Wheel specs
Old Mar 13, 2005 | 08:27 PM
NismoMax80's Avatar
SuPeRmOd
Wheel specs
2004-2006 OEM:
SE
size: 18" x 7.5"
offset: 40mm
bolt pattern: 5x114.3
tires: 245/45-18 V-rated
PSI: 32 Cold
SL
size: 17" x 7"
offset: 35mm
tires: 225/55-17 H-rated
PSI: 33 Cold
recomended upgrades:
size: 19" x 8.5"
offset: 35??mm
tires: 245/40-19 V-rated or higher
PSI: ??? Cold
size: 20" x 8.5"
offset: 40?mm
tires: 245/35-20 V-rated or higher
PSI: 30? Cold
size: 20" x 10" REAR ONLY
offset: 42mm
tires: 255/35-20 V-rated or higher
PSI: ? Cold
size: 22 x 9.5"
offset: 35mm
tires: 255/30-22 V-rated or higher
PSI: ? Cold
Tire Size Calculator
Tire Size Calculator 2
Offset
Old May 8, 2006 | 11:58 PM
po8pimp's Avatar
if you are looking to upgrade those horrible tread wearing stock tires..... I highly recommend the All season ultra high preformance continentals...... I bought these tires last year and put at least 15,000 miles on them including drag racing and hard driving auto crosses and other rediculous wear and tear events..... and I have a whole lot of life in them.... however I do not recommend siping your tires if you plan to do any of the above..... I had my tires siped and well I found out quickly how that was a bad idea..... the rubber grips so hard sometimes that it rips chunks out of the tire.... so don't sipe them unless you plan to cruise and what not.... siping gives you twice the gripping ability.... I got all 4 tires with siping and lifetime replacement up to an eighth in of tread for $945 at discount tires..... unlimited tire repair for nails and such and unlimited tire rotations and unlimited tire balancing for the life of the tires..... really great deal if you ask me.....
Old May 19, 2006 | 02:57 PM
queenzkid's Avatar
Hubcentric Rings And Centerbore Size
What about the size of the centerbore and hubcentric rings?
See 1010tire.com for information regarding this. I don't believe these aftermarket wheel websites are including this. Which means we are putting wheels on that doesn't fit the centerbore, which means the rims are riding on the lugs alone rather than the centerbore. The information specifically says that if the wheels are not 'hubcentric', you will have vibration!
Is this something that is minor or are we missing the big boat? No wheel shop has ever brought this to my attention as to a reason for vibration. Are the tire shops just careless or am I stressing over nothing?
Old Jun 14, 2006 | 05:20 PM
NismoMax80's Avatar
SuPeRmOd
hubcentric rings are 66.1mm for Nissans
Old Dec 8, 2006 | 03:01 AM
povartrader's Avatar
Is it a bad idea to use spacers to make rims of other sizes fit ours? Ex. using a spacer for 5x120 to fit our 5x114.3
Old Dec 8, 2006 | 06:49 AM
NmexMAX's Avatar
dot dot dot ...
No wheel weights no care
Good work :thumbsup
Old Aug 9, 2007 | 12:20 PM
illanoize's Avatar
about 20/10
is this thread for sure about the 20/10,s just dont wanna get them and they rub. Also will my rim on the rear be sticking out.
Old Aug 23, 2007 | 01:55 PM
NismoMax80's Avatar
SuPeRmOd
someone has them (not sure) and said they fit. Use the calculators to check. My opinion they may stick out some and if so they will rub. an offset calculator will help u decide better.
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
KabirUTA13
19
Oct 17, 2015 02:15 AM
240tomax
Sep 13, 2015 03:28 PM
dcam0326
Sep 8, 2015 11:02 PM
