Wheels/tires Sticky? G35 wheels on maximas
Old Aug 8, 2007 | 08:07 PM
  #521
IHAVEA2KMAXIMA's Avatar
I've read through the whole thread and not many people mention about the riding quality with them 18's. So I was just wondering how do 18" ride after lowered compare with 16-17" stockies. I remember when I had GLE suspension with 350z (245/45/18) and it rode like **** and rubbed a lot.
Old Aug 8, 2007 | 10:35 PM
  #522
SilverGLE's Avatar
I'm watching you, boy...
^ The reason you rubbed is the 245/45's... That size is 99% guaranteed to rub on a 5/5.5 gen. Your ride will be rougher with 18's versus 16's or 17's. I first had 245/45's in the rear and rubbed half the time with nobody in the car and 90% with an extra person. I went from 215/55/16 to 225/45/18 and the ride is definitely rougher, but not so bad you will really hate it. It's a noticeable difference, as I went from the 18's back to the 16's on Sunday for autox and haven't put the 18's back on (new suspension hopefully this weekend).
Old Aug 9, 2007 | 12:01 AM
  #523
Yea.. after reading 18pages of 245 will rub, Imma look for a set w/o tires so I can get some 235 or will rolling fenders work?
Old Aug 9, 2007 | 08:52 AM
  #524
joebangaa's Avatar
Why not 245/40/18?
Old Aug 9, 2007 | 10:09 AM
  #525
SilverGLE's Avatar
Originally Posted by joebangaa
Why not 245/40/18?
That size can still rub... Some people are running it with no problems, though. It's just not as likely to rub as 245/45/18.
I think you can fit 245's if you roll the fenders... Please, someone confirm that.
Old Aug 9, 2007 | 04:54 PM
  #526
soundmike's Avatar
Very sound, Mike
I'm on 245/40/18 w/ 40mm offset 18x8.5 rims, dropped on Maxspeeds. No rubbing.
Old Aug 15, 2007 | 08:14 PM
  #527
Hey Irish, what size tire did you run on the front G35c 6spokes wheels? I tried using the offset calculator and it seems the 17x7.5 with 225/45/17 and 30mm offset would stick out beyond the fender.
And bump for my fender rolling question too.
Old Aug 20, 2007 | 01:10 PM
  #528
I think I can now answer my own question since I have my fenders rolled. I still rub a bit with 17x8 (235/50/17) with 33mm offset. With that said... 18x8 (245/45/18) with 30mm offset should still rub with fenders rolled.
Old Aug 20, 2007 | 05:10 PM
  #529
irish44j's Avatar
retired moderator
that's because 245/45/18 is not even close to being the correct size. On the 18s use 235/40/18 or 245/40/18
On 17x8 you should be using 235/45/17....
You're rubbing because your tires are too "tall"...
For example, you can see in the original post in this thread that I have both the 18's and the 17s.....and neither of them rubs anyplace. And my fenders are not rolled.
Old Aug 21, 2007 | 02:03 PM
  #530
Okie pie , but I'm just trying to say that 245 will stick out too much that it will rub on rolled fenders. Some people might not rub due to being dropped on different suspension and other variables. Nonetheless, you're right on my sidewall part.
Old Aug 22, 2007 | 01:07 PM
  #531
darklegend06's Avatar
I skimmed through all the posts in here and prob missed it but I was wondering if I need to get new lug nuts if I get the G35 Coupe 7 spoke 18" rims or even the rays forged 19"?
Old Aug 23, 2007 | 04:16 PM
  #532
joebangaa's Avatar
New lug nuts are not necessary.
Old Aug 24, 2007 | 06:25 AM
  #533
kbmax's Avatar
2004 18" 350Z Wheels on '04 Maxima???
Are any modifications needed to put a 18" 2004 350Z wheel on a 2004 Maxima? Are they identical in style (look the same)? Wheel is 18x8 (stamped as REAR) and +35 offset.
TIA,
Kevin
Old Aug 24, 2007 | 06:34 AM
  #534
tripleGmax's Avatar
im pretty sure the offset is +30 and they will clear a bbk
Old Aug 24, 2007 | 07:38 AM
  #535
kbmax's Avatar
Oops, yes, they are +30 not +35. Hopefully, someone with an 04+ will say yes for sure. Nissan said the hub is different...
Thanks!
Old Aug 24, 2007 | 11:10 AM
  #536
jattsingh's Avatar
what do you guys think of these:
http://cgi.ebay.com/ebaymotors/Infin...QQcmdZViewItem
they are oem 19's from an 2006 infiniti m45. Would these work with a 2004 maxima? What size tires would I need for these?
Old Aug 24, 2007 | 01:00 PM
  #537
00MaxSE's Avatar
Pointy Elbows
It's been done before.
For tire size: http://forums.maxima.org/showthread.php?t=243784
Old Aug 24, 2007 | 02:38 PM
  #538
Please tell me you are not planning to bid on that...
Old Aug 24, 2007 | 04:52 PM
  #539
00MaxSE's Avatar
Pointy Elbows
Holy expensive!!
Old Aug 25, 2007 | 10:10 AM
  #540
jattsingh's Avatar
no that is too expensive, i am going to wait until i can find a deal. I think those rims look really good though, does anyone else have them on their 6th gen maxima?
Old Aug 25, 2007 | 01:32 PM
  #541
MetalBlueMaxx's Avatar
Yall think these would clear a SS Corp BBK? It's bigger than the z32 calipers for sure so I don't know.
Old Aug 25, 2007 | 05:05 PM
  #542
jattsingh's Avatar
ok so the tire size is 245/40-19. If I got the infiniti m45 rims and I was thinking about getting the Sumitomo HTR Z III (http://www.tirerack.com/tires/tires....nSpeedRating=V)
would this fit with no problem on my 2004 maxima? Would I be messing anything up in any way by doing this? Sorry, I do not know much about wheels/tires.
Old Aug 29, 2007 | 04:09 PM
  #543
farscaper's Avatar
I've been reading this huge sticky for a few days now. Great info. I just upgraded to a 2003 SE. I'll be using my original 17s for winters but I'm investigating new wheels & tires for the spring. Probably jump to 18s using 235/40/18 rubber.
While checking out prices I keep finding this web-site for OEM wheels. Is there anyone out there with any experience with them? Heard anything?
http://shop.wheelsrims.net/
Old Aug 29, 2007 | 06:18 PM
  #544
bwinter7's Avatar
Wow, that's a great find. All I know is that someone is going to have brand new SE-R rims for $250 a pop for next spring
Old Aug 29, 2007 | 07:43 PM
  #545
SilverGLE's Avatar
Never heard of them, so no opinions here. I'm more of the G 18's kind of man, so ebay or the G forums still better deals.
Old Aug 29, 2007 | 10:59 PM
  #546
joebangaa's Avatar
So why is the other one $705.99?
Old Aug 31, 2007 | 12:15 AM
  #547
riceyasian86's Avatar
17" 03 g35 coupe wheels
Old Sep 10, 2007 | 07:03 AM
  #548
Dan5.5's Avatar
Hey everyone,
quick question about center caps/
I got the 18 wheels from the sedan with the aero package. Which center caps to you guys use? Thanks, once i get center caps ill post pics up.
Old Sep 16, 2007 | 06:25 AM
  #549
bwinter7's Avatar
Because the $705 one is chrome, I don't want chrome. But, I am going to call them to ask the weight before I buy them
Old Sep 27, 2007 | 04:39 PM
  #550
Ericdd's Avatar
does anybody have the new murano 6 spoke wheels on there 4th gen? I'm currently looking for a 4 Gen for a family/daily driver and I really like the look of these wheels. if you have them please post pictures
Old Sep 29, 2007 | 01:24 PM
  #551
Buck96's Avatar
Hey Irish What year are your G 18"s ?
I see alot of G 18's for sale that are the Darker Grey/ Black chrome.
I want the lighter style like yours any ideas?
Old Sep 30, 2007 | 12:34 AM
  #552
soundmike's Avatar
Very sound, Mike
His is lighter because he repainted 'em.
Old Oct 1, 2007 | 01:24 PM
  #553
Buck96's Avatar
Yeah?! with what they look great
btw nice cardomain book irish, 32. pgs
Old Oct 4, 2007 | 05:16 PM
  #554
Audtatious's Avatar
Bandwagon Lover
The ebay 7-spoke 18x8x30mm wheels as sold by OE Wheel Distributors (seller moore9911) work just fine as I believe these are made by the same company that made the factory rims. I have a set of the hyper-silver that ran around $610 with shipping. I only had issues with one wheel that had a burr that needed removing in the hub section which was taken care of quickly. These rims came with factory Infiniti center caps and a set of caps without emblems.
From a tire standpoint, I would suggest a 235-40-18 for the 5th-gen maxima as a 245-40-18 will rub via the rear passenger fender lip (with a drop). Even with a light roll it will still rub (tho not to the point of causing a tire problem).
Old Oct 10, 2007 | 07:05 PM
  #555
Buck96's Avatar
Up Dates!! G35 'O7
the New '07 G35 sedan wheels 18"
Old Oct 10, 2007 | 07:14 PM
  #556
Buck96's Avatar
NP is this true Irish??
Old Oct 10, 2007 | 07:33 PM
  #557
Audtatious's Avatar
Bandwagon Lover
Originally Posted by Buck96
btw cool chick Audt, that your sis?
Nah, you don't recognize your mom before you were born?
Old Oct 10, 2007 | 07:44 PM
  #558
irish44j's Avatar
retired moderator
last two posts need to be deleted. this thread stays on-topic or , capiche?
Old Oct 13, 2007 | 02:46 PM
  #559
Audtatious's Avatar
Bandwagon Lover
Hey, just defending my family honor. If it results in a ban then it is what it is
Old Oct 13, 2007 | 03:14 PM
  #560
SilverGLE's Avatar
Yes. He sanded them down and repainted them Audi silver, IIRC. Thread link here.
Edit: Another thread here.
