View Poll Results: How wide should I go on 18s?
235/40
23.68%
245/40
29
76.32%
255/40
0%
Voters: 38. You may not vote on this poll
How Wide To Go On 18s?
Old Apr 4, 2005 | 04:08 PM
mnm_maxi's Avatar
I just got a set of 18x8 Mille Miglia EVO5s, how wide of tires should I get for my 2000 SE?
Old Apr 4, 2005 | 04:13 PM
mclee45's Avatar
I say go with 255/45/18s... Thats what i got
Old Apr 4, 2005 | 04:14 PM
NYPD-Arnold's Avatar
Z
255 has a high chance of rub. 245 has a chance. 235 won't. Now, 235/40 is out of spec a little. While the other two (especially 245) are close to spec. There's a number of people who run 245/40 without problems. So that's my vote.
Old Apr 4, 2005 | 04:17 PM
2000 Maximus's Avatar
yea i would def go with 245's with those rims that size
Awsome rims though
good luck
Old Apr 4, 2005 | 04:23 PM
brettb's Avatar
O'rly
245/40 is on my 18's no rubbing.
Old Apr 4, 2005 | 04:26 PM
Rob01ski
I have 245/45 on my hp evos, and when i hit a bump my back tires rub, i was wondering is your car lowered?, im getting 225/40 for that low profile look, cause now it kind of looks like a tractor.
Old Apr 4, 2005 | 04:51 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
What's the difference between 215/225/235/etc...?
Old Apr 4, 2005 | 05:34 PM
Rob01ski
The difference between 215/225/235 is that is the width of the tire not sure in which measure inches or metric for instance 225/40/18 the 225 is the width of the tire, the 40 is the heigth of the tire and 18 is the radius, to explain height easier it basically from the lip of your rim to the top of the tire, if anyone else can explain this better please do.
Old Apr 4, 2005 | 06:42 PM
MoCoMax's Avatar
I ran 245/40-18 on the same wheels and the same car with no rubbing whatsoever. The car was dropped, but not slammed (Maxspeeds). The biggest problem with the Mille Miglia wheels is how soft they are. I trashed 2 on one pothole, a third two days later. I chucked the damn things and replaced them with SSR's.
The only thing you will notice with the 245's over the stock tires is that the car will tend to follow road imperfections, and torque steer tends to be exaggerated some. Other than that, no problems at all.
Old Apr 4, 2005 | 06:47 PM
5 spd's Avatar
245/40r18
245 = width in millimetres
40 = 40% of the width (which is the height of the tire from the rim to the outside edge)
18 = size of rim/wheel
Old Apr 4, 2005 | 07:01 PM
Bluesbrekr's Avatar
Doctorate in Detailing
245x40 on my HP Evo Lightnings. Maxspeed springs....no problems at all.
Old Apr 4, 2005 | 07:24 PM
maximillien's Avatar
im running 245 for the rear now and it lines up with the body NICELY! not sticking out at all, although I cant say for the fronts....
Old Apr 4, 2005 | 09:05 PM
SEmy2K2go's Avatar
Go BUCKS!!!
245/40 would be my suggestion.
Old Apr 4, 2005 | 09:09 PM
Lumbee1's Avatar
235/40/18's for me. I don't see the point in going larger. BTW 255's look ugly on an 8" wheel.
Old Apr 4, 2005 | 09:16 PM
ZIPPIN's Avatar
Mauja He Mauja
wider is better
just kidding
Old Apr 5, 2005 | 10:31 AM
NISMAX03's Avatar
I have the 18" G35C rims with the stock tires (245/45 rear and 225/45 front) I would like to go with 245/40 all around but the rims have a 30 mm offset. I believe that size would be too wide for the front. Is this correct or not?
Old Apr 5, 2005 | 12:18 PM
whazzzzuup's Avatar
I used to run 235s on my 18x8 Falken Torque 5 wheels. I think my current tire (245) is closer to stock circumfrence.
Old Apr 5, 2005 | 02:03 PM
Playero's Avatar
Sanduguero
in my opinion 245-40-18 will look nice once you go 245-45-18 thats when it looks out proportion to me....
Old Apr 5, 2005 | 05:16 PM
theMax's Avatar
Originally Posted by Rob01ski
I have 245/45 on my hp evos, and when i hit a bump my back tires rub, i.
Whats your offset. A lower offset may help you run wider tires.
Triple8Sol's Avatar
I miss the .org!
235 width on an 8" wide rim. This belongs in the Wheels/Tires forum anyways, where this question has been answered countless times...
Old Apr 5, 2005 | 08:20 PM
Ammi's Avatar
350 Detroit Muscle
you'll be fine w/ 245s
Old Apr 6, 2005 | 04:56 AM
Doc's Avatar
Doc
Just curious, not being wise here, but how can 235's be out of spec when that is the recommended size for 18" rims on our cars?
Old Apr 6, 2005 | 05:00 AM
Doc's Avatar
Doc
Sorry, let me correct myself. I guess this thread began in the 5th gen room and got moved here looking at the cars you guys are referring to. 235's would be on target for my 4th gen. I guess there are slightly different specs for the 5th gens.
Old Apr 6, 2005 | 07:16 PM
mnm_maxi's Avatar
Majority rules.
Looks like I'm going to end up getting a set of Falken Ziex 512 245/40/18s, best of both worlds. I pondered about getting the 255s but decided I should stick with the 245s. Thanks for all your votes.
Old Apr 8, 2005 | 10:06 PM
samssen's Avatar
I have Nismo Wheels 18 x 8.5 offset +25 front and +30 rear. BF Goodrich TA KDW 45/40/18 front & 275/40/18 rear. No rub so far.
Old Apr 9, 2005 | 12:40 AM
whazzzzuup's Avatar
You can't link the picture directly from your computer. You have to upload the picture first. I want to see it.
Old Apr 9, 2005 | 05:35 AM
Ammi's Avatar
350 Detroit Muscle
I would also like to see how you dont rub w/ that setup
Old Apr 10, 2005 | 08:51 PM
samssen's Avatar
[QUOTE=samssen]I have Nismo Wheels 18 x 8.5 offset +25 front and +30 rear. BF Goodrich TA KDW 45/40/18 front & 275/40/18 rear. No rub so far.
Typing mistake: rear 245/40/18
my bad.....
Old Apr 11, 2005 | 02:51 PM
pearlywhite2k's Avatar
Do you think I can rock 245 with my 18's, only catch is they are 7.5 wide not 8. Right now im rockin 235 but just curious.
Old Apr 11, 2005 | 07:20 PM
Ammi's Avatar
350 Detroit Muscle
You can but not recommended by many tire manufacturers
Old Apr 12, 2005 | 04:10 PM
Epacy's Avatar
Unsuccesful STL Coordinator
Not so. Go find a calculator and check the difference from spec.
02PearlSE
Oct 7, 2015 02:12 AM
DBear
Sep 14, 2015 08:33 PM
MidnightMaxima_22
Aug 18, 2015 09:36 PM
jhontelj
Aug 17, 2015 04:07 AM
ericdwong
Feb 21, 2001 09:16 AM
