Should I get 235 or 245?
Old Aug 26, 2004 | 09:01 PM
Hunter11's Avatar
Just to make sure, I want to know what size tires I should get.
What I have now are Evo5 that have a +40mm offset they are 8in wide and my tire is 225/40r18. I have Sprint springs and no rubbing at all.
What I want are Italia Inox that are 19x8.5 that have a +38mm offset.
Should I get 235/35 or 245/35? Should I worry about rubbing with the 245?
I am about to get them so I just need to know what size would be best.
Old Aug 26, 2004 | 09:39 PM
VIP Maxima
245...........
Old Aug 26, 2004 | 09:55 PM
elchino's Avatar
Yeah that tire seems thin. 02 SE stockers are 7 in wide and we run 225. So if you go to 8 in wide, it makes sense 245 would fit well. (The 20 mm increase in tire width is a little less than the 1 inch increase in wheel width.)
Old Aug 28, 2004 | 09:54 PM
ZeRo MaX's Avatar
i have a similar question... but i think it's already answered...
19x8 rims with a 45 mm offset should have a 245/235/19 tires?
am i correct? or will i rub?
Thanx!
Bob_Jaap
Aug 23, 2001 11:30 PM
nizmomx
May 19, 2001 12:11 PM
tomI30
Feb 26, 2001 01:57 PM
