Wheels/tires Sticky? G35 wheels on maximas
Old Jun 11, 2007 | 07:23 PM
  #481
Nyarlathotep's Avatar
thanks guys.
Old Jun 13, 2007 | 02:43 PM
  #482
freddorais's Avatar
Hi , there as you can see i am a newb member and need some help, i own a stock nissan maxima 2000 GXE
I just got from a friend of mine a set of rim from an Lexus IS300 17" x 7"
The bolt pattern are the same , i found lugs nuts that can fit , my only concern is about the offset , those rims seems to be 50mm offset , will they fit , do i need spacer or any other tools , please help me out as i want to get my ugly OEM rims to trash.
thank you for your help
Old Jun 14, 2007 | 07:26 PM
  #483
Steve68's Avatar
Irish great thread! you car looks great and thanks for the info!!
Old Jun 14, 2007 | 07:42 PM
  #484
irish44j's Avatar
retired moderator
you'll probably want a 15-20mm spacer. Make sure you get an H&R hubcentric set with extended lugs, by the way.
Old Jun 17, 2007 | 03:24 PM
  #485
guod's Avatar
i love the g35 wheels. i am liking that the maxima shares so much with infiniti line..
Old Jun 28, 2007 | 01:14 PM
  #486
02Maximan's Avatar
newer style 17" g35
Hi I was wondering if anyone has put the 17 inch g35 wheels such as whats installed on this car: http://cgi.ebay.com/ebaymotors/2006-...QQcmdZViewItem
I know that the 03-04 17s are quite popular (what irish has) but I haven't seen any maximas with the newer style 17's on. They're basically like the 18's but are in 17inch. Anyone have these? I've read in this sticky quite a bit and searched so pardon me if I missed it. Any pictures?
Old Jun 29, 2007 | 05:05 AM
  #487
SilverGLE's Avatar
I'm watching you, boy...
I've seen one .orger with the 17's... He had them for sale months ago. They fit fine, but I have no info on the width or offset. Of course, I prefer the 18's...
Old Jun 29, 2007 | 06:09 AM
  #488
02Maximan's Avatar
yeah I like the looks of the 18's better also, but I wondered if I would be sacrificing ride quality with larger wheels with less sidewall. Thats why I wanted to stick to something 17 inch. I think they look good but i'm wondereing how close they just look like GLE wheels?
Old Jul 2, 2007 | 06:06 PM
  #489
02Maximan's Avatar
Anyone have any more thoughts about these wheels?
Old Jul 2, 2007 | 08:21 PM
  #490
irish44j's Avatar
retired moderator
they should fit fine. I believe that they are 17x7 though with a 40-42 offset, so aside from looks they aren't an upgrade in width or stance, as opposed to:
the 18's (8" wide with 30 offset) or the coupe 17's (stagger 7.5"f 8"r with 30/33 offset), both of which allow wider tires and a wider stance due to offset.
If you're just going for looks and want to re-use the tires off your OEM 17's, the wheels in the link should work well though.
Old Jul 3, 2007 | 06:53 AM
  #491
02Maximan's Avatar
Ok thanks man. I was wondering the numbers on these an it looks like you gave em to me. just what I was looking for. thanks
Old Jul 4, 2007 | 04:30 PM
  #492
SilverGLE's Avatar
I know it's been discussed before, but has anybody tried the new replica's on ebay from O E Wheels? They have 2 styles, "hypersilver" (which I believe is as close to OEM as possible), and "anthracite." Both are now 18" x 8". I've thought about picking up a set of these, as my are fairly scratched and could use a fresh start! I've checked out their rep on other forums and people seem to be fairly satisfied with their quality...
Old Jul 5, 2007 | 06:28 AM
  #493
2slow4u's Avatar
if you do the 350z Track wheels 8" in the front and 8.5" in the rear wont this cause issues w/ rotations and wear? Is it possible to utlize 4 of the front wheels of this car all the way around to be able to rotate the tires and keep life up on the tires? Just wanna make sure the fronts will fit as well (on the rear)?
Old Jul 5, 2007 | 09:04 AM
  #494
00MaxSE's Avatar
Pointy Elbows
You can use 4 fronts or 4 rears. I have the staggered setup and I guess I could rotate them F to R if i wanted to.
Old Jul 9, 2007 | 09:52 AM
  #495
hoya7127's Avatar
Hey, I just got the 18inch coupe wheels refinished and put on my 6th gen. Looks a bit smaill, would've preferred 19's. Got them refinished at Wheels America, paint looks really similar to the original.
Old Jul 11, 2007 | 06:30 PM
  #496
Padoora's Avatar
I just got the G35c wheels for my car and unfortunately the 245's in the back rub with people or over deep bumps, the car has more road noise, and the handling gets weird over bumps at times (strange wiggly feeling). Maybe i'm just **** here, but I have feeling it was a bad choice, or maybe I just need new tires 235-40-18???? Also, the 225's in the front really look funny like it has too much rim for the tire. How do the 235's look? ride?
Old Jul 12, 2007 | 08:23 PM
  #497
irish44j's Avatar
retired moderator
read the thread. 235/40/18 is the correct size to not rub.....245/40/18 might also work, but will be close. The 245/45/18 that come with the G are too large.
235/40/18 in sig, by the way.
Old Jul 13, 2007 | 08:09 AM
  #498
Padoora's Avatar
235-40-18 question.
Irish...Thank you.
But another thing I noticed is that the 225-45's on the front gives it a too much rim for tire look. In other words, the tires seem to narrow for the rim. The 245-45's look ok and full in the back, Just curious on how the 235-40's would look before I go and spend any more money. If they end up looking like the fronts(225-45) right now, I wouldn't get them. I in need of a nice uniform look all the way around. This staggered look just doesn't flow on maxima's. I've seen the side view on yours and others, but it's really hard to tell, I'd like to see a side close up view...Anyone??
Old Jul 13, 2007 | 06:25 PM
  #499
irish44j's Avatar
retired moderator
Irish...Thank you.
235/40 are about the same width as the rim, as you can see here.
Old Jul 13, 2007 | 09:39 PM
  #500
Padoora's Avatar
[QUOTE=irish44j]235/40 are about the same width as the rim, as you can see here.
QUOTE]
Thanks. From the pics, they look good. Has anyone tried 235 - 45 - 18 on a 2000 body style Maxima w/g35 wheels??
Old Jul 15, 2007 | 08:16 PM
  #501
irish44j's Avatar
retired moderator
[QUOTE=Padoora]
QUOTE]
they'll likely rub....my winter tires are the same diameter and they rub in the rear.
Old Aug 1, 2007 | 03:08 PM
  #502
SE My 6sp's Avatar
i was going to ask the same question are they as good as the factory ones look wise, cuz i'm having trouble finding a set of 18" coupe wheels for a good price
Old Aug 1, 2007 | 04:03 PM
  #503
soundmike's Avatar
Very sound, Mike
audtatious (Matt) bought some recently. You can check out his thread here. I personally think it looks awesome in Hypersilver.
Old Aug 1, 2007 | 06:57 PM
  #504
irish44j's Avatar
retired moderator
They look the same as mine (which are painted)...
Old Aug 1, 2007 | 07:42 PM
  #505
SilverGLE's Avatar
^ I think the photoshopped pic of his car makes them look like yours, irish... The "hypersilver" color looks 100x better...
Please, PLEASE, someone comment on the 18x8 replicas on ebay from the OEM seller... I posted those a month ago and got no response at all.
Old Aug 1, 2007 | 08:17 PM
  #506
irish44j's Avatar
retired moderator
you say something like that again, I'll permaban you
Old Aug 1, 2007 | 08:19 PM
  #507
irish44j's Avatar
retired moderator
I think the lack of response means nobody has them
I wouldn't see any major problem with them....I had an Ebay "OEM replacement" 5th gen wheel that was identical to my actual OEM wheels in every respect.
Old Aug 1, 2007 | 10:17 PM
  #508
SilverGLE's Avatar
Yeah, I think the quality should be about the same... I'll probably sell my scuffed-up OEM 18's sometime in the next year and replace them with the replicas for a fresh start. Damn college parking, especially parallel parking has killed them... Even better, I've hit more curbs on my Max than I have with my last car.
Old Aug 2, 2007 | 04:13 AM
  #509
soundmike's Avatar
Very sound, Mike
Go to the succeeding pages (3 in particular), he has actual photos of it there, along with a short take on what he thought about the rims.
Cliffs. The quality is good, but there was an issue with one of them not fitting correctly.
  #510
soundmike's Avatar
Very sound, Mike
Somewhat, only glossier.
Old Aug 2, 2007 | 03:01 PM
  #511
irish44j's Avatar
retired moderator
that pic of mine is old. I re-did them with Wurth paint (what is used on OEM BMW/Audi wheels) and they have much more lustre now.
first paint (silver spray paint + clearcoat) on the right.
repaint (Wurth + clearcoat + better prep) on the left
Old Aug 2, 2007 | 03:46 PM
  #512
SilverGLE's Avatar
But these are replicas in the OEM size (18x8 versus 18x7.5) from a different seller (supposedly). I already knew about the 18x7.5 copies with the yellow center caps...
Old Aug 2, 2007 | 03:50 PM
  #513
soundmike's Avatar
Very sound, Mike
They're from OE Wheels. They are 18x8 with the silver center caps. Although, if you ask me, they may be sold as OE, but i don't really think they are made by the same manufacturer.
Old Aug 2, 2007 | 03:53 PM
  #514
soundmike's Avatar
Very sound, Mike
I forgot about that! You have way too many posts for me to keep up.
Old Aug 2, 2007 | 10:48 PM
  #515
SilverGLE's Avatar
True. I wouldn't be surprised if someone else other than Infiniti's wheel mfg made these wheels. But you can't beat the price for them brand new... I think I'll bite, eventually.
Old Aug 3, 2007 | 04:11 AM
  #516
soundmike's Avatar
Very sound, Mike
I'm with you on that. Even discount wheel places locally are selling genuine rims for $200 a pop.
Old Aug 6, 2007 | 04:26 PM
  #517
02Maximan's Avatar
Extra noise with g35 wheels?
I recently installed some slightly used 17" g35 coupe wheels that I purchased off of g35driver and I seem to hear a lot more road noise than before. My wheels I had on before were 16" GXE wheels with 215 60 16 tires. The new ones are OE G35 size: 235 50 17 rear and 225 50 17 front. They're also OE Potenzas. Is it going to be a given that with wider tires and also the fact that they are Potenzas, that I will have a noiser ride?
Old Aug 6, 2007 | 04:49 PM
  #518
Fast1one's Avatar
I recently installed some slightly used 17" g35 coupe wheels off of g35driver and I seem to hear a lot more road noise. My wheels I had on before were some GXE 16"s with 215 60 16 tires. The new ones are the stock G35 size: 235 50 and 225 50 17. They're also Potenzas. Is it going to be a given that with wider tires and also the fact that they are Potenzas, that I will have a noiser ride?
Its the lower profile i would imagine, and possibly the tires...
Old Aug 7, 2007 | 06:47 PM
  #519
02Maximan's Avatar
Bump... Is this basically what I get for going to a bigger tire and also running potenza re92s?
Old Aug 7, 2007 | 06:51 PM
  #520
irish44j's Avatar
retired moderator
1. the size has little/nothing to do with it
2. the tire could be unevenly worn or just worn down, in which case it could get louder.
3. some tires simply are louder than others
4. check tire pressures to make sure they are correct
5. PLEASE get rid of the RE92s as soon as you can. They are downright dangerous in the rain and one of the worst "all-season" tires ever made.
