution's. I'll still ultimately check what the tire says tomorrow. BTW how wide are the Honeycomb GLE rims?
Old Jan 24, 2004 | 10:07 PM
rwatt1981's Avatar
for my 98 with 15" wheels...they recommend 32psi front and 29psi rear.
Old Jan 24, 2004 | 10:10 PM
Chino's Avatar
Who is "they"?
Old Jan 24, 2004 | 10:23 PM
I think the stock 15" honey's are 6.5" wide. I'm not positive.
Old Jan 24, 2004 | 10:38 PM
JeEvE's Avatar
I have some cheap tires on the stock 16'"s....had them when I bought the car. On the tire is says 44psi cold, how much should I put in?
Old Jan 24, 2004 | 10:40 PM
If the tire says 44PSI cold, then put in 44PSI cold.
Old Jan 24, 2004 | 10:55 PM
Broaner's Avatar
2060lbs and falling...
I also think the honeycombs are 6.5". Yeah my tire is rated for 44PSI also.
Old Jan 25, 2004 | 01:58 PM
Bman's Avatar
No, no, NO! You always follow the door sticker on the car (or look in the owner's manual) for tire inflation pressures as long as the tires are in the original (or close) size.
People are always saying things like "Nissan didn't make the tires, so they shouldn't dictate the pressure!!!!", but that is not how it works. The pressure on the tire sidewall is the MAXIMUM pressure that the tire is rated for, not what you should put in it. I am still amazed that even in this day and age people still think that you look on the tire to find the correct pressure....
Old Jan 27, 2004 | 10:15 AM
95Max's Avatar
GLE stock is 29 all around
240tomax
Tires and Wheels
Feb 10, 2016 11:01 PM
Excalibur23
Oct 13, 2015 04:33 PM
Serotta33
Sep 17, 2015 12:14 PM
jfl330
Sep 4, 2015 01:44 PM
