55 or 60?? Please help...
Old Sep 13, 2005 | 07:38 AM
MystA RavE's Avatar
I need to buy tires today and i'm not sure whether I should get the 215/60/16 instead of the 215/55/16. I want to do this because its cheaper...I dont care about the speedo I just need to make sure that it will be good on my 99 max.
Old Sep 13, 2005 | 09:40 AM
Mizeree_X's Avatar
Getting back to his roots
Use the tire calculator in the sticky...anything under 5% and you should be ok.
Old Sep 13, 2005 | 11:40 AM
guyfromkop's Avatar
go with 55, you'll get better handeling and that's what is suppose to fit 16 inch rims for our maximas
Old Sep 13, 2005 | 04:52 PM
Dave H.'s Avatar
He is right....go with 55....
Old Sep 17, 2005 | 08:53 AM
Tosh's Avatar
It is not just the speedometer; it also changes your gearing (upward) about eight to nine percent: your low gear will not be as low, and your high gear will be more like overdrive. If you do more highway cruising than pulling away from lights, that could be a good thing:: you will get more miles per gallon with the larger diameter tire. The equivalent in a 60-series tire to a 215/55-16 is 195/60-16; that will have the same overall diameter and revs per mile as a 215/55-16.
Old Sep 18, 2005 | 05:53 PM
MystA RavE's Avatar
I dont do a lot of highway...does that mean this is a bad thing gas mileage wise?
secoske
Dec 11, 2017 10:39 PM
maxxxed out
May 4, 2002 10:03 PM
MaxedOut2g
Apr 24, 2002 06:46 AM
samiam
Apr 15, 2002 07:50 AM
